Topic: SM5100b SMS receiving (Read 1 time) previous topic - next topic
camac
Dec 02, 2012, 11:11 am Last Edit: Dec 02, 2012, 11:25 am by camac Reason: 1
hi all,
Here is what i want to do: sense the temperature, check if any SMS has arrived, turn on the leds as instructed by the SMS, repeat the loop.
void loop () {
while (cell.available() >0)
char a[10];
inchar = cell.read();
a[0] = inchar;
if ( a[0]== '#')
digitalWrite(11,HIGH);
temperature = analogRead(0);
temperature = (temperature/1024)*5*1000;
Serial.print(temperature);
in the code, i would like to make it works like a interrupt, when there is a SMS being sent to the shield, the Arduino can respond as instructed.  But from what i have observed, the led fails to turn on.  Is there anything i have done wrong?  It should be..:smiley-eek:  Can anyone give me some advice?? Thanks!
Regards
MarkT
Please post all your code - we can't see the declarations of inchar or temperature, for instance.
camac
Sorry for the inconvenience caused.  Here is the codes in full: :)
#include <string.h>
#include <SoftwareSerial.h>
char incoming_char=0;
char a[20];
SoftwareSerial cell(2,3);
char mobilenumber[]="**********";
char textmessage[160];
char inchar;
int led1 = 9;
int led2 = 10;
int led3 = 11;
int led4 = 12;
 cell.begin(9600);
 delay(30000);
 cell.println("AT+CMGF=1");
 delay(200);
 cell.println("AT+CNMI=3,3,0,0");
 delay(200);
 pinMode(led1,OUTPUT);  //relay decoy//
 pinMode(led2,OUTPUT);  //relay decoy//
 pinMode(led3,OUTPUT);  //relay decoy//
 pinMode(led4,OUTPUT);  //relay decoy//
 digitalWrite(led1, LOW);
 digitalWrite(led2, LOW);
 digitalWrite(led3, LOW);
 digitalWrite(led4, LOW);
 pinMode(13,OUTPUT); //SMS status lamp
 pinMode(12,OUTPUT);
void SMSreceive() {
                   /*Receive setup*/
                   /*Loop Logic*/
                       inchar=cell.read();
                       if (inchar=='#') // OK - the start of our command
                         delay(10);
                         inchar=cell.read();
                           if (inchar=='a')
                               delay(10);
                               inchar=cell.read();
                                 if (inchar=='0')
                                 else if (inchar=='1')
                                     digitalWrite(led1, HIGH);
                                     delay(10);
                                     inchar=cell.read();
                                       if (inchar=='b')
                                           inchar=cell.read();
                                             if (inchar=='0')
                                                  digitalWrite(led2, HIGH);
                                                   delay(10);
                                                    inchar=cell.read();
                                                      if (inchar=='c')
                                                          inchar=cell.read();
                                                             if (inchar=='0')
        digitalWrite(led3, HIGH);
        delay(10);
        inchar=cell.read();
        if (inchar=='d')
        delay(10);
        inchar=cell.read();
        if (inchar=='0')
        digitalWrite(led4, HIGH);
        delay(10);
                                                             } // close c
        cell.println("AT+CMGD=1,4"); // delete all SMS
                                                          }//close b
                                                    }//close a
                                                 }//close #
                                               }//close available
                                             // close function
void startSMS() {
                 digitalWrite(13,HIGH);
                 cell.print("AT+CMGS=");
                 cell.write(34);
                 cell.print(mobilenumber);
                 cell.write(34);
                 cell.println();
                 delay (500);
void endSMS()   {
                 cell.write(26);
                 cell.println();
                 delay(15000);
                 digitalWrite(13, LOW);
void GSMTest()
if(cell.available() >0)
 incoming_char=cell.read();
 Serial.print(incoming_char);
if(Serial.available() >0)
 incoming_char=Serial.read();
 cell.print(incoming_char);
void dateFunction ()
time_t t = now();
Serial.print("System Date:  ");
Serial.print(day(t));
Serial.print(" : ");
Serial.print(month(t));
Serial.println(year(t));
void timeFunction ()
time_t t = now();
Serial.print("System Time:  ");
Serial.print(hour(t));
Serial.print(minute(t));
Serial.println(second(t));
long readVcc() {
 long result;
 // Read 1.1V reference against AVcc
 ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
 delay(2); // Wait for Vref to settle
 ADCSRA |= _BV(ADSC); // Convert
 while (bit_is_set(ADCSRA,ADSC));
 result = ADCL;
 result |= ADCH<<8;
 result = 1126400L / result; // Back-calculate AVcc in mV
 return result;
float LM3500()
 float r;
 float temperature;
 r=readVcc()/1000.0;
 temperature = (((r*temperature)/1024))/0.01;
 Serial.print("Measured voltage: ");
 Serial.println( r, 2 );
 Serial.print("Sensor_2 temperature:");
 Serial.println(temperature,2);
 return temperature;
void voltmeter03()
 float r;
 float measuredV;
 float correctfactor = 0.023;
 float correctedV;
 r=readVcc()/1000.0;
 measuredV = analogRead(3);
 measuredV = measuredV*r/1024.0;
 correctedV = measuredV - measuredV*correctfactor;
 Serial.print("Vcc Supply voltage");
 Serial.print("Measured voltage at voltage divider:");
 Serial.println(measuredV,2);
 Serial.print("Corrected voltage at voltage divider:");
 Serial.println(correctedV);
 /*dateFunction();
 timeFunction();*/
 /****************************Initialization for GSM Shield**********/
 /*Serial.println("Starting SM5100B Communication...");
 for(int i =1;i<=4800;i++) //cannot be used with the SMS receive function
 GSMTest();
 delay(25);
 /****************************End of Initalization*******************/
 //Transitional State//
 Serial.println("GSM Shield Initalization Completed!");
 Serial.println("Now proceed to the measuring stage...");
/******************************Sending SMS***************************/
  startSMS();
 cell.print("Arduino Initalization completed!");
 endSMS();
/******************************End of SMS****************************/
 delay(100);
 for(;;)
   while(cell.available() >0)
   inchar=cell.read();
   a[0]=inchar;
   delay(10);
   inchar=cell.read();
   a[1]=inchar;
   delay(10);
   inchar=cell.read();
   a[2]=inchar;
  LM3500();
   if(a[0] == '#')
PaulS
char a[10];
a[0] = inchar;
if ( a[0]== '#')
This is your whole while loop. In the loop, you create an array of 10 elements, and only write to the first one. The array goes out of scope as soon as there is no more serial data to read. Therefore, it has served no useful purpose.
Why is it there?
Your full code is full of commented out code, code that is never called, etc. Delete all the dead code and try again.
    inchar=cell.read();
    a[0]=inchar;
    delay(10);
    inchar=cell.read();
    a[1]=inchar;
    delay(10);
    inchar=cell.read();
    a[2]=inchar;
If there is at least one byte to read, hope like hell that two more arrive before you try to read them. Fail!
camac
Re: PaulS,
Thank you very much for your help!! Now i am having a clearer picture, and after some modifications, it seems to work!!  I really appreciated your help. :D
Regards,
