Loading...
Pages: 1 [2]   Go Down
Author Topic: multiple microphones  (Read 823 times)
Offline Offline
Newbie
View Profile
i am ok to have problems and start over many times, i just would like to get a good starting point before i just dive into it and find out it is not possible with the arduino.
Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
Check it out:
http://coolarduino.wordpress.com/2012/10/01/sound-localization/
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
It sounds to me like it might be a fun project, but that the likelihood for it to not achieve the results you desire are high (sometimes referred to as “Failure”, but I like to call these learning experiences), so maybe not a good project for someone just starting out unless you are highly tolerant to “learning experiences”. I would suggest doing something simpler to start, but would love to see what is possible with this.
I agree. Your first couple of projects should be based on projects others have 'proven' to be successful. I found designing and building a 5x5x5 led cube to be a perfect one for me to try and build on learning to program as I already had a hardware background. So I approached that project from a published one with the idea to use their hardware design as is but to write the sketch from scratch without even looking at their software. So build according to the skills you wish to acquire and build upon.
Lefty
Logged
Offline Offline
Newbie
View Profile
thanks guys this has really helped alot. i am going to put this project on the back burner for now but it will get done sometime.
Logged
Offline Offline
Newbie
View Profile
Quote
that is way cool, i would like to make something like that eventually but it would have to respond to just one loud bang instead of to continuous music
Logged
Montreal
Offline Offline
Edison Member
View Profile
WWW
Quote
Well, project is merely a concept: measure phase -> calculate time difference -> calculate direction of the source. Localization of the loud bang   differs only in last step, filtering / calculation direction.
For short impulses, less data available , the same time there is no need for "quasi real time" speed, so more math could be implemented to process received data pool,  and consequently get  even better accuracy.  All depends, on how fast  someone needs a result and what computational power is available.
Logged
Offline Offline
Newbie
View Profile
that make alot of help thank you.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
