Topic: Sending parameters to Java (Read 2444 times) previous topic - next topic
azziplekkus
Oct 17, 2012, 10:08 pm Last Edit: Oct 17, 2012, 10:27 pm by azziplekkus Reason: 1
Hello all,
Even though I'm kinda new to Arduino, I'm a bit ashamed to ask something simple as USB communication here. Especially because there are loads of tutorials to be found online (even on the arduino.cc homepage)
But still... I haven't been able to get it to work =/
Just for starters, I want to have my arduino to send numbers/words to the PC, and read it in Java.
Anyone have a good tutorial for that? one that does include Java example code?
Thanks in advance ;)
With kind regards
Azziplekkus
PaulS
Quote
Code: [Select]
Serial.print("Some words...");
int stuff = 14;
Serial.print(stuff); // Send a number
Quote
Java doesn't run on the Arduino. Can't help you there.
azziplekkus
Yes, I know how to "send" it. But if I want to read this in Java it will say
"Some words...14"
Sometimes it even does this (if I had put it in a loop)
Code: [Select]
"Some word
s...14"
"So
me words...14"
"Some words
...14"
"Some words...1
4"
"So
me words...14"
It reads every character seperatly, and prints it in console.
This way, I can't get the strings and integers out of the stream... =/
Got any idea on how to do this?
PaulS
Quote
Of course.
Code: [Select]
Serial.print("<"); // Send a start marker
Serial.print("Some words");
Serial.print(",");
Serial.print(someVariable);
Serial.print(",");
Serial.print(anotherVariable);
Serial.print(">"); // Send an end marker
Then, the Java applications needs to append characters to the string, starting when it sees the <, and stopping when it sees the >. Use the data only after you see a >.
azziplekkus
Mhmmm, do you know how I can write that in Java? I'm a noob programmer =/
PaulS
Quote
So it runs on the Arduino? You can't.
azziplekkus
#6
Oct 20, 2012, 05:39 pm Last Edit: Oct 21, 2012, 12:50 am by azziplekkus Reason: 1
No, I mean how do I write that in Java? So I can get the strings out again?
EDIT: nevermind, a friend of me helped me with writing the code :)
Amjad
Mohammed90
Quote
He meant that he wants with the Arduino via serial port using Java as the in-between-er to fetch and send the data over the serial port to the Arduino. That, sir, can be done. He does not want to run Java code on the Arduino. He says:
Quote
Anyhow, here are a few links on how to start a serial connection on Java to read data from a serial port:
http://www.java-samples.com/showtutorial.php?tutorialid=11
and
http://stackoverflow.com/questions/900950/how-to-send-data-to-com-port-using-java
