Loading...
Pages: 1 [2]   Go Down
Author Topic: hold last sensor value  (Read 599 times)
berlin
Offline Offline
Full Member
fubbi.com
View Profile
Quote
I don't really understand what you are doing.
Me neither, hence my posting in the forum "programming questions"  smiley
Quote
Code:
    posVal = tempVal;
    posVal = map(posVal, 1023, 1, 127, 0); // make midi notes
    posVal = constrain(posVal, 0, 127); // constrain it
Why? You never use posVal anywhere else.
Its a remain from previous iterations. Does it matter?
Quote
If tempVal is not 0, how can it be anything other than not 0? The 2nd if statement should be an else.
This what always confuses me. the logic of if's and else's. I cant figure it out smiley-sad
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
If it doesn't do anything useful, delete it. It doesn't hurt anything, but it takes time to compile every time, it takes time to upload every time, and it takes up space every time.
Quote
Else is used when there is something to do if the if statement is false.
If the switch pin is HIGH, turn the LED on. Else, turn it off. The pin can only be HIGH or LOW. There is no possibility of HALFWAYHIGH or NOTQUITELOW.
In the other hand, the values from an analog pin might fall into ranges that you want to treat as LOW, NOTQUITELOW, HALFWAYHIGH, and HIGH
Code:
int val = analogRead(somePin);
if(val <= 250)
else if(val <= 500)
else if(val <- 750)
Here, once an if (or else if) evaluates to true, and a block is executed, the rest of the else ifs are skipped, as is the else. If none of the if (or else if) statements are true, the else block will be executed.
Logged
berlin
Offline Offline
Full Member
fubbi.com
View Profile
I am trying the else I can still not dynamically update the value without releasing.
exactly the same as before
Code:
#include <MIDI.h>
#define LED 13
int sensorPin = A0;
int tempVal = 0;
int led = 13;
int note = 0;
int scale[] = {
  60,62,64,65,67,69,71};
  pinMode(LED, OUTPUT);
  MIDI.begin();
void loop(){
  tempVal = analogRead(sensorPin);
  if(tempVal == 0) {
    MIDI.sendControlChange(123,0,1); // OMNI NOTE OFF MSG
    digitalWrite(led, LOW);
  else if (tempVal > 1) {
    note = map(tempVal, 1023, 1, 6, 0);
    note = constrain(note, 0, 6);
    MIDI.sendNoteOn(scale[note],127,1);
    digitalWrite(led, HIGH);
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
You need a Serial.begin(115200); in setup() and some Serial.print() statements in loop. What value are you reading from the sensor each time? It is possible that you are not getting the clean 0 that you think you are.
What value is ending up in note?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
I suspect that you are flooding the MIDI device with lots of note on messages and only on release you have a note off.
You need to see if the value has changed even though it is not gone down to zero. Then turn the old note off and the new note on.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
