« on: December 01, 2012, 08:51:10 pm » |
Hello, I'm just starting out with this hobby and have tried to familiarize myself with the examples and the forum, but my programming skills are very green. I have a question regarding using a momentary switch to turn on an LED for a specified time using the "blinkwithoutdelay" method. I have an Arduino Uno set up with a momentary switch and resistor connected as an input to pin 6 and an LED and resistor connected as an output through a transistor (just wanted to learn how that worked) to pin 3. What I was attempting from the code below was that upon pressing the momentary switch the LED would turn on for 5 seconds and then turn off. What is actually happening is that the LED will blink on and off. Once I've pressed the button and the LED has blinked I can press the button again with no blink. I then have to wait approximately five seconds until a button press will trigger a blink. I've also noticed that if I press and hold the momentary switch what I get is a blink then approximately a 5 second wait and then another blink. May be coincidental? I've tried many different variations with if, if/else, and while, but I'm stumped. Any help would be appreciated! /* Turns on an LED for 5 seconds when a momentary pushbutton is pressed. The circuit: *pin 3 connected to LED through transistor *pin 6 connected to pushbutton/resistor */
const int buttonPin = 6; //the number of the pushbutton pin const int LEDPin = 3; //the number of the alarm pin int buttonState; //variable for the pushbutton status unsigned long ontime = 5000; //variable for the alarm on-time unsigned long currentMillis; long previousMillis = 0;
void setup() { pinMode(LEDPin, OUTPUT); //initialize the LED pin as an output pinMode(buttonPin, INPUT); //initialize the pushbutton pin as an input Serial.begin(9600); //initialize serial communication for debugging }
void loop() { buttonState = digitalRead(buttonPin); //check if the pushbutton is pressed Serial.println(buttonState); //print pushbutton condition to serial monitor currentMillis = millis(); if (buttonState == HIGH) { //if pushbutton has been pressed: if (currentMillis - previousMillis > ontime) { //check if difference between current time digitalWrite(LEDPin, HIGH); //and previous time is larger than the alarm time previousMillis = currentMillis; } } digitalWrite(LEDPin, LOW); //turn LED off } Eventually I would like to add an on/off switch that could be used to arm/disarm the system and also turn off the LED prior to the 5 second time limit if desired, but we must crawl before we walk. If anyone knows of any examples of how to do this (or something similar to this) I would gladly welcome a link.
« Last Edit: December 01, 2012, 08:53:12 pm by grim »
Seattle, WA USA
Seattle, WA USA
« Reply #1 on: December 01, 2012, 09:04:14 pm » |
pinMode(buttonPin, INPUT); //initialize the pushbutton pin as an input But, you don't enable the pullup resistor. So, you have an external resistor, right? How is the switch wired? buttonState = digitalRead(buttonPin); //check if the pushbutton is pressed Serial.println(buttonState); //print pushbutton condition to serial monitor currentMillis = millis(); if (buttonState == HIGH) { //if pushbutton has been pressed: if (currentMillis - previousMillis > ontime) { //check if difference between current time digitalWrite(LEDPin, HIGH); //and previous time is larger than the alarm time previousMillis = currentMillis; } } digitalWrite(LEDPin, LOW); //turn LED off
Apparently, you didn't fully understand the blink without delay example. If the switch is HIGH (or LOW if you wire the switch the easy way), turn the LED and and set a variable (with a meaningful name, like startTime; currentMillis is not such a name). Then, periodically see if the LED is still on (startTime is not zero) and enough time has passed (now - startTime is greater than the on time you want), turn the LED off and set startTime to 0.
« Reply #2 on: December 01, 2012, 09:14:52 pm » |
This results in turning the LED off immediately after turning it on: buttonState = digitalRead(buttonPin); //check if the pushbutton is pressed Serial.println(buttonState); //print pushbutton condition to serial monitor currentMillis = millis(); if (buttonState == HIGH) { //if pushbutton has been pressed: if (currentMillis - previousMillis > ontime) { //check if difference between current time digitalWrite(LEDPin, HIGH); //and previous time is larger than the alarm time previousMillis = currentMillis; } } digitalWrite(LEDPin, LOW); //turn LED off
Note that you say "if button is high, set led pin high;" followed by "always set led pin low". That "always" part (digitalWrite(LEDPin, LOW)) happens on every single loop. Consider the following instead: unsigned int debounceTime = 100; unsigned long onTime = 5000;
static bool ledOn = false; static unsigned long buttonTm = 0; static unsigned long ledTm = 0;
// always debounce your inputs, but debouncing uses a different time counter // than your LED on, necessarily, as you want to be able to press the button // more than once every on period
if( digitalRead(buttonPin) == HIGH && millis() - buttonTm > debounceTime ) {
buttonTm = millis();
if( ledOn ) { // LED is already on, turn it off digitalWrite(LEDPin, LOW); ledOn = false; } else { // LED is not on, turn it on digitalWrite(LEDPin, HIGH); ledOn = true; ledTm = millis(); } }
if( ledOn == true && millis() - ledTm >= onTime ) { // LED has been on long enough to turn off automatically digitalWrite(LEDPin, LOW); ledOn = false; } }
Hope that helps.
Seattle, WA USA
Seattle, WA USA
« Reply #3 on: December 01, 2012, 09:28:02 pm » |
if( ledOn ) { // LED is already on, turn it off digitalWrite(LEDPin, LOW); ledOn = false; } else { // LED is not on, turn it on digitalWrite(LEDPin, HIGH); ledOn = true; ledTm = millis(); } @drone I have a problem with this code. The ledOn variable should, in my opinion, be of type int, and it should be assigned/compared to HIGH and LOW. Why? Because then you can do: ledOn = HIGH; digitalWrite(LEDPin, lodOn); This assures that the state of the LED and the value of ledOn never get out of sync. I know that you think it won't happen, but it does. A month later, you make a change to the digitalWrite statement and forget to change the following statement, and you spend a long time trying to figure out what went wrong with such a simple change.
« Reply #4 on: December 01, 2012, 09:31:13 pm » |
Easy:
1) at the time you trigger that output, start a timer to count time. 2) in the timer isr, compare elapsed time vs. desired time. 3) when the desired time has elapsed, turn off the output.
Seattle, WA USA
Seattle, WA USA
« Reply #5 on: December 01, 2012, 09:43:09 pm » |
1) at the time you trigger that output, start a timer to count time. That is hardly easier than calling millis(). 2) in the timer isr, compare elapsed time vs. desired time. So, now you need another function, instead of the same simple if statement in loop(). 3) when the desired time has elapsed, turn off the output. Which, of course, you could do in loop() with sacrificing a timer.
« Reply #6 on: December 01, 2012, 09:59:24 pm » |
ledOn = HIGH; digitalWrite(LEDPin, lodOn); This assures that the state of the LED and the value of ledOn never get out of sync. I know that you think it won't happen, but it does. A month later, you make a change to the digitalWrite statement and forget to change the following statement, and you spend a long time trying to figure out what went wrong with such a simple change. Stranger things have happened! A good point. In general, I would isolate the LED code out of the loop too, unless I didn't expect that I'd do much more in my sketch. I hate seeing long loop/main functions.
« Reply #7 on: December 02, 2012, 08:40:55 am » |
This is something that I would do: unsigned long _timer1_period=0; //timer period, in seconds unsigned long _timer1_counter=0; //timer1 counter //timer1 isr ISR(TIMER1_OVF_vect) { _timer1_counter+=0x10000ul; //increment timer_counter if (_timer1_counter >=F_CPU) { _timer1_counter -= F_CPU; //reset timer_counter _timer1_period -= 1; //decrement duration_sec if (!_timer1_period) { //elapsed time has been reached //turn off the led digitalWrite(LEDPin, LOW); TIMSK1 &=~(1<<TOIE1); //turn off timer1 interrupt } } }
//initialize the timer //to expire in user-specified period of time void tmr1_init(unsigned long duration_sec) { _timer1_counter = 0; //reset timer1 counter _timer1_period=duration_sec; //set timer period TCCR1B = 0x00; //turn off the timer TCCR1A = 0x00; //normal portion operation TCNT1 = 0; //reset the timer TIFR1 |= (1<<TOV1); //clear the timer flag TCCR1B = 0x01; //turn on the timer, 1:1 prescaler TIMSK1 |= (1<<TOIE1); //enable the timer interrupt sei(); //enable global interrupt }
The isr keeps track of time elapsed and at the end, turns itself off. The other routine just initialize the timer. Once it is set, it goes on by itself. Here would be your user code: if (buttonState==HIGH) { digitalWrite(LEDPin, HIGH); //turn on the led pin tmr1_init(5); //initialize the timer to elapse in 5 seconds }
As the routines are set-and-forget type, your user code is greatly simplified: all it does is to set up the timer and then it moves on.
UK
« Reply #8 on: December 02, 2012, 11:42:18 am » |
Maybe that's what you'd do, but IMO using a hardware timer for such a simple problem is overkill, excessively complex and unscalable. The 'blink without delay' shows how to implement this sort of thing in a very simple and scalable way that also fits in well with handling other events asynchronously.
