Topic: How to connect LEDs to RX0/TX1 and still be able to flash? (Read 997 times) previous topic - next topic
acid
I've tried to connect 2 leds on Digital Pin0 and Digital Pin1. I know it's connected to UART RX/TX. After this connection I wasn't able to flash device - no response.
But there must be some way to isolate this LEDs from RX/TX pins during programming(except putting release buttons).
So I want to have LEDs on those pins (using all pins on Arduino UNO) and be able to program board.
Boffin1
What have you got connected to all the other pins ?   more leds?
Grumpy_Mike
The best way is to switch them out. That is physically disconnect them.
Alternatively you can use a buffer or a transistor to isolate them from the serial signals. They will then flash as you upload stuff but when the sketch starts running they will be fully controllable.
acid
Other LEDs, SPI. The number of pins are exactly matches to requirements if I only can isolate them and use flash device without disconnecting LEDs.
acid
Could you please give me some reference values of elements?
Boffin1
You can drive loads of LEDs from 3 pins with a shift register ....
Grumpy_Mike
You can't without isolating the LEDs from the serial input. As I said before you fdo this either electrically or mechanically.
