« Reply #30 on: December 03, 2012, 08:37:14 am » |
Cyber, yeah cheers, stupid mistake partly because of exhaustion and partly because I am struggling with the syntax.
Billroy, cheers for that mate and also a perfect example of why I am having so many problems and frustrations...........there simply is no such thing as a whichpin in the code section.
I am used to having a book full of code, there uses, syntax and options sitting next to me so I can compare them all and then pick and choose what I want.Well thats how it was in Basic days........lol. I still have all those old books.
I am totalled for tonight so gunna hit the sack.............Im in Australia and its quite late/early morning actually. However tomorrow I will give that a run but more importantly try to understand what its doing and why.........I consider that as important as having it work.
Im a sparky by trade so the wiring and hardware is pretty much straight forward for me with just the odd calculation that I have to look up here and there that is no longer in my head. But this programming thing.............lol, well.
By any chance is there a decent book or website with the code that you would suggest?
Anyways off to bed and thanks again mate. Will post back, probably with a heap of questions tomorrow.
Best wishes.
Manchester (England England)
Online
Solder is electric glue
« Reply #31 on: December 03, 2012, 09:17:07 am » |
Just so you will have something to wake up to:- .there simply is no such thing as a whichpin in the code section. First line of the code:- byte whichpin = 3; The code that Billroy posted will work too quickly and it will look like all the LEDs are on a bit dim. To slow it down add a delay(200) after the turning on of the LED. I am used to having a book full of code, there uses, syntax and options sitting next to me so I can compare them all and then pick and choose what I want. Nowadays it is on line a good place to start is here:- http://arduino.cc/en/Tutorial/HomePageThe C language is very much like Basic. However my advice to you would be to go slowly and try and think why what is happening is happening don't just give up and try something else. When I learned to program it was on punch cards and you could only have one run a day. If something went wrong you thought about it rather than just try something else. Actions are always logical, try and "play being the processor" that is doing each line in your head as the processor would. Remember it is very fast, if you turn on and LED and then OFF again you will not see it change.
« Reply #32 on: December 03, 2012, 10:50:22 pm » |
Thanks Bill and Mike.
Unfortunately that code does exactly what I was already able to do.
The problem is that I only want it to generate one number for each pass of HIGH from input switch 2. That input switch will be staying HIGH for a variable ammount of time. Once it goes to LOW then that should turn whatever output was on HIGH from the first pass through to LOW which it currently does. Then when the input goes HIGH again, I want one more number generated And so on.
I have had it at the stage where I can get just one to stay on by entering a WHILE loop but I dont seem to able to exit that loop when the input goes LOW.
That is where I am certain I had it all wrong but because I am struggling to understand the ; and the { } and how they affect things and when they can and cannot be used.
Everytime I had what I considered logical the verifier would force me to delete or add one or the other or tell me my BREAK was outside the loop etc. Then when I got things happy for the verifier the program would get stuck in the loop...........well either that or the random number generator always started at exactly the same number because the same number LED would be lighting every time.
Online
« Reply #33 on: December 04, 2012, 04:52:01 am » |
Try this code:- byte whichpin = 3; // set to 3 so turning it off is harmless int inputState=HIGH, oldState=LOW; void setup() { Serial.begin(9600); randomSeed(analogRead(0)); for(int i=3;i<11;i++) { pinMode(i, OUTPUT); } pinMode(2,INPUT); }
void loop() { inputState = digitalRead(2); if (inputState != oldState) { // a change has occoured if(inputState == HIGH) { // input high so turn on a random LED whichpin = random(3,10); // calculate what LED is to be on digitalWrite(whichpin, HIGH); // set the LED on } // end of input high else { // here if input is low digitalWrite(whichpin, LOW); // turn of the LED that was on } // end of input is low } // end of a change has occoured oldState = inputState; } Copy and paste it in. Read the comments. If it does not do what you want say again what you want and what it does. Everytime I had what I considered logical the verifier would force me to delete or add one or the other or tell me my BREAK was outside the loop etc. In any contest between a human and a compiler the compiler is correct in what is logical. The braces enclose blocks of code and must be nested like this:- { code { code } code }
« Reply #34 on: December 04, 2012, 07:00:21 am » |
Thanks Mike,
What is happenning now is that everything works perfectly except that the same LED comes on every single time.
I have also reached this stage on numerous occasions and each time I have come up with the following options generally going with option 2 and offering poor syntax or coding and hence the reason I am here.
Either it is not random selecting
Stuck permanently in a loop
the first number selected in a random function is always the same.
Or is it possible that the analogread (0) which is supposed to be noise affected is not noise affected for the first run through?
Is it possible that the "noise" part of analogread has to be turned on? I have extreme doubts about this but hey just throwing it out there.
I just had an idea, is there anyway to run the random selector once doing nothing so that the second pass would end up selecting the useable random number? At least that would prove or disprove theories 3 and 4.
I have spent hours going through other peoples builds trying to find someone with a similar setup but no luck as yet..........well no luck from the point of view that I could fully understand what was being done and therefore to pick out the relevant bits.
PS if it means anything, turning everything off for a few minutes and then turning it all back on again does not change anything at all...........even the same LED blinks which is by the way output 3.
hmmmm..........is that a clue? 3 is the first of the series? I know it doesnt make sense and yes I am clutching at straws.
By the way, just to confirm for myself that everything is working fine at hardware level, I have tested the multiple blink program which has almost identical OUTLET setup and it works fine.
Online
« Reply #35 on: December 04, 2012, 07:09:05 am » |
What is happenning now is that everything works perfectly except that the same LED comes on every single time. OK immediately after the loop add this line:- void loop() { inputState = random(0,10); inputState = digitalRead(2);
What this will do is to keep on generating random numbers all the time. This will be out of sync with your external signal and so will randomize what you get. Remember the same number coming on say four or five times in a row can still be a random number. Do you always want it to be a different number? While it is not random people often think this is what random numbers should do. If so then keep generating a number until it is different. if(inputState == HIGH) { // input high so turn on a random LED whichpin = random(3,10); // calculate what LED is to be on digitalWrite(whichpin, HIGH); // set the LED on this should be:- if(inputState == HIGH) { // input high so turn on a random LED int temp = whichpin; while(temp == whichpin) { whichpin = random(3,10); }// calculate what LED is to be on digitalWrite(whichpin, HIGH); // set the LED on
« Reply #36 on: December 04, 2012, 08:34:04 am » |
Yes I definitely want a random number every time and yes that could mean the same one quite a number of times in a row.....Some call it luck, I call it variance. However I left the program running for a good half hour and during that time it would have had the input switch turn on and off many hundreds of times and the chances of the same number coming up that many times are astronomical. I have added the code and it has not changed anything except that now its selected number 7 as its lock in number so that removes the clue of the first number which I never really believed anyways. (see last post by me) Looking at the way its coded though isnt the program selecting that random number and calling it inputState and then in the very next line changing it to equal digitalRead(2)? Just to be 100% certain I have everything the way you intended........... byte whichpin = 3; // set to 3 so turning it off is harmless int inputState=HIGH, oldState=LOW; void setup() { Serial.begin(9600); randomSeed(analogRead(0)); for(int i=3;i<11;i++) { pinMode(i, OUTPUT); } pinMode(2,INPUT); }
void loop() { inputState = random(0,10); inputState = digitalRead(2); if (inputState != oldState) { // a change has occoured if(inputState == HIGH) { // input high so turn on a random LED whichpin = random(3,10); // calculate what LED is to be on digitalWrite(whichpin, HIGH); // set the LED on } // end of input high else { // here if input is low digitalWrite(whichpin, LOW); // turn of the LED that was on } // end of input is low } // end of a change has occoured oldState = inputState; }
« Reply #37 on: December 04, 2012, 08:49:51 am » |
Mike I just noticed an interesting thing, if I remove the input pin that is plugged into digital 2 and move it to say dig 1 or 0 or analog 1-5 then the same led continues to flash. While the pin is unplugged nothing happens at all which is what you would expect but we have not set any of the other pins as anything?
By the way the signal is a regulated 5.oV DC input which I understand is well within specs.
Online
« Reply #38 on: December 04, 2012, 08:59:07 am » |
and move it to say dig 1 or 0 Do not use digital pins 0 & 1 these have the serial signals on them and they make things more complex to use. or analog 1-5 then the same led continues to flash. Have you changed the code to reflect the change in pin. Using analogue pin 0 means you have to call it digital pin 14, with pin 15 for analogue 1 and so on. If you don't change the code then yes it will continue to flash. Are you saying that the latest code still flashes the same LED?
« Reply #39 on: December 04, 2012, 09:03:08 am » |
Yes it does mate. Been happily doing it now for about 20 mins or so
So still no change unfortunately.
Online
« Reply #40 on: December 04, 2012, 09:04:17 am » |
How is the switch wired up?
Online
« Reply #41 on: December 04, 2012, 09:12:19 am » |
This is very odd. I have just tried this code with a wire from pin 2 touching on the USB socket and print statements in place of LEDs lighting up. This works how I would expect it to, what happens for you? byte whichpin = 3; // set to 3 so turning it off is harmless int inputState=HIGH, oldState=LOW; void setup() { Serial.begin(9600); randomSeed(analogRead(0)); for(int i=3;i<11;i++) { pinMode(i, OUTPUT); } pinMode(2,INPUT); digitalWrite(2, HIGH); }
void loop() { inputState = random(0,10); inputState = digitalRead(2); if (inputState != oldState) { // a change has occoured if(inputState == HIGH) { // input high so turn on a random LED whichpin = random(3,10); // calculate what LED is to be on // digitalWrite(whichpin, HIGH); // set the LED on Serial.print(whichpin); Serial.println(" on"); } // end of input high else { // here if input is low digitalWrite(whichpin, LOW); // turn of the LED that was on Serial.print(whichpin); Serial.println(" off"); } // end of input is low } // end of a change has occoured oldState = inputState; } Run the serial monitor to see the output.
Seattle, WA USA
Seattle, WA USA
« Reply #42 on: December 04, 2012, 09:40:11 am » |
I don't understand this: inputState = random(0,10); inputState = digitalRead(2); What is the point of assigning inputState a random number and then assigning it a value based on a switch state? One should go.
Online
« Reply #43 on: December 04, 2012, 09:57:33 am » |
What is the point of assigning inputState a random number and then assigning it a value based on a switch state? He was complaining that the random function always gave him the same number. So that was to spin the random number generator while the loop was idle as the actual number was picked on every transition of an external asynchronous signal. It is a cheap way of seeding. As it turns out he still reports the random function is giving the same value so there is something going on that he is unaware that he is not telling us. I suppose insted of:- inputState = random(0,10); I could have used:- random(0,10); but as the variable was not being used until the next line it didn't matter.
« Last Edit: December 04, 2012, 09:59:22 am by Grumpy_Mike »
Online
« Reply #44 on: December 04, 2012, 10:15:20 am » |
My latest thought is that this signal that is being fed in from outside is not a logic level signal and the ground of that signal is not connected to the ground of the arduino. Therefore the arduino board is being "wanged" on a transition and is resting the processor, which is why the random number is the same.
Therefore we need from Mazza more detail about this signal and if it causes the on board LED to flash when it makes a transition.
