« Reply #15 on: January 08, 2013, 05:35:33 am » |
Hi Nassa!
Bossac doesn't work?! It happened to me, too. Are you using a USB 3 port? This could be the problem. To fix it, just program the Arduino by using a USB 2 port or, if you don't have it, through a USB 2.0 Hub! Cheers
« Reply #16 on: January 08, 2013, 01:24:25 pm » |
I tried to follow to tutorial. But I cant build the static library I think some includes are wrong but I cant find out wich. I got the following error log (not the complete log just this is just a small part) when trying to build. I'm on osx maybe that got something to do with it '__disable_irq' was not declared in this scope interrupt_sam_nvic.h /ArduinoDueCore/src/lib/libsam/include line 123 '__DMB' was not declared in this scope interrupt_sam_nvic.h /ArduinoDueCore/src/lib/libsam/include line 123 '__enable_irq' was not declared in this scope interrupt_sam_nvic.h /ArduinoDueCore/src/lib/libsam/include line 135 '_dwIrq' was not declared in this scope USARTClass.cpp /ArduinoDueCore/src/core line 60 '_pUsart' was not declared in this scope USARTClass.cpp /ArduinoDueCore/src/core line 43 'Adc' was not declared in this scope adc.h /ArduinoDueCore/src/lib/libsam/include line 175 'Dacc' was not declared in this scope dacc.h /ArduinoDueCore/src/lib/libsam/include line 67 'IRQn_Type' does not name a type USARTClass.h /ArduinoDueCore/src/core line 35 'NVIC_DisableIRQ' was not declared in this scope USARTClass.cpp /ArduinoDueCore/src/core line 72 'NVIC_EnableIRQ' was not declared in this scope USARTClass.cpp /ArduinoDueCore/src/core line 60 'p_adc' was not declared in this scope adc.h /ArduinoDueCore/src/lib/libsam/include line 173 'p_dacc' was not declared in this scope dacc.h /ArduinoDueCore/src/lib/libsam/include line 66 'p_tc' was not declared in this scope tc.h /ArduinoDueCore/src/lib/libsam/include line 73 'p_tc' was not declared in this scope tc.h /ArduinoDueCore/src/lib/libsam/include line 71 'Pdc' does not name a type dacc.h /ArduinoDueCore/src/lib/libsam/include line 70 'Pio' does not name a type pio.h /ArduinoDueCore/src/lib/libsam/include line 124 'pPio' was not declared in this scope pio.h /ArduinoDueCore/src/lib/libsam/include line 109 'pPwm' was not declared in this scope pwmc.h /ArduinoDueCore/src/lib/libsam/include line 76
« Reply #17 on: January 08, 2013, 02:10:25 pm » |
Hi Joppuh,
I do not think your problem is not OSX. In my opinion, there are two possibilities :
Either you forgot one of the 3 defines : __SAM3X8E__ USB_PID=0x003E USBCON
Either you forgot an include path or one or more files are missing.
Warning, and include Defines Path must be set in the configuration C and C+ + (Tool Settings) : ARM Sourcery Windows GCC C Compiler and ARM Sourcery Windows GCC C + + Compiler
Let me known please.
Nassa.
« Reply #18 on: January 08, 2013, 02:20:02 pm » |
These are my defined symbols in C and C++ compiler _SAM3X8E_ USB_PID=0x003E USBCON
These are my included paths
"${workspace_loc:/${ProjName}/src/core}" "${workspace_loc:/${ProjName}/src/lib/CMSIS/Device/ATMEL}" "${workspace_loc:/${ProjName}/src/lib/CMSIS/CMSIS/Include}" "${workspace_loc:/${ProjName}/src/lib/libsam/include}" "${workspace_loc:/${ProjName}/src/lib/libsam}" "${workspace_loc:/${ProjName}/src/lib/CMSIS/Device/ATMEL/sam3xa/include}" "${workspace_loc:/${ProjName}/src/lib/variants/arduino_due_x}"
« Reply #19 on: January 08, 2013, 02:44:15 pm » |
The processor Define is : __SAM3X8E__ and not _SAM3X8E_ There is 2 underscore before and 2 underscore after.
Could you verify ?
And let me know please.
Nassa.
« Reply #20 on: January 08, 2013, 03:27:34 pm » |
Still got 135 errors but all in USBcore.cpp But Im able to build I got a libArduinoDueCore.a in my Release folder. But I think the linker script isnt working for de MyProject If I build your example I only get a main.o and a syscalls_sam3.o in my release folder.. EDIT All the errors about USBcore.ccp are could not be resolved errors like: Field 'UOTGHS_DEVCTRL' could not be resolved
« Last Edit: January 08, 2013, 03:48:22 pm by joppuh123 »
« Reply #21 on: January 08, 2013, 03:48:19 pm » |
Clean your ArduinoDueCore project : - clean ArduinoDueCore project - in the "Problems" tab right click on the root errors node, when the popup is open, click on "Delete" item. You can do the same for warnings. - bluid ArduinoDueCore.
Build MyProject.
Nassa.
« Reply #22 on: January 08, 2013, 03:55:51 pm » |
No more errors or warnings!
But nothing in the release folder of myprojects..
I'll try to make a new project
EDIT Got a .map file in my release folder but not a hex..
« Last Edit: January 08, 2013, 04:08:52 pm by joppuh123 »
« Reply #23 on: January 09, 2013, 07:51:02 am » |
Hi Nassa , I played a bit with arduino uno elipse integration and looking at your guide I don't see the define which says which board is beeng compiled. In case of Aduino due it is -DARDUINO=151. Zad
« Reply #24 on: January 09, 2013, 11:01:48 am » |
Hi Nassa, if I well understood ,to use the PROGRAMMING port with bossac you shall use one of the two procedures reported in the AduinoDue main page. that are : 1) pressing the erase button on the arduino while running bossac 2) Open the serial port without bossac, which activates the Erase and Reset sequence , and then launch the bossac . Unfortunately I can only use the bossac via command line while pressing the erase button, if I do that using the eclipse external tool it doesn't works. I'll do a script which opens the port ,closes it and then run the bossac. By the way, to understand how the bossac is actually run by the arduino IDE , I substituted the original bossac with a simple shell script and run the upload procedure on the IDE. Here the code : echo $@ >/Applications/Arduino-due.app/Contents/Resources/Java/hardware/tools/bossac.arg /Applications/Arduino-due.app/Contents/Resources/Java/hardware/tools/bossac.orig $@
Zad
« Reply #25 on: January 09, 2013, 12:43:40 pm » |
I've got these error's now in myProject These error's keep coming back I defined -L but it seems i't cant find the library or something if I build like 3 times in a row it completes but only shows the .o files undefined reference to `digitalWrite' main.cpp /MyProject/src C/C++ Problem undefined reference to `USBDevice' main.cpp /MyProject/src C/C++ Problem undefined reference to `USBDevice_::attach()' main.cpp /MyProject/src C/C++ Problem undefined reference to `pinMode' main.cpp /MyProject/src C/C++ Problem undefined reference to `delay' main.cpp /MyProject/src C/C++ Problem undefined reference to `init' main.cpp /MyProject/src C/C++ Problem
EDIT: Fixed it now I got a elf file!
« Last Edit: January 09, 2013, 12:50:25 pm by joppuh123 »
« Reply #26 on: January 09, 2013, 01:11:56 pm » |
I resolved the problem with bossac in Eclipse , for some reasons ,in my case , if as first parameter in the arguments list is placed --port=tty.usbmodemfd121 the command ends with : No device found on tty.usbmodemfd121 also when I press the erase button. if --port is used as seconds parameter, using the erase button, eclipse and bossac run like a charm. Erase flash Write 9556 bytes to flash
[ ] 0% (0/38 pages) [======= ] 26% (10/38 pages) [=============== ] 52% (20/38 pages) [======================= ] 78% (30/38 pages) [==============================] 100% (38/38 pages) Verify 9556 bytes of flash
[ ] 0% (0/38 pages) [======= ] 26% (10/38 pages) [=============== ] 52% (20/38 pages) [======================= ] 78% (30/38 pages) [==============================] 100% (38/38 pages) Verify successful Set boot flash true CPU reset.
I tried to open the programming port and then to launch bossac , but I have still the uploading problem. For the moment it works fine with the erase button. @joppuh123: It seems your core library doesn't contain wiring_digital.c , do you have it in yours library files? it is contained inside variants/arduino_due_x Cheers zad
« Reply #27 on: January 09, 2013, 01:43:55 pm » |
I do got a wiring_digital.c I have it in /src/core not in variants... I got an elf file I was able to upload the elf file but the led doesn't blink... Is it because I dont got the -DARDUINO=151 define. Also the library does build but is was browsing the source file and an error poped up. Field 'PIO_OSR' could not be resolved wiring_digital.c /ArduinoDueCore/src/core line 62 Semantic Error
Getting an stm32 working in eclipse is easier than this!
« Reply #28 on: January 09, 2013, 02:02:39 pm » |
HI All, finally I did it ! I'm able to build the blinky led program and upload it using the external tool all done in eclipse. The last tiny problem is the bossac manually operation... I've followed a different path from the one proposed by Nassa, obviously is due to him if I'm at this stage. I will soon post how I did it . Cheers Zad
« Reply #29 on: January 09, 2013, 02:10:16 pm » |
Congrats I'm excited to hear how you did it!
