Topic: Arduino Mega ADK Demokit problem (Read 4107 times) previous topic - next topic
weisheng5566
Hi all,
I just received a arduino Mega ADk board for one of my project but when i tried to upload the demokit code from the google ADK to the board, i get the error below.
I already have capsense library, USB host shield library and android accessory library installed.
demokit:52: error: 'CapSense' does not name a type
demokit.pde: In function 'void setup()':
demokit:120: error: 'touch_robot' was not declared in this scope
demokit.pde: In function 'void loop()':
demokit:250: error: 'touch_robot' was not declared in this scope
Thanks in advance.
AWOL
I think you need to check you've got the CapacitiveSensor library installed, and that the variables and classes are correctly named.
For some reason, they appear to have different names in the most recent releases.
Jhojan
#2
Jan 30, 2013, 10:50 pm Last Edit: Jan 30, 2013, 11:16 pm by Jhojan Reason: 1
I have the same problem
I have installed (arduino 1.0.3) in opt /
in opt/arduino-1.0.3/libraries I copied the folders (AndroidAccessory, CapSense and USB_Host_Shield)
i got the CapSense's  folder by changing the name of the extracted folder (arduino-libraries-CapacitiveSensor-b297f3f.zip) taken from  related link (CapacitiveSensor04.zip).
I have tried to upload as root in Ubuntu 12.04 64 bit
in file / examples / CapSense / CapitiveSensorSketch I did not find problems  uploading to the board
So, I've changed in the lines with errors (CapSense) by (CapacitiveSensor).
considering that the class  is now  named  (CapacitiveSensor) at CapSense library v.04
and the library is now called  CapacitiveSensor as well
taking this
#include <Wire.h>
#include <Servo.h>
#include <Max3421e.h>
#include <Usb.h>
#include <AndroidAccessory.h>
#include <CapacitiveSensor.h>
#define  LED3_RED       2
#define  LED3_GREEN     4
#define  LED3_BLUE      3
#define  LED2_RED       5
#define  LED2_GREEN     7
#define  LED2_BLUE      6
#define  LED1_RED       8
#define  LED1_GREEN     10
#define  LED1_BLUE      9
#define  SERVO1         11
#define  SERVO2         12
#define  SERVO3         13
#define  TOUCH_RECV     14
#define  TOUCH_SEND     15
#define  RELAY1         A0
#define  RELAY2         A1
#define  LIGHT_SENSOR   A2
#define  TEMP_SENSOR    A3
#define  BUTTON1        A6
#define  BUTTON2        A7
#define  BUTTON3        A8
#define  JOY_SWITCH     A9      // pulls line down when pressed
#define  JOY_nINT       A10     // active low interrupt input
#define  JOY_nRESET     A11     // active low reset output
AndroidAccessory acc("Google, Inc.",
    "DemoKit",
    "DemoKit Arduino Board",
    "1.0",
    "http://www.android.com",
    "0000000012345678");
Servo servos[3];
// 10M ohm resistor on demo shield
CapacitiveSensor   touch_robot = CapacitiveSensor(TOUCH_SEND, TOUCH_RECV);
void setup();
void loop();
void init_buttons()
pinMode(BUTTON1, INPUT);
pinMode(BUTTON2, INPUT);
pinMode(BUTTON3, INPUT);
pinMode(JOY_SWITCH, INPUT);
// enable the internal pullups
digitalWrite(BUTTON1, HIGH);
digitalWrite(BUTTON2, HIGH);
digitalWrite(BUTTON3, HIGH);
digitalWrite(JOY_SWITCH, HIGH);
void init_relays()
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
void init_leds()
digitalWrite(LED1_RED, 1);
digitalWrite(LED1_GREEN, 1);
digitalWrite(LED1_BLUE, 1);
pinMode(LED1_RED, OUTPUT);
pinMode(LED1_GREEN, OUTPUT);
pinMode(LED1_BLUE, OUTPUT);
digitalWrite(LED2_RED, 1);
digitalWrite(LED2_GREEN, 1);
digitalWrite(LED2_BLUE, 1);
pinMode(LED2_RED, OUTPUT);
pinMode(LED2_GREEN, OUTPUT);
pinMode(LED2_BLUE, OUTPUT);
digitalWrite(LED3_RED, 1);
digitalWrite(LED3_GREEN, 1);
digitalWrite(LED3_BLUE, 1);
pinMode(LED3_RED, OUTPUT);
pinMode(LED3_GREEN, OUTPUT);
pinMode(LED3_BLUE, OUTPUT);
void init_joystick(int threshold);
byte b1, b2, b3, b4, c;
Serial.print("\r\nStart");
init_leds();
init_relays();
init_buttons();
init_joystick( 5 );
// autocalibrate OFF
touch_robot.set_CS_AutocaL_Millis(0xFFFFFFFF);
servos[0].attach(SERVO1);
servos[0].write(90);
servos[1].attach(SERVO2);
servos[1].write(90);
servos[2].attach(SERVO3);
servos[2].write(90);
b1 = digitalRead(BUTTON1);
b2 = digitalRead(BUTTON2);
b3 = digitalRead(BUTTON3);
b4 = digitalRead(JOY_SWITCH);
c = 0;
acc.powerOn();
byte err;
byte idle;
static byte count = 0;
byte msg[3];
long touchcount;
if (acc.isConnected()) {
int len = acc.read(msg, sizeof(msg), 1);
int i;
byte b;
uint16_t val;
int x, y;
char c0;
if (len > 0) {
// assumes only one command per packet
if (msg[0] == 0x2) {
if (msg[1] == 0x0)
analogWrite(LED1_RED, 255 - msg[2]);
else if (msg[1] == 0x1)
analogWrite(LED1_GREEN, 255 - msg[2]);
else if (msg[1] == 0x2)
analogWrite(LED1_BLUE, 255 - msg[2]);
else if (msg[1] == 0x3)
analogWrite(LED2_RED, 255 - msg[2]);
else if (msg[1] == 0x4)
analogWrite(LED2_GREEN, 255 - msg[2]);
else if (msg[1] == 0x5)
analogWrite(LED2_BLUE, 255 - msg[2]);
else if (msg[1] == 0x6)
analogWrite(LED3_RED, 255 - msg[2]);
else if (msg[1] == 0x7)
analogWrite(LED3_GREEN, 255 - msg[2]);
else if (msg[1] == 0x8)
analogWrite(LED3_BLUE, 255 - msg[2]);
else if (msg[1] == 0x10)
servos[0].write(map(msg[2], 0, 255, 0, 180));
else if (msg[1] == 0x11)
servos[1].write(map(msg[2], 0, 255, 0, 180));
else if (msg[1] == 0x12)
servos[2].write(map(msg[2], 0, 255, 0, 180));
} else if (msg[0] == 0x3) {
if (msg[1] == 0x0)
digitalWrite(RELAY1, msg[2] ? HIGH : LOW);
digitalWrite(RELAY2, msg[2] ? HIGH : LOW);
msg[0] = 0x1;
b = digitalRead(BUTTON1);
if (b != b1) {
msg[1] = 0;
msg[2] = b ? 0 : 1;
acc.write(msg, 3);
b1 = b;
b = digitalRead(BUTTON2);
if (b != b2) {
msg[1] = 1;
msg[2] = b ? 0 : 1;
acc.write(msg, 3);
b2 = b;
b = digitalRead(BUTTON3);
if (b != b3) {
msg[1] = 2;
msg[2] = b ? 0 : 1;
acc.write(msg, 3);
b3 = b;
b = digitalRead(JOY_SWITCH);
if (b != b4) {
msg[1] = 4;
msg[2] = b ? 0 : 1;
acc.write(msg, 3);
b4 = b;
switch (count++ % 0x10) {
case 0:
val = analogRead(TEMP_SENSOR);
msg[0] = 0x4;
msg[1] = val >> 8;
msg[2] = val & 0xff;
acc.write(msg, 3);
break;
case 0x4:
val = analogRead(LIGHT_SENSOR);
msg[0] = 0x5;
msg[1] = val >> 8;
acc.write(msg, 3);
break;
case 0x8:
read_joystick(&x, &y);
msg[0] = 0x6;
msg[1] = constrain(x, -128, 127);
msg[2] = constrain(y, -128, 127);
acc.write(msg, 3);
break;
case 0xc:
touchcount = touch_robot.capacitiveSensor(5);
c0 = touchcount > 750;
if (c0 != c) {
msg[0] = 0x1;
msg[1] = 3;
msg[2] = c0;
acc.write(msg, 3);
c = c0;
break;
// reset outputs to default values on disconnect
analogWrite(LED1_RED, 255);
analogWrite(LED1_GREEN, 255);
analogWrite(LED1_BLUE, 255);
analogWrite(LED2_RED, 255);
analogWrite(LED2_GREEN, 255);
analogWrite(LED2_BLUE, 255);
analogWrite(LED3_RED, 255);
analogWrite(LED3_GREEN, 255);
analogWrite(LED3_BLUE, 255);
digitalWrite(RELAY1, LOW);
digitalWrite(RELAY2, LOW);
delay(10);
// Austria Microsystems i2c Joystick
byte status = 0;
pinMode(JOY_nINT, INPUT);
digitalWrite(JOY_nINT, HIGH);
pinMode(JOY_nRESET, OUTPUT);
digitalWrite(JOY_nRESET, 1);
delay(1);
digitalWrite(JOY_nRESET, 0);
delay(1);
Wire.begin();
do {
status = read_joy_reg(0x0f);
} while ((status & 0xf0) != 0xf0);
// invert magnet polarity setting, per datasheet
write_joy_reg(0x2e, 0x86);
calibrate_joystick(threshold);
int offset_X, offset_Y;
void calibrate_joystick(int dz)
char iii;
int x_cal = 0;
int y_cal = 0;
// Low Power Mode, 20ms auto wakeup
// INTn output enabled
// INTn active after each measurement
// Normal (non-Reset) mode
write_joy_reg(0x0f, 0x00);
delay(1);
// dummy read of Y_reg to reset interrupt
read_joy_reg(0x11);
for(iii = 0; iii != 16; iii++) {
while(!joystick_interrupt()) {}
x_cal += read_joy_reg(0x10);
y_cal += read_joy_reg(0x11);
// divide by 16 to get average
offset_X = -(x_cal>>4);
offset_Y = -(y_cal>>4);
write_joy_reg(0x12, dz - offset_X);  // Xp, LEFT threshold for INTn
write_joy_reg(0x13, -dz - offset_X);  // Xn, RIGHT threshold for INTn
write_joy_reg(0x14, dz - offset_Y);  // Yp, UP threshold for INTn
write_joy_reg(0x15, -dz - offset_Y);  // Yn, DOWN threshold for INTn
// dead zone threshold detect requested?
if (dz)
write_joy_reg(0x0f, 0x04);
void read_joystick(int *x, int *y)
*x = read_joy_reg(0x10) + offset_X;
*y = read_joy_reg(0x11) + offset_Y;  // reading Y clears the interrupt
char joystick_interrupt()
return digitalRead(JOY_nINT) == 0;
#define  JOY_I2C_ADDR    0x40
char read_joy_reg(char reg_addr)
char c;
Wire.beginTransmission(JOY_I2C_ADDR);
Wire.write(reg_addr);
Wire.endTransmission();
Wire.requestFrom(JOY_I2C_ADDR, 1);
while(Wire.available())
c = Wire.read();
return c;
void write_joy_reg(char reg_addr, char val)
Wire.write(val);
now i can upload, sorry for my English
stefan123
I also have the same problem
i have used the code of Jhojan
but i stil get a error
in this line:
the error:
C:\Program Files\arduino-1.0.3\libraries\AndroidAccessory/AndroidAccessory.h: In function 'void loop()':
C:\Program Files\arduino-1.0.3\libraries\AndroidAccessory/AndroidAccessory.h:65: error: 'int AndroidAccessory::read(void*, int, unsigned int)' is private
sketch_feb17a:148: error: within this context
