[SOLVED]
There were 3 problems working against us.
1) src/ASF/sam\boards/arduino_due_x/arduino_due_x.h
* Un-define USB_ID_GPIO and remove any references to it to force host mode.
2) src/ASF/sam/drivers/pmc/sleep.c
* pmc_save_clock_settings() and pmc_restore_clock_settings() don't work properly in ASF 3.7.2. These functions were re-worked with code from ASF 3.5.
3) src/ui.c
* ui_usb_sof_event()
* Reads a push button that doesn't exist on a stock board.
* This creates a scenario where the device will not work the first time it's plugged or if it is already connected when the application starts.
Download my re-worked version here:
http://usb-travis.googlecode.com/files/ARDUINO_DUE_USB_HOST_HIDMSC.zipNOTE: When you create a new project with ASF 3.7.2, use sleep.c from the code above. Hopefully Atmel will fix the bugs in the next ASF release.
sleep.c
* \file
* \brief Sleep mode access
* Copyright (c) 2013 Atmel Corporation. All rights reserved.
* \asf_license_start
* \page License
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. The name of Atmel may not be used to endorse or promote products derived
* from this software without specific prior written permission.
* 4. This software may only be redistributed and used in connection with an
* Atmel microcontroller product.
* THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR IMPLIED
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
* EXPRESSLY AND SPECIFICALLY DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
* STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
* ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
* \asf_license_stop
/* [TR]
* in ASF 3.7.2. These functions were re-worked with code from ASF 3.5.
#include <compiler.h>
#include "sleep.h"
/* SAM3 and SAM4 series */
#if (SAM3S || SAM3N || SAM3XA || SAM3U || SAM4S || SAM4E)
# include "pmc.h"
# include "board.h"
* Save clock settings and shutdown PLLs
__always_inline static void pmc_save_clock_settings(
uint32_t *p_osc_setting,
uint32_t *p_pll0_setting,
uint32_t *p_pll1_setting,
uint32_t *p_mck_setting)
if (p_osc_setting) {
*p_osc_setting = PMC->CKGR_MOR;
if (p_pll0_setting) {
*p_pll0_setting = PMC->CKGR_PLLAR;
if (p_pll1_setting) {
#if (SAM3S || SAM4S)
*p_pll1_setting = PMC->CKGR_PLLBR;
#elif (SAM3U || SAM3XA)
*p_pll1_setting = PMC->CKGR_UCKR;
#else
*p_pll1_setting = 0;
#endif
if (p_mck_setting) {
*p_mck_setting = PMC->PMC_MCKR;
// Switch MCK to Main clock (internal or external 12MHz) for fast wakeup
// If MAIN_CLK is already the source, just skip
if ((PMC->PMC_MCKR & PMC_MCKR_CSS_Msk) == PMC_MCKR_CSS_MAIN_CLK) {
return;
// If we have to enable the MAIN_CLK
if ((PMC->PMC_SR & PMC_SR_MOSCXTS) == 0) {
// Intend to use internal RC as source of MAIN_CLK
pmc_osc_enable_fastrc(CKGR_MOR_MOSCRCF_12_MHz);
pmc_switch_mainck_to_fastrc(CKGR_MOR_MOSCRCF_12_MHz);
pmc_switch_mck_to_mainck(PMC_MCKR_PRES_CLK_1);
* Restore clock settings
__always_inline static void pmc_restore_clock_setting(
uint32_t osc_setting,
uint32_t pll0_setting,
uint32_t pll1_setting,
uint32_t mck_setting)
uint32_t mckr;
if ((pll0_setting & CKGR_PLLAR_MULA_Msk) &&
pll0_setting != PMC->CKGR_PLLAR) {
PMC->CKGR_PLLAR = 0;
PMC->CKGR_PLLAR = CKGR_PLLAR_ONE | pll0_setting;
while (!(PMC->PMC_SR & PMC_SR_LOCKA));
if ((pll1_setting & CKGR_PLLBR_MULB_Msk) &&
pll1_setting != PMC->CKGR_PLLBR) {
PMC->CKGR_PLLBR = 0;
PMC->CKGR_PLLBR = pll1_setting ;
while (!(PMC->PMC_SR & PMC_SR_LOCKB));
if ((pll1_setting & CKGR_UCKR_UPLLEN) &&
pll1_setting != PMC->CKGR_UCKR) {
PMC->CKGR_UCKR = 0;
PMC->CKGR_UCKR = pll1_setting;
while (!(PMC->PMC_SR & PMC_SR_LOCKU));
#else
UNUSED(pll1_setting);
#endif
/* Switch to faster clock */
mckr = PMC->PMC_MCKR;
// Set PRES
PMC->PMC_MCKR = (mckr & ~PMC_MCKR_PRES_Msk)
| (mck_setting & PMC_MCKR_PRES_Msk);
while (!(PMC->PMC_SR & PMC_SR_MCKRDY));
// Set CSS and others
PMC->PMC_MCKR = mck_setting;
/* Shutdown fastrc */
if (0 == (osc_setting & CKGR_MOR_MOSCRCEN)) {
pmc_osc_disable_fastrc();
/** If clocks are switched to FASTRC for WAIT mode */
static volatile bool b_is_fastrc_used = false;
void pmc_sleep(int sleep_mode)
switch (sleep_mode) {
case SAM_PM_SMODE_SLEEP_WFI:
case SAM_PM_SMODE_SLEEP_WFE:
#if (SAM4S || SAM4E)
SCB->SCR &= (uint32_t)~SCR_SLEEPDEEP;
cpu_irq_enable();
__WFI();
break;
#else
PMC->PMC_FSMR &= (uint32_t)~PMC_FSMR_LPM;
cpu_irq_enable();
if (sleep_mode == SAM_PM_SMODE_SLEEP_WFI)
__WFI();
__WFE();
break;
#endif
case SAM_PM_SMODE_WAIT: {
uint32_t mor, pllr0, pllr1, mckr;
cpu_irq_disable();
b_is_fastrc_used = true;
pmc_save_clock_settings(&mor, &pllr0, &pllr1, &mckr);
/* Enter wait mode */
cpu_irq_enable();
pmc_enable_waitmode();
cpu_irq_disable();
pmc_restore_clock_setting(mor, pllr0, pllr1, mckr);
cpu_irq_enable();
break;
case SAM_PM_SMODE_BACKUP:
SCB->SCR |= SCR_SLEEPDEEP;
SUPC->SUPC_CR = SUPC_CR_KEY(0xA5u) | SUPC_CR_VROFF_STOP_VREG;
cpu_irq_enable();
__WFI() ;
#else
cpu_irq_enable();
__WFE() ;
#endif
break;
bool pmc_is_wakeup_clocks_restored(void)
return !b_is_fastrc_used;
#endif /* #if (SAM3S || SAM3N || SAM3XA || SAM3U || SAM4S || SAM4E) */
Regards,
Travis
