Loading...
Pages: [1]   Go Down
Author Topic: Checksum Error in DHT11  (Read 321 times)
Offline Offline
Newbie
View Profile
Hi!!!
I'm testing DHT11 sensor with the code I saw in this page:
http://arduino.cc/playground/Main/DHT11Lib
And it's impossible always the same problem "Checksum Error". I've tried with other codes and the same problem always happens.
I've checked elctrical parts, ports... I use Arduino One with Ethernet Shield.
Somebody can I help me?
In advance, thank you very much.
« Last Edit: November 30, 2012, 10:27:29 am by kukuso » Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
1) post your code
2) have you tried without Ethernet shield => minimizing your code, or use sample code of the lib
Note the delay time between 2 samples is 2 seconds for DHT11
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
OK, this is the code
//   FILE:  dht11_test1.pde
// PURPOSE: DHT11 library test sketch for Arduino
//Celsius to Fahrenheit conversion
double Fahrenheit(double celsius)
   return 1.8 * celsius + 32;
//Celsius to Kelvin conversion
double Kelvin(double celsius)
   return celsius + 273.15;
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
   double A0= 373.15/(273.15 + celsius);
   double SUM = -7.90298 * (A0-1);
   SUM += 5.02808 * log10(A0);
   SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
   SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
   SUM += log10(1013.246);
   double VP = pow(10, SUM-3) * humidity;
   double T = log(VP/0.61078);   // temp var
   return (241.88 * T) / (17.558-T);
// delta max = 0.6544 wrt dewPoint()
// 5x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
   double a = 17.271;
   double b = 237.7;
   double temp = (a * celsius) / (b + celsius) + log(humidity/100);
   double Td = (b * temp) / (a - temp);
   return Td;
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN 2
  Serial.println("DHT11 TEST PROGRAM ");
  Serial.print("LIBRARY VERSION: ");
  Serial.println(DHT11LIB_VERSION);
  Serial.println("\n");
  int chk = DHT11.read(DHT11PIN);
  Serial.print("Read sensor: ");
  switch (chk)
    case DHTLIB_OK:
      Serial.println("OK");
    case DHTLIB_ERROR_CHECKSUM:
      Serial.println("Checksum error");
    case DHTLIB_ERROR_TIMEOUT:
      Serial.println("Time out error");
    default:
      Serial.println("Unknown error");
  Serial.print("Humidity (%): ");
  Serial.println((float)DHT11.humidity, 2);
  Serial.print("Temperature (oC): ");
  Serial.println((float)DHT11.temperature, 2);
  Serial.print("Temperature (oF): ");
  Serial.println(Fahrenheit(DHT11.temperature), 2);
  Serial.print("Temperature (K): ");
  Serial.println(Kelvin(DHT11.temperature), 2);
  Serial.print("Dew Point (oC): ");
  Serial.println(dewPoint(DHT11.temperature, DHT11.humidity));
  Serial.print("Dew PointFast (oC): ");
  Serial.println(dewPointFast(DHT11.temperature, DHT11.humidity));
  delay(2000);
// END OF FILE
I have tried without ethernet and nothing.
Sometimes appears Timeout error and other times Checksum error.
Logged
Offline Offline
Newbie
View Profile
Today I checked with other DHT11 and it runs correctly so maybe it was the PCB or own sensor.
Thank you very much!
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
you're welcome.
Please use the code tags next time when posting code - it is the # button just above the smileys.
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
