« on: July 09, 2009, 08:56:29 am » |
I´m looking for a big graphic display (around 3'') with a wide temperature operation. It has to be Sunlight Readable. It will be in a bike. I´m thinking in a 4D System or GLDC (KS0108 or T6963). I would like something with controller,because I would like to control with Mega.
¿Any recommendation? I´ve looking CrystalFonz displays... If it´s possible with color feature, it´ll be fantastic...
Thank you
Regards,
Igor R.
« Last Edit: July 09, 2009, 08:56:54 am by igorreal »
London
Have fun!
« Reply #2 on: July 09, 2009, 10:12:51 am » |
« Last Edit: July 09, 2009, 10:13:21 am by mem »
« Reply #3 on: July 09, 2009, 10:22:46 am » |
Exist others cheaper, it depends of the model... I´m not sure that a TFT or Oled will be sunlight redeable...When I try to see something in my PDA outside, it´s difficult... It will be fitted on a motorbike... I need something redeable with high bright, wide temperature range and the electronic inside must resist vibrations. Graphics LDC are the best in price... for sure....But nowadays are quite "retro" design.....je,je,je
« Last Edit: July 09, 2009, 10:23:52 am by igorreal »
London, England
Go! Go! Arduinoooo !!!
« Reply #4 on: July 09, 2009, 10:31:35 am » |
OLED is sun readable.
« Reply #5 on: July 09, 2009, 11:20:10 am » |
And what about life of this technologies? Because I´ve read that Oled are 20k hours...
London
Have fun!
« Reply #6 on: July 09, 2009, 12:45:12 pm » |
Are you expecting to run your bike for that many hours? If you average 25 miles per hour you would be able to travel a distance greater then that to the moon and back before you used up the 20k hours.
North Yorkshire, UK
« Reply #7 on: July 09, 2009, 01:11:53 pm » |
It used to be that the blue's had a life of about 20k hours but nowadays the blue is more like 40k hours and the other colours much higher. It depends if you go for a decent display or not... Depends on price a little bit.
Anyway, what's wrong with a dot graphic display? who doesn't like a bit of retro? 8-)
For temperature you could just use a 20x4 display and use some 4 line text for BIG NUMBERS...
Mowcius
« Reply #8 on: July 09, 2009, 01:12:20 pm » |
Mem,You don´t have to think only in application with the motorbike in movement.... There are 2'3 years... You imagine that the display of your car break down in 5 years ....
« Last Edit: July 09, 2009, 01:14:16 pm by igorreal »
« Reply #9 on: July 09, 2009, 01:19:16 pm » |
It´s not to show temperature... I need that the display works in a wide range of temperature... like -20 to 80ºC. The application will be like an onboard computer....  Of course, with a gldc an a little of design could be something cool
« Last Edit: July 09, 2009, 01:19:58 pm by igorreal »
London
Have fun!
« Reply #10 on: July 09, 2009, 01:49:35 pm » |
You imagine that the display of your car break down in 5 years .... 20k operating hours in my car would take 60 years  Anyway, if you do decide to go retro, I have a nice GLCD library for you to use: http://www.arduino.cc/playground/Code/GLCDks0108
« Last Edit: July 09, 2009, 01:50:02 pm by mem »
« Reply #11 on: July 09, 2009, 02:10:30 pm » |
Thank you mem. But I´m asking more about models, types, where to buy, experiences, ....
I need a big one display (more than 3'')
Regards,
« Last Edit: July 09, 2009, 02:40:00 pm by igorreal »
North Yorkshire, UK
« Reply #12 on: July 09, 2009, 02:35:57 pm » |
For temperature you could just use a 20x4 display and use some 4 line text for BIG NUMBERS... Oh, sorry, misread the post, sounds like a cool project, Mowcius
Manchester (England England)
Solder is electric glue
« Reply #13 on: July 09, 2009, 06:08:40 pm » |
I need that the display works in a wide range of temperature... like -20 to 80ºC. Normal commercial electronics is only specked for 0 to 70C. Going outside these ranges costs you a lot more. A military specified display is going to cost about 5 to 10 times more than a commercial display.
« Reply #14 on: July 10, 2009, 02:28:41 am » |
I´ve found CrytalFontz which has -20 to 70ºC. With T6963 controller and 160x128 (101 x 82 mm). It seems good!!
Any experience with this company? Another similar?
