Sorry for the inconvenience caused. Here is the codes in full:
#include <string.h>
#include <SoftwareSerial.h>
char incoming_char=0;
char a[20];
SoftwareSerial cell(2,3);
char mobilenumber[]="**********";
char textmessage[160];
char inchar;
int led1 = 9;
int led2 = 10;
int led3 = 11;
int led4 = 12;
cell.begin(9600);
delay(30000);
cell.println("AT+CMGF=1");
delay(200);
cell.println("AT+CNMI=3,3,0,0");
delay(200);
pinMode(led1,OUTPUT); //relay decoy//
pinMode(led2,OUTPUT); //relay decoy//
pinMode(led3,OUTPUT); //relay decoy//
pinMode(led4,OUTPUT); //relay decoy//
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
digitalWrite(led4, LOW);
pinMode(13,OUTPUT); //SMS status lamp
pinMode(12,OUTPUT);
void SMSreceive() {
/*Receive setup*/
/*Loop Logic*/
inchar=cell.read();
if (inchar=='#') // OK - the start of our command
delay(10);
inchar=cell.read();
if (inchar=='a')
delay(10);
inchar=cell.read();
if (inchar=='0')
else if (inchar=='1')
digitalWrite(led1, HIGH);
delay(10);
inchar=cell.read();
if (inchar=='b')
inchar=cell.read();
if (inchar=='0')
digitalWrite(led2, HIGH);
delay(10);
inchar=cell.read();
if (inchar=='c')
inchar=cell.read();
if (inchar=='0')
digitalWrite(led3, HIGH);
delay(10);
inchar=cell.read();
if (inchar=='d')
delay(10);
inchar=cell.read();
if (inchar=='0')
digitalWrite(led4, HIGH);
delay(10);
} // close c
cell.println("AT+CMGD=1,4"); // delete all SMS
}//close b
}//close a
}//close #
}//close available
// close function
void startSMS() {
digitalWrite(13,HIGH);
cell.print("AT+CMGS=");
cell.write(34);
cell.print(mobilenumber);
cell.write(34);
cell.println();
delay (500);
void endSMS() {
cell.write(26);
cell.println();
delay(15000);
digitalWrite(13, LOW);
void GSMTest()
if(cell.available() >0)
incoming_char=cell.read();
Serial.print(incoming_char);
if(Serial.available() >0)
incoming_char=Serial.read();
cell.print(incoming_char);
void dateFunction ()
time_t t = now();
Serial.print("System Date: ");
Serial.print(day(t));
Serial.print(" : ");
Serial.print(month(t));
Serial.println(year(t));
void timeFunction ()
time_t t = now();
Serial.print("System Time: ");
Serial.print(hour(t));
Serial.print(minute(t));
Serial.println(second(t));
long readVcc() {
long result;
// Read 1.1V reference against AVcc
ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
delay(2); // Wait for Vref to settle
ADCSRA |= _BV(ADSC); // Convert
while (bit_is_set(ADCSRA,ADSC));
result = ADCL;
result |= ADCH<<8;
result = 1126400L / result; // Back-calculate AVcc in mV
return result;
float LM3500()
float r;
float temperature;
r=readVcc()/1000.0;
temperature = analogRead(0);
temperature = (((r*temperature)/1024))/0.01;
Serial.print("Measured voltage: ");
Serial.println( r, 2 );
Serial.print("Sensor_2 temperature:");
Serial.println(temperature,2);
return temperature;
void voltmeter03()
float r;
float measuredV;
float correctfactor = 0.023;
float correctedV;
r=readVcc()/1000.0;
measuredV = analogRead(3);
measuredV = measuredV*r/1024.0;
correctedV = measuredV - measuredV*correctfactor;
Serial.print("Vcc Supply voltage");
Serial.print("Measured voltage at voltage divider:");
Serial.println(measuredV,2);
Serial.print("Corrected voltage at voltage divider:");
Serial.println(correctedV);
/*dateFunction();
timeFunction();*/
/****************************Initialization for GSM Shield**********/
/*Serial.println("Starting SM5100B Communication...");
for(int i =1;i<=4800;i++) //cannot be used with the SMS receive function
GSMTest();
delay(25);
/****************************End of Initalization*******************/
//Transitional State//
Serial.println("GSM Shield Initalization Completed!");
Serial.println("Now proceed to the measuring stage...");
/******************************Sending SMS***************************/
startSMS();
cell.print("Arduino Initalization completed!");
endSMS();
/******************************End of SMS****************************/
delay(100);
for(;;)
while(cell.available() >0)
inchar=cell.read();
a[0]=inchar;
delay(10);
inchar=cell.read();
a[1]=inchar;
delay(10);
inchar=cell.read();
a[2]=inchar;
LM3500();
if(a[0] == '#')
