Topic: Frequency Measurement Library Zero Frequency (Read 850 times) previous topic - next topic
matinzk
I am using the Frequency Measurement Library: http://interface.khm.de/index.php/lab/experiments/frequency-measurement-library/
I am trying to measure frequecy from 0-500 To then connect to my RPM and speed frequency signal wires on my car to convert the frequency values to the correct speed and RPM values.
The problem I have is that when RPM is 0 or speed is 0 the library either doesn't give me anything or gives random values. How can I measure 0 frequency? Or in other words set frequency at zero when there are no counts?
I don't have to use this particular library either.
Any help is appreciated.
Thanks.
MarkT
You want to use a different technique from that library (which is measuring the period).  You want to measure the zero-crossings per second instead.   Simplest way is to count each zero crossing in a variable and then every second (use the blinkWithoutDelay technique) note the change in that variable from the last time.
matinzk
Thanks for your reply.
I'm not sure how to do that to be honest  :~
