Pages: [1] 2 3 4   Go Down
Author Topic: 16x2 lcd with UnoR3 probs  (Read 2855 times)
Hi!
It seems I got the famous problem with the lcd. The letters wont appear.
Its a 16x2 blue lcd.
Have checked the cables over and over again and I find it correct.
The LCD starts and the backlight shows, but not the letters.
Sometimes the white boxes flashes a millisec or so, then disappears.
Im followed the Hello world guide wich comes with the arduino.
I got the 10K potentiometer. And I have tried with and without it, same result.
I also cant change the contrast with the potentiometer coupled on. Ive
checked the outputvoltage on it,and it works!
Anybody that got an idea? Can link a video if someone want a look.
Western New York, USA
I have heard that before.
Are you using a current limiting resistor with your backlight?
You must use the potentiometer and you must get the contrast working before you proceed any further.
If you can't get a row of boxes to appear then you are wasting your time trying to display any text.
Ive checked the outputvoltage on it,and it works!
Explain what voltage(s) you measured and why you think it works.  When it really works you will be able to see a row of boxes on the screen.
We really can't give more help without more information.
Don
You do some programming to solve a problem, and some to solve it in a particular language. (CC2)
Like code and schematics.
Central MN, USA
Video would be fine as long as its quality is high enough to tell how the connection is made.
When I checked the potentiometer,I used a voltmeter and looked at the output voltage when the arduino was running and only coupled in the voltage from the arduino.I think the potentiometer works because it gives diffrent voltage to the LCD. It also changes the contrast a liiiiiitle liiiitle bit.
Little bit hard to see it in the video tho.
Here is the video: https://vimeo.com/54703995
Here is a clearly pic of how I wired everything, and a pic I got from the manual to compare with.
http://tinypic.com/view.php?pic=2ldubtt&s=6
Here is a video showing how the white boxes flashes when I turned the potentiometer with everything wired:
https://vimeo.com/54704282
Here is the manual for the LCD from the manufactor:
http://www.kjell.com/.mvc/Document/File?id=b6e33422-63ff-48be-b140-a04a0114d7ef
And here is the code I was runnning with everyting coupled in the pic:
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
  lcd.begin(16, 2);
  lcd.print("hello, world!");
  lcd.setCursor(0, 1);
  lcd.print(millis()/1000);
I've tested you sketch on my lcd+keypad shield and it worked perfectly. I just had to change the pin numbers because the lcd on my shield is wired differently than you test setup.
So I think there must be something wrong with your connections...
Why wouldn't it work?  It's the 'Hello World' example sketch that comes with the IDE.
Don
Here is the video...
You don't have to even run the first video to see the first (and possibly the only) problem.
You must solder the connections to your LCD module.  A row of header pins (or very short stiff wires) would be the best choice, then you can plug the module directly into the breadboard.
Don
alabama
Since I can't see any solder that usually runs through the holes along with the wires that connect to your LCD, I'm going with not soldered wires or at least a cold solder joint.
TomJ
Einstein once said you don't really understand anything until you can explain it to your Grandmother
Here is a clearly pic of how I wired everything...
Look in the lower left box in the 'Description of Terminals' and you will see that the backlight must be supplied with no more than 4.5 Volts.
This means that you must use a series resistor to drop the voltage and at the same time limit the current through tbe LED backlight.
Don
You should be able to vary the voltage at pin 3 from 0 to 5 Volts (with respect to pin 1).  The display should be blank at +5 Volts and you should have a single solid row of blocks at 0 Volts.  The proper setting, which will still show the blocks, will be around 0.4 Volts for your LCD.
Don
Don
I've recently tested to connect the backlight to the 3v pin on the arduino instead. But its the same. (Ive solder the wires on the backside of the LCD)
Could I have destoyed the backlight when I wired it to the +5V?
Will buy the headers tomorrow and solder it.
Dallas, TX USA
Don, Dr,
I think I now understand a potential reason why we are seeing so many newbies not soldering
their connections to the LCD.
It is the Arduino Tutorial:
http://arduino.cc/en/Tutorial/LiquidCrystal
Nowhere in there does it ever mention needing to solder the connections
to the LCD module.
It shows them soldered in the photo, but it never says it in the text/instructions.
In fact it doesn't even list solder in the h/w requirements.
Ignoring the obvious typo of "LED" vs "LCD" this is really the only instructions:
To wire your LED screen to your Arduino, connect the following pins
And then a fritzing diagram below.
So the issue is that users can follow the tutorial to the letter and have everything
"wired" correctly and end up with a non working or even semi working LCD because the tutorial fails
to mention the requirement of soldering the connections to the LCD.
Unfortunately trying to get the Arduino team to change anything is worse
than pulling teeth. But clearly this needs to get updated.
I opened issues
https://github.com/arduino/Arduino/issues/1149
http://code.google.com/p/arduino/issues/detail?id=1116
Note: It appears that github is now being used for issues but I wen't ahead
and put it on the google code page as well.
--- bill
Regardless of how you power an LED you still need some way to limit the current and this almost always involves the use of a resistor.
Depending upon the LED configuration in the backlight circuit the 3 V supply may not provide enough voltage and/or current to work properly.
You should power the backlight from a 5 Volt supply using a resistor in between the supply and one of the backlight pins.  Unfortunately your data sheet does not supply enough information to determine the required resistance so you will have to experiment.  I would start out with about 150 ohms and see if the voltage across the LED is then within specifications and if the backlight is sufficiently bright.
You didn't help it or the Arduino power supply at all, but you probably didn't destroy either of them (yet) either.
Don
Unfortunately trying to get the Arduino team to change anything is worse than pulling teeth. But clearly this needs to get updated.
That is the understatement of the year.
It appears that github is now being used for issues but I wen't ahead and put it on the google code page as well.
This doesn't help the fact that most beginners rely on the 'official' Arduino pages as gospel truth and mere mortals cannot correct those pages even when they are blatantly incorrect, incomplete, or obsolete.
Don
« Last Edit: December 02, 2012, 12:10:36 pm by floresta » Logged
Pages: [1] 2 3 4   Go Up
