Topic: Easyvr - Domotics - Help (Read 1 time) previous topic - next topic
LCMOURA
This program will turn on or off lights and open or close blind.
I want to say a command "Entrada" e goes to group 1 if the name, saved in this group was right goes to group 16 (pwd), otherwise the program counts three attemps and blink a red led and plays buzzer for 5 secs. If program goes to group 16, that means that the name said was correct, and evething was right, the program plays a sound in sound table and goes to group 0, otherwise the program do the same procedure when the name is wrong. What I really want to do is put a If inside a Switch case, is that possible? If anyone could help me out I would appreciate it.
Code: [Select]
#include <EasyVR.h>
#define SND_SON_FINAL_1            1
#define SND_SON_FINAL_2            2
#define SND_SON_FINAL_3            3
#define SND_SON_FINAL_4            4
#define SND_SON_FINAL_5            5
#define SND_SON_FINAL_6            6
#define SND_SON_FINAL_7            7
#define SND_SON_FINAL_8            8
#define SND_SON_FINAL_9            9
EasyVR easyvr(port);
enum Groups
 GROUP_0  = 0,
 GROUP_1  = 1,
 GROUP_2  = 2,
 GROUP_3  = 3,
 GROUP_4  = 4,
 GROUP_5  = 5,
 GROUP_6  = 6,
 GROUP_7  = 7,
 GROUP_8  = 8,
 GROUP_16 = 16,
 Entrada = 17
enum Group0
 G0_CASA = 0,
enum Group1
 G1_LUIZ_MOURA = 0,
enum Group2
 G2_ILUMINACAO = 0,
 G2_PERSIANA = 1,
 G2_CANCELA_COMANDO = 2,
 G2_ATALHO_OFF = 3,
 G2_SAINDO = 4,
 G2_ENTRADA = 5,
enum Group3
 G3_ESTAR = 0,
 G3_SALA = 1,
 G3_QUARTO = 2,
enum Group4
 G4_LIGA = 0,
 G4_DESLIGA = 1,
 G4_CANCELA_LUZ = 2,
enum Group5
 G5_ABRE_PERSIANA = 0,
 G5_FECHA_PERSIANA = 1,
 G5_CANCELAR_PERSIANA = 2,
enum Group6
 G6_LIGA = 0,
 G6_DESLIGA = 1,
 G6_CANCELAR_LUZ = 2,
enum Group7
 G7_LIGA = 0,
 G7_DESLIGA = 1,
 G7_CANCELAR_LUZ = 2,
enum Group8
 G8_DESLIGA_ESTAR = 0,
 G8_DESLIGA_QUARTO = 1,
 G8_DESLIGA_SALA = 2,
 G8_DESLIGA_TUDO = 3,
enum Entrada
 Wake_on_char = 0,
enum Group16
 G16_PWR_LUIZ = 0,
EasyVRBridge bridge;
int8_t group, idx;
int E2 = 6;
int M2 = 7;
const int LDR = 14;
int ValorLido = 0;
int ValorLido2 = 0;
const int led = 5;
 if (bridge.check())
   cli();
   bridge.loop(0, 1, 12, 13);
 port.begin(9600);
 if (!easyvr.detect())
   Serial.println("EasyVR not detected!");
   for (;;);
 easyvr.setPinOutput(EasyVR::IO1, LOW);
 Serial.println("EasyVR detected!");
 easyvr.setTimeout(5);
 easyvr.setLanguage(0);
 pinMode(8, OUTPUT);
 pinMode(3, OUTPUT);
 pinMode(4, OUTPUT);
 pinMode(9, OUTPUT);
 pinMode(10, OUTPUT);
 pinMode(M2, OUTPUT);
 pinMode(led, OUTPUT);
void action();
int idx_nome;
int idx_pwd;
char wake[32];
int nome_nc;
int count=0;
 easyvr.setPinOutput(EasyVR::IO1, HIGH);
 Serial.print("Diga um comando do grupo ");
 Serial.println(group);
 easyvr.recognizeCommand(group);
  do
 ValorLido = analogRead(LDR);
 if (ValorLido < 5){
  digitalWrite(led, HIGH);
 else{
  digitalWrite(led, LOW);
 while (!easyvr.hasFinished());
 easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
 idx = easyvr.getWord();
 if (idx >= 0)
return;
 idx = easyvr.getCommand();
 if (idx >= 0)
   // print debug message
   uint8_t train = 0;
   char name[32];
   Serial.print("Command: ");
   Serial.print(idx);
   if (easyvr.dumpCommand(group, idx, name, train))
     Serial.print(" = ");
     Serial.println(name);
   easyvr.playSound(0, EasyVR::VOL_FULL);
   // perform some action
   action();
 else // errors or timeout
   if (easyvr.isTimeout())
     Serial.println("Timed out, try again...");
   int16_t err = easyvr.getError();
   if (err >= 0)
     Serial.print("Error ");
     Serial.println(err, HEX);
     easyvr.playSound(8, EasyVR::VOL_FULL);
void action()
    switch (group)
   case GROUP_0:
     switch (idx)
     case G0_CASA:
       easyvr.playSound(4, EasyVR::VOL_FULL);
       group = (2);
   case GROUP_1:
     switch (idx)
     case G1_LUIZ_MOURA:
       easyvr.playSound(9, EasyVR::VOL_FULL);
       group = (16);
   case GROUP_2:
     switch (idx)
     case G2_ILUMINACAO:
       easyvr.playSound(5, EasyVR::VOL_FULL);
       group = (3);
     case G2_PERSIANA:
       easyvr.playSound(7, EasyVR::VOL_FULL);
       group = (5);
     case G2_CANCELA_COMANDO:
       easyvr.playSound(3, EasyVR::VOL_FULL);
       group = (0);
       case G2_ATALHO_OFF:
       group = (8);
     case G2_SAINDO:
       easyvr.sleep(0);
       case G2_ENTRADA:
       easyvr.playSound(6, EasyVR::VOL_FULL);
       group = (1);
   case GROUP_3:
     switch (idx)
     case G3_ESTAR:
       group = (4);
     case G3_SALA:
       group = (6);
     case G3_QUARTO:
       group = (7);
   case GROUP_4:
     switch (idx)
     case G4_LIGA:
       digitalWrite(8, HIGH);
     case G4_DESLIGA:
       digitalWrite(8, LOW);
     case G4_CANCELA_LUZ:
       group = (0);
   case GROUP_5:
     switch (idx)
     case G5_ABRE_PERSIANA:
     digitalWrite(M2,HIGH);
     digitalWrite(E2,HIGH);
     delay(2200);
     digitalWrite(M2,LOW);
     digitalWrite(E2,LOW);
     case G5_FECHA_PERSIANA:
     delay(1600);
     case G5_CANCELAR_PERSIANA:
     group = (0);
     case GROUP_6:
     switch (idx)
     case G6_LIGA:
       digitalWrite(3, HIGH);
     case G6_DESLIGA:
       digitalWrite(3, LOW);
     case G6_CANCELAR_LUZ:
       group = (0);
   case GROUP_7:
     switch (idx)
     case G7_LIGA:
       digitalWrite(4, HIGH);
     case G7_DESLIGA:
       digitalWrite(4, LOW);
     case G7_CANCELAR_LUZ:
       group = (0);
   case GROUP_8:
     switch (idx)
     case G8_DESLIGA_ESTAR:
       group = (0);
     case G8_DESLIGA_QUARTO:
       group = (0);
     case G8_DESLIGA_SALA:
       group = (0);
     case G8_DESLIGA_TUDO:
       digitalWrite(5, LOW);
       delay(1500);
       group = (0);
   case GROUP_16:
     switch (idx)
     case G16_PWR_LUIZ:
     int16_t err1 = easyvr.getError();
     if (err1 >= 11)
     easyvr.playSound(1, EasyVR::VOL_FULL);
     digitalWrite(10, HIGH);
     digitalWrite(10, LOW);
     digitalWrite(9, LOW);
      else{
       easyvr.playSound(2, EasyVR::VOL_FULL);
       digitalWrite(9, HIGH);
       delay(5000);
       group = (0);
codlink
From your code, when you say something in group 0, it goes to group 16.
I don't think I understood your question correctly, but are you asking that when you are in group 16 and they say the word in group 16 that you want it to go back to group 0?
//LiNK
LCMOURA
Thanks for helping me.
This program besides turn on or turn off the light, it also control access home
In my code, after the trigger when I say "Entrada" (a word registred in group 2, that means I want to enter in the house) it goes for group 1, and when I said a word (User name) registred in group 1, it goes for group 16, if I said some word that is not registred in group 1, it should generate an error, and blink a red led and play a buzzer after three attemps. But if everything is ok, it goes for group 16.
In group 16 If I said the correct passaword for this User Name (registred in group 1), it plays a sound recorded in sound table that means that the user have the garanteed access to home and the system goes back to group 0, waiting for the trigger. If the password was wrong it shoud generate an error and blink a red led a play a buzzer after three atemps, the same procedure if the user name was not registred. I am trying to do the same as Control Access Home in the Veear web site.
Link: http://www.veear.eu/downloads/
Can you help me?
codlink
Now I know what you want it to do, what is it doing wrong?
I see your polling the error if you say something wrong, but your not printing it anywhere.  For the LEDs and buzzer, you do just like in the other groups.  You can write them HIGH or LOW depending on what you want.
What are the numbers for?
Code: [Select]
  pinMode(8, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(9, OUTPUT);
If you gave them meaningful names, it might help you and the people that are trying to help.
//LiNK
LCMOURA
I think the program is not generate the error. I think that the if inside de Case G16_PWD_LUIZ is not working.
Follow:
Code: [Select]
case G16_PWR_LUIZ:
      if (err1 >= 11)
       else{
        delay(5000);
        digitalWrite(9, LOW);// write your action code here
        group = (0);
       }// group = GROUP_X; <-- or jump to another group X for composite commands
Here we go, the pins are: 8 - Living Room, 3 - Hall, 4 - Room, 9 - Red Led installed in the driveway, 10 - Green Led installed in the driveway, M2 - blind motor and led, another led controled by light sensor.
I did not gave the meaningful names, because the forum post limits on the maximum number of 9500 characters, and my first post of 9500 had passed characters.
If I need to put more information please let me know.
codlink
I am guessing when this error:
Code: [Select]
      if (err1 >= 11)
occurs, you want to:
Code: [Select]
If these Writes are not working than the error of "greater than or equal to 11" is not happening.
In the manual error "11h" is the error produced from "Recognition Failed."  I honestly don't know how to write this into proper C++, but try something like this:
Code: [Select]
      if (err1 == 11h)
If it doesn't work, than maybe someone could chime in and tell us how to write a hex style C++ code for that.
//LiNK
PaulS
Quote
Well, one could always Serial.print() the value to see what it is.
codlink
Quote
lol, very true..
//LiNK
LCMOURA
I put a 11h, but it get a compile error. If anyone could help me I really, really appreciate it.
codlink
Code: [Select]
Serial.println(err1);
Serial.println("");
When you say a word that it doesn't recognize, it should print it to the serial monitor what the error is.
//LiNK
