Topic: how to extract data from i button DS1923-F5# using arduino (Read 2192 times) previous topic - next topic
jahnavi
I am trying to get the data from DS1923-F5# using arduino. I have an sample code to extract data from DS1920-F5 using the same code while changing the vlaues of the registers for DS1923-F5# is not working out. So please let me know how to do it as DS1923-F5# is a Temperature/Humidity Logger ibutton where as  DS1920-F5 is just the Temperature i button.
Thank you
tkbyd
If no one has already invented this wheel... which you should hope for!... there's LOTS (not for the faint hearted) on 1-Wire stuff, reading the datasheets, etc, at....
http://www.arunet.co.uk/tkboyd/e1didx.htm
and
http://www.arunet.co.uk/tkboyd/e1dsw.htm
Be of good cheer! You can probably, for Arduino work, skip over all of the "addressing"/ "selecting" stuff covered in the pages mentioned above.
jahnavi
I have gone through the links that were stated in the post but i didn't find any example which can extract data from the ibutton logger. Can you please post any example that will get the data from ibutton logger.
Thank you
