Pages: [1] 2 3   Go Down
Author Topic: Looking for some help in stopping this motorized potentiometer midway  (Read 1864 times)
Santa Cruz, CA
So I'm controlling this motorized linear pot: (https://www.sparkfun.com/products/10976)
via TI SN754410 H-Bridge.
I'm using TouchOSC (custom interface made thru TouchOSC editor) running through the oscP5 and serial libraries in Processing to communicate with the Arduino.
I've got the main objective down - https://www.youtube.com/watch?v=R4vXC0ugHZA&feature=plcp
What I'm looking for though more specifically is how to get the motor to stop midway based on it's position reading.
Any help's appreciated!
Here's the Arduino code I have so far:
//=====INITIALIZE PINS========
int switchPin = 7;    // switch input
int motor1APin = 6;    // H-bridge leg 1 (pin 2, 1A) PWM
int motor2APin = 5;    // H-bridge leg 2 (pin 7, 2A) PWM
int enablePin = 9;    // H-bridge enable pin
int lineTrack = 5;    //line track for position reading
int incomingByte;   // for incoming serial data
void setup(){
  Serial.begin(57600);
  // set the switch pin and line track as inputs:
  pinMode(switchPin, INPUT);
  pinMode(lineTrack, INPUT);
  //set the motor logic pins and enable pin as outputs
  pinMode(motor1APin, OUTPUT);
  pinMode(motor2APin, OUTPUT);
  pinMode(enablePin, OUTPUT);
  // set enablePin high so that motor can turn on:
  digitalWrite(enablePin, HIGH);
  if (Serial.available() > 0) {
    // read the incoming byte data from Processing:
    incomingByte = Serial.read();
    // say what you got:
    Serial.print("I received: ");
    Serial.println(incomingByte, DEC);
  //Move motor forward if truth is told
  if (incomingByte == 65) {
    motorForward();
  //Move motor forward if lie is told
  else if(incomingByte == 66) {
    motorBackward();
  else if(incomingByte == 67){
    //Obtain position reading
    int pos = analogRead(lineTrack);  //read the line positioning
    pos = map(pos, 0, 1023, 0, 110); //remap positioning to scale of 0-100
    //For proper readings, insert 2 to A5, 3 to 5V, 1 to GND
    if (pos >= 100) {
      motorBackward();
      motorStop();
    else if (pos <= 10) {
      motorForward();
      motorStop();
void motorForward(){
  analogWrite(motor1APin, 30);
  analogWrite(motor2APin, 150);
void motorBackward(){
  analogWrite(motor1APin, 150);
  analogWrite(motor2APin, 30);
void motorStop(){
    analogWrite(motor1APin, 255);
    analogWrite(motor2APin, 255);
Norfolk UK
The motorized potentiometer has 2x tapers. Wire one as normal to your audio or whatever and use the other as position feedback to the device controlling the motor. I did not read the datasheet but one taper may be a linear for feedback and the other taper logarithmic for audio.
Malaysia
dear bluesbud
i had been following your post since the very beginning. I am very much interested in your project. Okay I see that you need a 3 position application rite. i cant help up much with  TouchOSC but i can help you with the H-bridge and arduino part.
first of all if you don't already have a motor driver i would suggest you to look up on this 2 link i have for you
http://www.modularcircuits.com/blog/articles/old-h-bridge-secrets/part-1/
http://www.societyofrobots.com/member_tutorials/book/export/html/159
disclaimer: I am not in anyway associated with the author of both web page.
 now down to the programming part
Well if you comment is right then your program is wrong.
it should be
pos = map(pos, 0, 1023, 0, 100); //remap positioning to scale of 0-100
but how ever i would say that if you need any only 3 location
lets say I'm using 3 button and your slider which your slider have a motor controller and a linear potentiomenter as feedback.
let say in my set up,
1)if i press the first button, the motor will rotate clockwise and stop at the far end
2)if i press the second button, the motor will rotate anticlockwise and stop at the middle end if its at the far end or if its at the near end it will rotate clockwise and stop at the middle
3)if i press the third button, the motor will rotate anticlockwise and stop at the near end
this is only and example for you to see the logic behind this program, i hope you could translate it to your own setup.
if this is my setup i would like to put some kind of safety or interlock.
i would like that if any two or three button are push at the same time will not make it move.
and i would also like that unless the slider have reach it preset position it will not change its course.
i would also like to make the speed of the motor to be variable so that it is capable of a going to top speed but not overshooting.
in my physical connection from arduino to the motor controller, and the potentiometer
ok i will use a 2 pin motor controller using the circuit that is show in the webpage
to control the motor, one pin is set as Enable and this one need to be pwm, while the other pin will be the direction
Enable pin will be connected to pin 3 at Uno and pin 2 will be my direction.
if direction is High then motor turn clockwise and if direction is low then motor turn anticlockwise.
this i hypothetically speaking. The speed is control by the value of pwm on the enable, the higher the pwm then the higher the speed.
for the pot i will connect the middle leg to port A0 and the other two to ground and 5 volt respectively
for the buttons, i will hook it to pin 4,5,and 6. For the purpose of this example please consider that this button all have an external circuit that have take care the debounce or this button is a perfect button that does not need to be debounce. I then also put a resistor to the ground and one of the leg of the button, and this middle position is put to the pin. This setup is call as a pull down resistor, or just pulling the pot value down to ground
Okay now for the pseudo code,
read the value from pot,
read value of button one,button two, and button three,
if value of button one high and button two and three are low then motor rotate clockwise until pot full
if value of button two high, button one and three are low and pot higher then middle value then motor rotate anticlockwise until pot middle value
if value of button two high, button one and three are low and pot lower then middle value then motor rotate clockwise until pot middle value
if button three high and button one and two are low then motor rotate anticlockwise until pot 0
if motor rotate, button value for one, two and three is low
for real code that arduino will understand
int Pot           =   A0;
int Button1       =    4;
int Button2       =    5;
int Button3       =    6;
int Direction     =    2;
int Enable        =    3;
int Clockwise     = HIGH;
int Anticlockwise =  LOW;
int Stop          =  LOW;
int potval              ;
  pinMode (Pot,INPUT);
  pinMode (Button1,INPUT);
  pinMode (Button2,INPUT);
  pinMode (Button3,INPUT);
  pinMode (Direction,OUTPUT);
  pinMode (Enable,OUTPUT);
 int PotVal = analogRead(Pot);
 int Btn1    = digitalRead(Button1);
 int Btn2    = digitalRead(Button2);
 int Btn3    = digitalRead(Button3);
 if (Btn1 == HIGH && Btn2 ==LOW && Btn3 ==LOW)
   int Speed = map (PotVal,PotVal,1023,255,0);
   do
     analogWrite (Enable,Speed);
     digitalWrite (Direction, Clockwise);
     potval = analogRead(Pot);
   while (potval <= 1023);
   if (potval == 1023)
    digitalWrite (Enable,Stop);
 if (Btn2 ==HIGH && Btn1 ==LOW && Btn3 == LOW && PotVal >512)
  int Speed = map (PotVal,PotVal,512,255,0);
  do
    digitalWrite(Direction,Anticlockwise);
  while (potval > 511);
  if (potval == 512)
 if (Btn2 ==HIGH && Btn1 ==LOW && Btn3 == LOW && PotVal < 512)
  do
    digitalWrite(Direction,Clockwise);
  while (potval < 513);
  if (potval == 512)
    digitalWrite (Enable,LOW);
 if (Btn3 == HIGH && Btn1 ==LOW && Btn2 ==LOW)
   int Speed = map (PotVal,PotVal,0,255,0);
   do
     digitalWrite (Direction,Anticlockwise);
   while (potval >=0);
   if (potval == 0)
I hope you could understand my code bluesbud, this code however just as an example of what you could do.
I hope someone could verify my code,
Santa Cruz, CA
Thanks for following, I'll be checking this in a bit later this afternoon.
As for the remapping code
I actually did that on purpose because it was the readings I was getting were a bit under. 100% on the far end read 90, so I just added 10.
Santa Cruz, CA
Hey, this looks great and is really helpful. I'm just a bit confused about the buttons, considering my buttons are on a TouchOSC interface and don't necessarily have a HIGH or LOW state. I just have serial communication coming in.
Malaysia
the code i did is just an example of what you could do, if you have 3 different button. lets say in a Serial communication situation. just use if like if serial read == 1 (meaning the button one) then Button 1 = high. i hope this make sense to you
Santa Cruz, CA
Ah, yeah, that makes sense. Thanks!
Santa Cruz, CA
Hrrrmm, something's gone awry. See attached zip file.
I have a feeling it has to do with the position of enablePin, where I analogRead the potVal in the do function or how I'm calling previous & new states.
Malaysia
what software are you using. i cant read any of your file.
Santa Cruz, CA
I'm using Arduino...though I have had Processing and Arduino sketches open in each other's platform. Have you checked default program that opens it?
Santa Cruz, CA
Any luck getting them open? I'll see what's up.
Santa Cruz, CA
Yeah, they should open just fine.
Here's the code. I've split them up in tabs to keep it a bit organized (thus the zip).
So, I figure it might be best to give you context so you're not confused. I have two puppets, Obama and Romney, with this motor as a Pinocchio nose that moves forward or backwards based on the truthfulness of a selected statement. The statements are selected via TouchOSC on an iPad.
I've attached my processing code below this one.
//For proper lineTrack readings, insert 2 to A5, 3 to 5V, 1 to GND
int potVal;
int prevState;
void setup(){
  readSerial();
  //Cases are named by previous state, followed by new state
  lieTruth();
  truthLie();
  truthHalf();
  lieHalf();
  halfTruth();
  halfLie();
//If previous state was lie and new state is a truth, move backwards all the way
void lieTruth (){
  if (prevState == 2 && incomingByte == 65){
    //    //Obtain position reading
    //    int potVal = analogRead(lineTrack);  //read the line positioning
    //    int Speed = map (potVal,potVal,0,255,0);  //Map from 1023-0, HIGH-LOW
    do
      //      analogWrite (enablePin, Speed);
      motorBackward();
    while (analogRead(lineTrack) >= 0);
    if (potVal == 0){
      motorStop();
//If previous state was truth and new state is a lie, move forward all the way
void truthLie(){
  if (prevState == 1 && incomingByte == 66){
    //    int Speed = map (potVal,potVal,1023,255,0);    //Map from 0-1023, HIGH-LOW
    do
      motorForward();
    while (analogRead(lineTrack) <= 1023);
    if (potVal == 1023){
      motorStop();
//If prevState was truth and new state half truth. Go forwards halfway
void truthHalf(){
  if (prevState == 1 && incomingByte == 67){
    //    int Speed = map (potVal,potVal,512,255,0);  //Map from 0-512, HIGH-LOW
    do
      motorForward();
    while (analogRead(lineTrack) >= 513);
    if (potVal == 512){
      motorStop();
//If prevState was lie and new state half truth. Go backwards halfway
void lieHalf(){
  if (prevState == 2 && incomingByte == 67){
    //    int Speed = map (potVal,potVal,512,255,0);  //Map from 1023-512 to HIGH-LOW
    do
      motorBackward();
    while (analogRead(lineTrack) >= 511);
    if (potVal == 512){
      motorStop();
//If prevState was half-truth and new state truth. Go backwards halfway
void halfTruth(){
  if (prevState == 3 && incomingByte == 65){
    //    int Speed = map (potVal,potVal,0,255,0);    //Map from 512-0, HIGH-LOW
    do
      motorBackward();
    while (analogRead(lineTrack) <= 513);
    if (potVal == 0){
      motorStop();
//If prevState was half-truth and new state lie. Go forwards halfway
void halfLie(){
  if (prevState == 3 && incomingByte == 66){
    //    int Speed = map (potVal,potVal,1023,255,0);    //Map from 512-1023, HIGH-LOW
    do
      motorForward();
      motorStop();
  analogWrite(motor2APin, 160);
  analogWrite(motor1APin, 160);
void motorStop(){
void readSerial(){
  int prevState;
  //Allow previous states to be stored here in prevState
  // 1 = truth
  // 2 = lie
  // 3 = half-truth
  //Store data as previous states
  if (incomingByte == 65) {   //Truth
    prevState = 1;
  else if(incomingByte == 66) {  //Lie
    prevState = 2;
  else if(incomingByte == 67) {  //Half-truth
    prevState = 3;
Processing code:
//libraries needed for arduino communication
import processing.serial.*;
//libraries needed for osc
import oscP5.*;
import netP5.*;
Serial arduinoPort;        //  Set arduinoPort as serial connection
OscP5 oscP5;
NetAddress myRemoteLocation;
//set/change port numbers here
int incomingPort = 8000;
int outgoingPort = 9000;
//set/change the IP address that the OSC data is being sent to
//127.0.0.1 is the local address (for sending osc to an application on the same computer)
String ipAddress = "127.0.0.1";
int truthVal;  //truthValue
  size(100, 100);
  background(0);
  frameRate(25);
  /* start oscP5, listening for incoming messages at port 8000 */
  //for INCOMING osc messages (e.g. from Max/MSP)
  oscP5 = new OscP5(this, incomingPort); //port number set above
  arduinoPort = new Serial(this, Serial.list()[4], 57600);  //port 4 is Arduino to USB
// Incoming osc message are forwarded to the following oscEvent method. Write to the arduino here--------
// This method is called for each OSC message recieved
void oscEvent(OscMessage theOscMessage)
  println("### received an osc message.");
  println("addrpattern: "+theOscMessage.addrPattern());
  //Convert the OSC address pattern to a string
  String addr = theOscMessage.addrPattern();
  if (addr.equals("/o/truth") == true) //if the osc message reads obama truth
    truthVal = 0;    //Set truthVal to 0
  else if (addr.equals("/o/lie") == true) //if the osc message reads obama lie
    truthVal = 1;  //Set truthVal to 1
  else if (addr.equals("/o/halfTruth") == true)
    truthVal = 2;
void draw()
  //write serial data to for the Arduino to read
  if (truthVal == 0) //if the osc message reads obama truth
    arduinoPort.write(65);
    println("Obama Truth");
  else if (truthVal == 1) //if the osc message reads obama truth
    arduinoPort.write(66);
    println("Obama Lie");
  else if (truthVal == 2) //if the osc message reads obama truth
    arduinoPort.write(67);
    println("Obama Half-Truth");
Malaysia
hello there, sorry i cant even open any of your zip file, maybe its my computer.
the 5 need to change to A5. anyway i got an idea, to reduce the programming in arduino part.
lets see maybe in the processing part you could send a serial data maybe A,B and C
if A receive the motor will move to position 0
if B receive the motor will move to position 1
if C receive the motor will move to position 2
and the list could expend as you seem fit.
now in arduino
lets say if arduino receive an A= 0
then it will move to position to where the pot is 0
let say if arduino receive a B = 512
then it will move to position to where the pot is 512
lets say if arduino receive a c = 1023
then it will move to position to where the pot is 1023
lets try to program the arduino
const int Pot     = A0;  //Set the Linear Pot middle pin to Arduino A0 port
const int Enable =  2;  //Set the Motor controller pin on pin 2 Arduino
const int A1      =  3;  //Set the Motor Controller pin A1 to port 3;
const int A2      =  4;  //Set the Motor Controller pin A2 to port 4;
int Target        =  0;  //Target is the position we want the motor to move to
int Speed         =  0;  //Speed Control for motor
 pinMode (Pot,INPUT);          //Set Pot as Input
 pinMode (Enable,OUTPUT);  //Set Enable as Output
 pinMode (A1,OUTPUT);       //Set A1 as Output
 pinMode (A2,OUTPUT);       //Set A2 as Output
 Serial.begin(9600);             //Initialize Serial Communication at 9600 baud rate
    int inByte = Serial.read();
    switch (inByte)
     case 'A':
                MoveMotor(0);
                break;
     case 'B':
                MoveMotor(512);
                break;
     case 'C':
                MoveMotor(1023);
                break;
     default:
void MoveMotor(Target)
  int PotVal =AnalogRead (Pot);
  if (PotVal > Target)
   Speed = map (PotVal,Target,PotVal,0,255);
   analogWrite (Enable, Speed);
   digitalWrite (A1, HIGH);
   digitalWrite (A2,LOW);
  if (PotVal < Target)
   Speed = map (PotVal,PotVal,Target,0,255);
   digitalWrite (A1, LOW);
   digitalWrite (A2,HIGH);
  digitalWrite (Enable,HIGH);
  digitalWrite (A2, LOW);
  return;
ok. please try the program with your serial sending only A B or C no need to change to ASCII value. this way if you increase the number of stop position you dont have to change the program instead just add more stop along the way.
Malaysia
sorry the program i gave b4 will not compile. use this one instead
const int  pin1A      =  3;  //Set the Motor Controller pin A1 to port 3;
const int pin2A      =  4;  //Set the Motor Controller pin A2 to port 4;
    switch (inByte)
     case 'A':
                MoveMotor(0);
                break;
     case 'B':
                MoveMotor(512);
                break;
     case 'C':
                MoveMotor(1023);
                break;
     default:
                MotorStop();
                break;
void MoveMotor(int Target)
  int PotVal =analogRead (Pot);
   digitalWrite (pin1A, HIGH);
   digitalWrite (pin2A,LOW);
   digitalWrite (pin1A, LOW);
   digitalWrite (pin2A,HIGH);
  digitalWrite (pin2A, LOW);
  return;
void MotorStop()
  return;
Santa Cruz, CA
Hrmm, no luck :/
Pages: [1] 2 3   Go Up
