Loading...
Pages: [1]   Go Down
Author Topic: Compiler freezes with no erorrs, changes since last compile remove  (Read 198 times)
Offline Offline
Newbie
View Profile
I am having what appears to be a wierd error with the arduino compiler.
I have a substantial deumilenova program, just short of 1000 lines so i am hesitant to post it at this stage.
However everything was compiling and downloading correrctly until i made a small addition to the code, a very simle sub routine and a call in main.
Now, having removed this component whenever i try to compile my program the status bar gets to 25% and freezes and does not throw out an error in the compiler (just the usual red compiler log). This happens on both my desktop and laptop as well.
Can anyone suggest anything to try and rectify this problem, the thought of trawling 1000 lines for a possible error without debugging information is going to be time consuming in the least
Logged
New Jersey
Online Online
Edison Member
View Profile
Can you successfully compile other programs?
Logged
Offline Offline
Newbie
View Profile
Yes, and it appears i can compile previous versions of this program as well.
Logged
Offline Offline
Newbie
View Profile
***SOLVED***
I have found the error in my code.
I had started to write a serial output line for troubleshoot but must have gotten distracted. Regardless the line
Serial.print("
Appears to cause the compiler to hang.
The quick way to find this was using a program called Beyond Compare which makes life easy when comparing two different versions of a program as it highlights any changed lines and text very clearly.
Logged
Offline Offline
Newbie
View Profile
I do not know if this is a known bug however i recently had a problem with a piece of code causing the compiler to hault without returning an error message and debugging information and i thought i would share
Logged
New Jersey
Online Online
Edison Member
View Profile
Amazingly, that was my next guess - you've managed to make a string so long it crashed the compiler, or so it appears.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Go ahead.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Code:
void setup ()
  Serial.print ("
  }  // end of setup
void loop ()
  }  // end of loop
That did not hang. I got:
Code:
sketch_dec07b:2: error: missing terminating " character
sketch_dec07b.cpp: In function 'void setup()':
sketch_dec07b:3: error: expected primary-expression before '}' token
sketch_dec07b:3: error: expected `;' before '}' token
It helps to post the problem code, you know. We can't guess what it is.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
Logged
Pages: [1]   Go Up
Print
Jump to:
