Topic: Clock (Hours and Mins) Project (Read 1 time) previous topic - next topic
Jackaroo
Hi all!
I've been designing a clock and I've decided that the only way it's going to work is with and Arduino.
I'm newbie to this, never really tried programming before and I've been looking over some simple commands.
Basically I was just wondering if what I proposing is do-able, or if their is a better way of doing it...
The clock consists of digits 1 to 12 being lit up (the hours), and 00 to 55 being lit up (the minutes), the board would be controlling 24 relays to turn on a much bigger power supply to control the lights. The relays are latching so I would have to pulse them rather than keep them on.
The code I was thinking of using was counting in milliseconds, when it reached 5 mins it would turn 00 off and turn 05 on and so on until it reached 55, after that it would go back to 00 and the hour light will change. Then once it reached the 13th hour it would go back to 1.
This is my first project using Arduino and code, so please be nice  :smiley-sweat: Looking forward to other projects I might try once I get the hang of it  :D Also sorry if this question has been asked before...
PaulS
Quote
Yes, it is.
Since you didn't ask any other questions, I guess that's all the answers you need. Good luck.
As a suggestion, though, the Arduino isn't all that accurate as a clock. Adding a RTC (real time clock) to a project involving 24 relays, 24 high power LEDS, a large power supply, and an Arduino is not going to add any significant cost to the project, and will make it much easier to develop the project.
The RTC library will, for instance, have a method to return the hour as a separate integer. That makes it enormously easier to determine which of 12 relays to bang on.
Similarly, it will have a method to get minutes.
Since you are into a fairly complex project, you might consider adding 60 small LEDs around the perimeter and lighting one per second. These don't need to be high power LEDs switched with relays. It's fun to watch the second indicator sweep around (and will give you much more immediate feedback that the code is working). Waiting 12 hours to see that all the relays latch in the correct order can try your patience.
dhenry
Quote
Using an interrupt and you are done. I wrote the following piece for some other purpose but it can be easily repurposed here:
Code: [Select]
//unsigned long _timer1_period=0;  //timer period, in seconds
unsigned long _timer1_counter=0;  //timer1 counter
struct {
  unsigned char hour;
  unsigned char minute;
  unsigned char second;
} mytime;
//timer1 isr
ISR(TIMER1_OVF_vect) {
  _timer1_counter+=0x10000ul;   //increment timer_counter
  if (_timer1_counter >=F_CPU) {
    _timer1_counter -= F_CPU;    //reset timer_counter
    mytime.second+=1; //increment the seconds
    if (mytime.second >=60) {
      mytime.second -= 60; //reset seconds
      mytime.minute += 1; //increment the minute
      if (mytime.minute>=60) {
        mytime.minute -= 60;  //reset minute
        mytime.hour += 1;
//initialize the timer
//to expire in user-specified period of time
void tmr1_init(void) {
  _timer1_counter = 0;            //reset timer1 counter
  mytime.hour = mytime.minute = mytime.second = 0;//reset mytime
  TCCR1B = 0x00;                //turn off the timer
  TCCR1A = 0x00;                //normal portion operation
  TCNT1 = 0;                    //reset the timer
  TIFR1 |= (1<<TOV1);            //clear the timer flag
  TCCR1B = 0x01;                //turn on the timer, 1:1 prescaler
  TIMSK1 |= (1<<TOIE1);        //enable the timer interrupt
  sei();                      //enable global interrupt
In your code, you will just set it up and test it:
Code: [Select]
void setup(void) {
  tmr1_init(); //reset the timer and get it started
void loop(void) {
  if (mytime is mydesiredtime) {
    //do something
Riva
Quote
Do you really need relays? could the digits be illuminated by LED's. Sounds a bit like a word clock http://arduino.cc/forum/index.php/topic,118338.0.html but using digits.
Don't PM me for help as I will ignore it.
Jackaroo
Thank you for the quick reply PaulS :)
So the Arduino would set the start time (by buttons) on the RTC, then the RTC would count the time for the Arduino, and then it sorts out what time to put on?
Thank you for the advice
dhenry - Thank you very much for that code, i'll have a proper read over it, trying to understand all the different parts :)
Riva - I was planning on using el wire rather than LEDs, I didn't think the board could supply that much power, or am I completely wrong? But yes it is sort of like a word clock.
Thank you all for the quick replies :)
PaulS
Quote
If that final it refers to the Arduino, rather than the RTC, then yes.
Jackaroo
Yep, thank you Paul, shall be ordering one of them ASAP.
And Riva that word clock looks fantastic!
CrossRoads
You might try this code. I have found my crystal equipped duemilanova tracks the time really well.
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
Download this, with the time set a minute or so ahead, then open the serial monitor when the time is about 2-3 seconds ahead of where you set it.
For example, I set mine for 9:26, uploaded to the board, and at 9:25:57 I opened the serial monitor, which reset the board with a time at 9:26.
When I have run this in the past I did not see it drifting at all.
Code: [Select]
// time display test
unsigned long currentmicros = 0;
unsigned long previousmicros = 0;
unsigned long interval = 10000;
byte tens_hours = 0;  // enter the time here, add in reading some buttons to make it standalone/adjustable
byte ones_hours = 9;
byte tens_minutes = 2;
byte ones_minutes = 6;
byte tens_seconds = 0;
byte ones_seconds = 0;
byte tenths = 0;
byte hundredths= 0;
byte prior_seconds = 0;
 Serial.begin(57600);
 currentmicros = micros(); // read the time.
 while (currentmicros - previousmicros >= interval) // 10 milliseconds have gone by
   hundredths = hundredths +1;
   if (hundredths == 10){
     hundredths = 0;
     tenths = tenths +1;
   if (tenths == 10){
     tenths = 0;
     ones_seconds = ones_seconds +1;
   if (ones_seconds == 10){
     ones_seconds = 0;
     tens_seconds = tens_seconds +1;
   if (tens_seconds == 6){
     tens_seconds = 0;
     ones_minutes = ones_minutes +1;
   if (ones_minutes == 10){
     ones_minutes = 0;
     tens_minutes = tens_minutes +1;
   if (tens_minutes == 6){
     tens_minutes = 0;
     ones_hours = ones_hours +1;
   if (ones_hours == 10){
     ones_hours = 0;
     tens_hours = tens_hours +1;
   if (tens_hours == 3){
     tens_hours = 0;
   previousmicros = previousmicros + interval; // update for the next comparison
 // counters are all updated now,
 if (prior_seconds != ones_seconds){
   Serial.print (tens_hours, DEC);
   Serial.print (" ");
   Serial.print (ones_hours, DEC);
   Serial.print (" : ");
   Serial.print (tens_minutes, DEC);
   Serial.print (" ");
   Serial.print (ones_minutes, DEC);
   Serial.print (tens_seconds, DEC);
   Serial.print (" ");
   Serial.println (ones_seconds, DEC);
   prior_seconds = ones_seconds;
} // end void loop
Jackaroo
So when you say crystal, is that different to a RTC? Also thank you for the code, is it supposed to run an LCD?
CrossRoads
#9
Dec 02, 2012, 04:50 pm Last Edit: Dec 02, 2012, 06:03 pm by CrossRoads Reason: 1
No, the onboard clock source - an actual crystal vs a resonator.  Vs an RTC, which is a seperate chip with its own crystal.  DS1307 is one chip, I2C interface and uses 32.768KHz crystal. Ohers are DS3231 & DS3234, both are somewhat larger chips but have built-in crystal and supposedly more accurate.
This was just test code, so it only outputs to the serial monitor.
Would be straightforward to output to an LCD, replace the serial print calls with LCD calls.
dhenry
Quote
You can use a rtc but it is really not need for your application: the main crystal does an excellent job keeping time, if you code it so.
PaulS
Quote
On the other hand, if the clock/Arduino ever looses power, you get to reset the time again. An RTC has a battery backup, so it isn't necessary to reset it.
dc42
Relays will be noisy, quite expensive (given the number you require and the fact that they will all need drivers) and unreliable in the long term. Why not use opto triacs instead, like this board https://www.sparkfun.com/products/11323 does?
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
Jackaroo
Going on that I think it's the best choice.
Unfortunately I live in the UK, I could only find them for US sale? Plus I already won 50 relays off ebay... so there isn't a problem on price, and they're latching so I don't need to have a current flowing through them, just need to pulse them, so I'm assuming there will be no noise... What do I need the drivers for? Thanks again everyone :)
dc42
Of course you can buy opto triacs in the UK, see e.g. http://uk.farnell.com/vishay/vo2223a-x001/phototriac-power-dip-6-0-9a/dp/1870799.
How much voltage and current do your latching relays need? The Arduino has a current limit of 40mA per pin, plus a per-chip limit (e.g. 200mA total Vcc or ground current for the Uno).
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
