Topic: 4 Pin RGB LED Flickering Flame effect, help! (Read 3774 times) previous topic - next topic
sg92
Hey guys this is my first post on here (go easy), I'm trying to make a flickering LED effect using a 4pin LED, I know normal LED flame tutorials have been done to death but I can't seem to find one for 4pins, I'm using these ones because in my experience theyre a lot brighter. So! Out of curiosity I tried this code with the LED, it works in terms of flickering, but it goes all different colours as opposed to going traditional red/yellow. I've got another 2 of these LED's if its a case of setting them individually to a colour then getting them to flicker. Can anyone point me in the right direction? Any help is appreciated!  Thanks
int ledPin1 = 10;
int ledPin2 = 9;
int ledPin3 = 11;
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
analogWrite(ledPin1, random(120)+135);
analogWrite(ledPin2, random(120)+135);
analogWrite(ledPin3, random(120)+135);
delay(random(100));
johnwasser
To keep the light in the Red/Orange/Yellow range you probably want to make sure that the Green and Blue components are the same intensity:
int ledPinRed = 10;
int ledPinGreen = 9;
int ledPinBlue = 11;
pinMode(ledPinRed, OUTPUT);
pinMode(ledPinGreen, OUTPUT);
pinMode(ledPinBlue, OUTPUT);
int Red = random(120)+135;
int Yellow = random(120)+135;
analogWrite(ledPinRed, Red);
analogWrite(ledPinGreen, Yellow);
analogWrite(ledPinBlue, Yellow);
delay(random(100));
dc42
Unfortunately, green and blue do not mix to give yellow, that gives cyan. You need to mix red and green to get yellow. Try selecting a random red level, then a random green level that is no greater than the red level you picked. Either don't use blue at all, or use a random blue level that is no greater than the green level you picked.
Grumpy_Mike
I would not flash the blue one at all and limit the range of the green LED to keep all he colours flame like.
sg92
Ah thanks so much guys! The code johnwasser gave worked a treat! It now flickers red/yellow  :)
