Topic: WDT code does not run on duemilenova and mega but runs fine on leonardo (Read 1 time) previous topic - next topic
Jantje
I have a problem which seems to be board specific.
I tried to run the code copied below on my duemilenova. The code runs a loop that goes slower and slower till the watchdog resets the board.
The code runs fine till the first reset triggered by the watchdog. Then led L starts blinking really fast and never stops doing so.
Pressing the reset button does not help. Taking away power and plugging it back in repeats the scenario as described above.
As the code was taken from the forum and the watchdog flag needs to be reset in the startup code, I thought this may be bootloader related so I burned the bootloader with version 1.0.2 of the Arduino IDE.
This did not solve the problem.
Then I tried with a mega and a leonardo. The mega behaves the same but the leonardo works fine.
So I'm wondering what is wrong here.
Anyone can help?
Best regards
Jantje
Code: [Select]
// Do not remove the include below
#include "test.h"
//  Watchdog Timer Example
#include <avr/wdt.h>
unsigned long ToggleDelay;  //  When this delay grows to longer than the WDT interval the WDT resets the Arduino
const int LEDpin = 13;
void toggle_led()
  digitalWrite(LEDpin, !digitalRead(LEDpin));
  wdt_disable();
  ToggleDelay = 1;   // Start with a very short delay
  pinMode(LEDpin, OUTPUT);
  wdt_enable(WDTO_250MS);  // Set watchdog to 1/4 second
  ToggleDelay=0;
  wdt_reset();
  toggle_led();   // Blinking goes slower and slower until the WDT causes reset, then starts over.
  delay(ToggleDelay);
  ToggleDelay += 5;   // Increase the delay by 5 milliseconds.
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Jantje
Nick
I was not aware that you can select a bootloader when burning a bootloader with the Arduino IDE.
So I guess I did the default one for duemilenove.
If there is a better one: can you point me to it? Can you point me to documentation how I can burn it?
Best regards
Jantje
nickgammon
I am using the Uno bootloader on my Duemilanove - it works fine (it's the same processor) and I don't have any issues with the WDT.
Jantje
I hadn't thought of that one.
I'll give it a try tonight
Best regards
Jantje
retrolefty
Best regards
Jantje
That should fix your issue with the WDT. 328 based boards prior to the Uno (and still to this day mega boards of all flavors) used bootloaders that do not handle WDT interrupts correctly. In the old days one could get a copy of a modified bootloader from the Adafruit (and other 3rd parties?) that would correct the problem with 328 based boards.
But today for any of the older arduino 16Mhz 328p based boards you can just burn them with the Uno bootloader by selecting the Uno board prior to performing the burn bootloader operations. Just keep in mind that after that you must always select the Uno board when uploading sketches to the board, as in effect for uploading purposes your older board has become a Uno board.
Lefty
Jantje
retrolefty
Thanks for this alert. I'm sure I would have used the name of the lord when experiencing this behavior
Best regards
Jantje
Jantje
nick & retrolefty
this works like a charm.
Thanks for helping me out.
Best regards
Jantje
