Topic: Checksum Error in DHT11 (Read 3552 times) previous topic - next topic
kukuso
Nov 30, 2012, 04:23 pm Last Edit: Nov 30, 2012, 04:27 pm by kukuso Reason: 1
Hi!!!
I'm testing DHT11 sensor with the code I saw in this page:
http://arduino.cc/playground/Main/DHT11Lib
And it's impossible always the same problem "Checksum Error". I've tried with other codes and the same problem always happens.
I've checked elctrical parts, ports... I use Arduino One with Ethernet Shield.
Somebody can I help me?
In advance, thank you very much.
robtillaart
1) post your code
2) have you tried without Ethernet shield => minimizing your code, or use sample code of the lib
Note the delay time between 2 samples is 2 seconds for DHT11
Rob Tillaart
kukuso
OK, this is the code
//   FILE:  dht11_test1.pde
// PURPOSE: DHT11 library test sketch for Arduino
//Celsius to Fahrenheit conversion
double Fahrenheit(double celsius)
   return 1.8 * celsius + 32;
//Celsius to Kelvin conversion
double Kelvin(double celsius)
   return celsius + 273.15;
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
   double A0= 373.15/(273.15 + celsius);
   double SUM = -7.90298 * (A0-1);
   SUM += 5.02808 * log10(A0);
   SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
   SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
   SUM += log10(1013.246);
   double VP = pow(10, SUM-3) * humidity;
   double T = log(VP/0.61078);   // temp var
   return (241.88 * T) / (17.558-T);
// delta max = 0.6544 wrt dewPoint()
// 5x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
   double a = 17.271;
   double b = 237.7;
   double temp = (a * celsius) / (b + celsius) + log(humidity/100);
   double Td = (b * temp) / (a - temp);
   return Td;
#include <dht11.h>
dht11 DHT11;
#define DHT11PIN 2
  Serial.println("DHT11 TEST PROGRAM ");
  Serial.print("LIBRARY VERSION: ");
  Serial.println(DHT11LIB_VERSION);
  Serial.println();
  Serial.println("\n");
  int chk = DHT11.read(DHT11PIN);
  Serial.print("Read sensor: ");
  switch (chk)
    case DHTLIB_OK:
      Serial.println("OK");
      break;
    case DHTLIB_ERROR_CHECKSUM:
      Serial.println("Checksum error");
      break;
    case DHTLIB_ERROR_TIMEOUT:
      Serial.println("Time out error");
      break;
    default:
      Serial.println("Unknown error");
      break;
  Serial.print("Humidity (%): ");
  Serial.println((float)DHT11.humidity, 2);
  Serial.print("Temperature (oC): ");
  Serial.println((float)DHT11.temperature, 2);
  Serial.print("Temperature (oF): ");
  Serial.println(Fahrenheit(DHT11.temperature), 2);
  Serial.print("Temperature (K): ");
  Serial.println(Kelvin(DHT11.temperature), 2);
  Serial.print("Dew Point (oC): ");
  Serial.println(dewPoint(DHT11.temperature, DHT11.humidity));
  Serial.print("Dew PointFast (oC): ");
  Serial.println(dewPointFast(DHT11.temperature, DHT11.humidity));
  delay(2000);
// END OF FILE
I have tried without ethernet and nothing.
Sometimes appears Timeout error and other times Checksum error.
kukuso
Today I checked with other DHT11 and it runs correctly so maybe it was the PCB or own sensor.
Thank you very much!
robtillaart
you're welcome.
Please use the code tags next time when posting code - it is the # button just above the smileys.
Rob Tillaart
