It is ready and it works flawlessly! Thanks guys for your help!
PaulS: I have to apologize, you were right; it is better to use "while(Serial.available()){", and I could go down with the delay as low as 2 microseconds.
Here is the final code:
/* This program reads a text up to 100 characters through the Serial connection,
puts it into an array of bytes
and sends out the morse code. */
const byte spk = 10; //speaker pin
const byte led = 13; //led pin
byte text[100]; //array for charakters
boolean newText = false;
byte part[9]; //array for the morse code of a charakter
byte wpm = 13; //words per minute, set speed
int Hz = 800; //morse code frequency (in herz)
pinMode(spk, OUTPUT);
pinMode(led, OUTPUT);
Serial.println("Power On");
//couldn't find any other solutions to put the parts of the morse code in an array, default is 9
void setChar(byte p0=9, byte p1=9, byte p2=9, byte p3=9, byte p4=9, byte p5=9, byte p6=9, byte p7=9, byte p8=9){
part[0] = p0;
part[1] = p1;
part[2] = p2;
part[3] = p3;
part[4] = p4;
part[5] = p5;
part[6] = p6;
part[7] = p7;
part[8] = p8;
int numb = 0;
while(Serial.available()){ //read the text from serial
text[numb] = Serial.read();
if(text[numb] == 255) text[numb] = 0; //if there are no characters to read, Serial.read reads 255
numb++;
delay(2); //needed for stability
newText = true;
if(newText){
for(byte i=0; i<100; i++){
// if there is a next character (excluding space) -> gap between letters
if(text[i] > 32) morse(3);
switch(text[i]){ //convert ASCII numbers to morse code
case 32: //space
setChar(4);
break;
case 'A':
case 'a':
setChar(0,1);
break;
case 'B':
case 'b':
setChar(1,0,0,0);
break;
case 'C':
case 'c':
setChar(1,0,1,0);
break;
case 'D':
case 'd':
setChar(1,0,0);
break;
case 'E':
case 'e':
setChar(0);
break;
case 'F':
case 'f':
setChar(0,0,1,0);
break;
case 'G':
case 'g':
setChar(1,1,0);
break;
case 'H':
case 'h':
setChar(0,0,0,0);
break;
case 'I':
case 'i':
setChar(0);
break;
case 'J':
case 'j':
setChar(0,1,1,1);
break;
case 'K':
case 'k':
setChar(1,0,1);
break;
case 'L':
case 'l':
setChar(0,1,0,0);
break;
case 'M':
case 'm':
setChar(1,1);
break;
case 'N':
case 'n':
setChar(1);
break;
case 'O':
case 'o':
setChar(1,1,1);
break;
case 'P':
case 'p':
setChar(0,1,1,0);
break;
case 'Q':
case 'q':
setChar(1,1,0,1);
break;
case 'R':
case 'r':
setChar(0,1,0);
break;
case 'S':
case 's':
setChar(0,0,0);
break;
case 'T':
case 't':
setChar(1);
break;
case 'U':
case 'u':
case 'ú':
setChar(0,0,1);
break;
case 'V':
case 'v':
setChar(0,0,0,1);
break;
case 'W':
case 'w':
setChar(0,1,1);
break;
case 'X':
case 'x':
setChar(1,0,0,1);
break;
case 'Y':
case 'y':
setChar(1,0,1,1);
break;
case 'Z':
case 'z':
setChar(1,1,0,0);
break;
case '0':
setChar(1,1,1,1,1);
break;
case '1':
setChar(0,1,1,1,1);
break;
case '2':
setChar(0,0,1,1,1);
break;
case '3':
setChar(0,0,0,1,1);
break;
case '4':
setChar(0,0,0,0,1);
break;
case '5':
setChar(0,0,0,0,0);
break;
case '6':
setChar(1,0,0,0,0);
break;
case '7':
setChar(1,1,0,0,0);
break;
case '8':
setChar(1,1,1,0,0);
break;
case '9':
setChar(1,1,1,1,0);
break;
case '.':
setChar(0,1,0,1,0,1);
break;
case ',':
setChar(1,1,0,0,1,1);
break;
case '?':
setChar(0,0,1,1,0,0);
break;
case 39: //Apostrophe
case 96:
setChar(0,1,1,1,1,0);
break;
case '!':
setChar(1,0,1,0,1,1);
break;
case '/':
setChar(1,0,0,1,0);
break;
case '(':
setChar(1,0,1,1,0);
break;
case ')':
setChar(1,0,1,1,0,1);
break;
case '&':
setChar(0,1,0,0,0);
break;
case ':':
setChar(1,1,1,0,0,0);
break;
case ';':
setChar(1,0,1,0,1,0);
break;
case '=':
setChar(1,0,0,0,1);
break;
case '+':
setChar(0,1,0,1,0);
break;
case '-':
setChar(1,0,0,0,0,1);
break;
case '_':
setChar(0,0,1,1,0,1);
break;
case '"':
setChar(0,1,0,0,1,0);
break;
case '$':
setChar(0,0,0,1,0,0,1);
break;
case '@':
setChar(0,1,1,0,1,0);
break;
case 'ä':
setChar(0,1,0,1);
break;
case 'á':
setChar(0,1,1,0,1);
break;
case 'é':
setChar(0,0,1,0,0);
break;
case 'ó':
case 'ö':
case 'ő':
setChar(1,1,1,0);
break;
case 'ü':
case 'ű':
setChar(0,0,1,1);
break;
default: //do nothing
setChar();
break;
Serial.write(text[i]);
character(); //output letter
text[i] = 0; //reset
Serial.println("");
newText = false;
void character(){
for(byte i=0; i<9; i++){
if(part[i] == 9) break;
else if(part[i] == 4) morse(4);
else{
morse(part[i]);
morse(2);
void morse(byte element){
if(element == 0){ //dot
digitalWrite(led, HIGH);
tone(spk, Hz, 1000 / wpm);
delay(1000 / wpm);
digitalWrite(led, LOW);
else if(element == 1){ //dash
tone(spk, Hz, 3000 / wpm);
delay(3000 / wpm);
else if(element == 2){ //inter-element gap
delay(1000 / wpm);
else if(element == 3){ //short gap (between letters)
delay(3000 / wpm);
else if(element == 4){ //medium gap or space (between words)
delay(7000 / wpm);
