Topic: Displays... (Read 7138 times) previous topic - next topic
Igor R
One easy question:
How can I calculate the space require to store a bitmap in a dot graphic display?
For example, if I have a display of 128x64 dots
Kind Regards,
Igor R.
mem
#16
Jul 12, 2009, 08:19 pm Last Edit: Jul 12, 2009, 11:33 pm by mem Reason: 1
total bytes equals width times height times bits per pixel divided by 8
128 x 64 with 8 bits (1 byte) per pixel is 8k bytes
Igor R
Thank you mem!!!
Anyone knows which is the LCD and touch used in LCDash project? (Megasquirt)
It´s a T6963. I´m asking about where I can buy it.
http://lcdash.wikispaces.com/LCD
http://lcdash.wikispaces.com/touchscreen
Regards,
florinc
Why 8 bits per pixel if this is a monochrome display?
mem
In the first post the OP said he would ideally like a color display if possible
EmilyJane
Linked from the site you referenced:
http://www.diyautotune.com/catalog/lcdash-digital-touchscreen-dash-display-for-megasquirt-p-167.html
Looks kind of pricey to me. It looks like a transmissive type where I would think for outdoor readability you'd want a transflective.
Igor R
EmilyJane,I want only the display, not the entire solution... I suppose the display is $60 or something similar...
In a monochrome display, the calculation is different?
Thank you for your feedbacks!!
Igor R.
AWOL
Depends - monochrome could be one bit per pixel, so 128x64 would requires 8192 bits = 1024bytes.
OTOH, you could have maybe a monchrome greyscale of, say four bits per pixel, so in that case, you'd need four times as much memory, or 4kbytes.
Igor R
#23
Jul 13, 2009, 10:13 am Last Edit: Jul 13, 2009, 10:15 am by igorreal Reason: 1
With the KS0108 or T6963 controllers, do you know the bits per pixel?
It´s only to think about the amount of space required...
Thank-u!
Regards
Igor R.
mem
#24
Jul 13, 2009, 10:50 am Last Edit: Jul 13, 2009, 10:50 am by mem Reason: 1
ks0108 and similer are 1 bit per pixel, so 128x64 memory is 1k bytes
EmilyJane
#25
Jul 13, 2009, 05:44 pm Last Edit: Jul 13, 2009, 05:47 pm by EmilyJane Reason: 1
Oops, sorry, I thought that sounded a little high. :-[
I think something like this:
http://www.crystalfontz.com/product/CFAG12864B-TFH-V
is what you are looking for. It's around $34 and it is a transflective display, which is the most sunlight readable of the LCD displays, in my experience. It also has an LED edgelight, which will allow reading in darker conditions.
Igor R
Thank you!!
I suppose they´re using this http://www.crystalfontz.com/product/CFAG240128L-TMI-TZTS.
Because of it´s 240x128 and touchscreen ($87).
In the web say that the best for sunlight are Reflective or Transflective. (Yellow/Green LED Backlight or White Edge LED Backlight ).
The blue one is Transmissive...
Uff... a lot of differents technologies... I´m quite confused...je,je,je
EmilyJane
You need to make up your mind about how many pixels you want and then buy a transflective display. I don't see the problem. ::) :D
Igor R
ja,ja,ja
I would like KS0107/KS0108 or Toshiba T6963 because it´s easy to implement and there are many info and libraries in internet.
Something like this: http://www.crystalfontz.com/product/CFAG240128L-YYH-TZ
Size: 240x128 or 160x128
But in stead of Yellow/Green led backlight, I would like blue or red backlight. Both would be fantastic!!
Letters-Graph in black and background in blue is a perfect combination!!
Example:
Is it possible change the leds?
EmilyJane
If you can make do with 128 x 64, they have one with an RGB backlight:
http://www.crystalfontz.com/product/CFAG12864A-CFH-TA
With the proper psychic sensor software in your Arduino, it would be like a two-wheel mood ring!
