Pages: 1 [2]   Go Down
Author Topic: error: 'setChar' was not declared in this scope  (Read 750 times)
New Jersey
Your problem may be caused by the IDE declaring function prototypes for you. Try moving the setChar function definition up before it is called.
Edit: Nick, yet again, you typed more quickly!
Melbourne, Australia
Shannon Member
Lua rocks!
Ach!
And I discovered it is a known issue, else I would have reported it:
http://code.google.com/p/arduino/issues/detail?id=386
(Been around for over 2 years so don't hold your breath).
Get Bitlash: http://bitlash.net
Sorry to be late to the party, but I thought I'd throw in the Morse and Morse2 examples that ship with Bitlash as specimens worth study for those coding Morse generators, especially those coming up against the problems of state machines for the first time.
Both examples use a compressed table to store the morse code translations.  The first example is blocking, and the second, Morse2, is fully non-blocking.
They are both in the Bitlash distribution, which you can get at http://bitlash.net.  I've attached them here for reference or you can see them online at https://github.com/billroy/bitlash/tree/master/examples/morse and https://github.com/billroy/bitlash/tree/master/examples/morse2
-br
« Last Edit: November 30, 2012, 07:00:32 pm by billroy » Logged
It looks like the function prototype-generator used by the IDE didn't recognize that prototype with the default arguments. Move setChar before loop, and it compiles OK.
Thanks that really works!
It is ready and it works flawlessly! Thanks guys for your help!
PaulS: I have to apologize, you were right; it is better to use "while(Serial.available()){", and I could go down with the delay as low as 2 microseconds.
Here is the final code:
/* This program reads a text up to 100 characters through the Serial connection,
 puts it into an array of bytes
 and sends out the morse code. */
const byte spk = 10;  //speaker pin
const byte led = 13;  //led pin
byte text[100];  //array for charakters
boolean newText = false;
byte part[9];  //array for the morse code of a charakter
byte wpm = 13; //words per minute, set speed
int Hz = 800; //morse code frequency (in herz)
  pinMode(spk, OUTPUT);
  pinMode(led, OUTPUT);
  Serial.println("Power On");
//couldn't find any other solutions to put the parts of the morse code in an array, default is 9
void setChar(byte p0=9, byte p1=9, byte p2=9, byte p3=9, byte p4=9, byte p5=9, byte p6=9, byte p7=9, byte p8=9){
  part[0] = p0;
  part[1] = p1;
  part[2] = p2;
  part[3] = p3;
  part[4] = p4;
  part[5] = p5;
  part[6] = p6;
  part[7] = p7;
  part[8] = p8;
  int numb = 0;
  while(Serial.available()){  //read the text from serial
    text[numb] = Serial.read();
    if(text[numb] == 255) text[numb] = 0; //if there are no characters to read, Serial.read reads 255
    numb++;
    delay(2);  //needed for stability
    newText = true;
  if(newText){
    for(byte i=0; i<100; i++){
      // if there is a next character (excluding space) -> gap between letters
      if(text[i] > 32) morse(3);
      switch(text[i]){  //convert ASCII numbers to morse code
      case 32:  //space
        setChar(4);
        break;
      case 'A':
      case 'a':
        setChar(0,1);
        break;
      case 'B':
      case 'b':
        setChar(1,0,0,0);
        break;
      case 'C':
      case 'c':
        setChar(1,0,1,0);
        break;
      case 'D':
      case 'd':
        setChar(1,0,0);
        break;
      case 'E':
      case 'e':
        setChar(0);
        break;
      case 'F':
      case 'f':
        setChar(0,0,1,0);
        break;
      case 'G':
      case 'g':
        setChar(1,1,0);
        break;
      case 'H':
      case 'h':
        setChar(0,0,0,0);
        break;
      case 'I':
      case 'i':
        setChar(0);
        break;
      case 'J':
      case 'j':
        setChar(0,1,1,1);
        break;
      case 'K':
      case 'k':
        setChar(1,0,1);
        break;
      case 'L':
      case 'l':
        setChar(0,1,0,0);
        break;
      case 'M':
      case 'm':
        setChar(1,1);
        break;
      case 'N':
      case 'n':
        setChar(1);
        break;
      case 'O':
      case 'o':
        setChar(1,1,1);
        break;
      case 'P':
      case 'p':
        setChar(0,1,1,0);
        break;
      case 'Q':
      case 'q':
        setChar(1,1,0,1);
        break;
      case 'R':
      case 'r':
        setChar(0,1,0);
        break;
      case 'S':
      case 's':
        setChar(0,0,0);
        break;
      case 'T':
      case 't':
        setChar(1);
        break;
      case 'U':
      case 'u':
      case 'ú':
        setChar(0,0,1);
        break;
      case 'V':
      case 'v':
        setChar(0,0,0,1);
        break;
      case 'W':
      case 'w':
        setChar(0,1,1);
        break;
      case 'X':
      case 'x':
        setChar(1,0,0,1);
        break;
      case 'Y':
      case 'y':
        setChar(1,0,1,1);
        break;
      case 'Z':
      case 'z':
        setChar(1,1,0,0);
        break;
      case '0':
        setChar(1,1,1,1,1);
        break;
      case '1':
        setChar(0,1,1,1,1);
        break;
      case '2':
        setChar(0,0,1,1,1);
        break;
      case '3':
        setChar(0,0,0,1,1);
        break;
      case '4':
        setChar(0,0,0,0,1);
        break;
      case '5':
        setChar(0,0,0,0,0);
        break;
      case '6':
        setChar(1,0,0,0,0);
        break;
      case '7':
        setChar(1,1,0,0,0);
        break;
      case '8':
        setChar(1,1,1,0,0);
        break;
      case '9':
        setChar(1,1,1,1,0);
        break;
      case '.':
        setChar(0,1,0,1,0,1);
        break;
      case ',':
        setChar(1,1,0,0,1,1);
        break;
      case '?':
        setChar(0,0,1,1,0,0);
        break;
      case 39:  //Apostrophe
      case 96:
        setChar(0,1,1,1,1,0);
        break;
      case '!':
        setChar(1,0,1,0,1,1);
        break;
      case '/':
        setChar(1,0,0,1,0);
        break;
      case '(':
        setChar(1,0,1,1,0);
        break;
      case ')':
        setChar(1,0,1,1,0,1);
        break;
      case '&':
        setChar(0,1,0,0,0);
        break;
      case ':':
        setChar(1,1,1,0,0,0);
        break;
      case ';':
        setChar(1,0,1,0,1,0);
        break;
      case '=':
        setChar(1,0,0,0,1);
        break;
      case '+':
        setChar(0,1,0,1,0);
        break;
      case '-':
        setChar(1,0,0,0,0,1);
        break;
      case '_':
        setChar(0,0,1,1,0,1);
        break;
      case '"':
        setChar(0,1,0,0,1,0);
        break;
      case '$':
        setChar(0,0,0,1,0,0,1);
        break;
      case '@':
        setChar(0,1,1,0,1,0);
        break;
      case 'ä':
        setChar(0,1,0,1);
        break;
      case 'á':
        setChar(0,1,1,0,1);
        break;
      case 'é':
        setChar(0,0,1,0,0);
        break;
      case 'ó':
      case 'ö':
      case 'ő':
        setChar(1,1,1,0);
        break;
      case 'ü':
      case 'ű':
        setChar(0,0,1,1);
        break;
      default:  //do nothing
        setChar();
        break;
      Serial.write(text[i]);
      character();  //output letter
      text[i] = 0;  //reset
    Serial.println("");
    newText = false;
void character(){
  for(byte i=0; i<9; i++){
    if(part[i] == 9) break;
    else if(part[i] == 4) morse(4);
    else{
      morse(part[i]);
      morse(2);
void morse(byte element){
  if(element == 0){  //dot
    digitalWrite(led, HIGH);
    tone(spk, Hz, 1000 / wpm);
    delay(1000 / wpm);
    digitalWrite(led, LOW);
  else if(element == 1){  //dash
    tone(spk, Hz, 3000 / wpm);
    delay(3000 / wpm);
  else if(element == 2){  //inter-element gap
    delay(1000 / wpm);
  else if(element == 3){  //short gap (between letters)
    delay(3000 / wpm);
  else if(element == 4){  //medium gap or space (between words)
    delay(7000 / wpm);
Pages: 1 [2]   Go Up
