Topic: HC SR04 and 7 segment display (Read 769 times) previous topic - next topic
SAButter
I'm having some trouble on getting the two programs to connect. The serial monitor is telling me that the sr04 is working but I dont know how to send that distance to the rest of the program so the display can use it.
If you guys have the time to point me in a direction I could use the help.
Code: [Select]
// Example NewPing library sketch that does a ping about 20 times per second.
#include <NewPing.h>
#define TRIGGER_PIN  3  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     2  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
int aPin = 13;                // Red LED connected to digital pin 13
int bPin = 12;
int cPin = 11;
int dPin = 10;
int ePin = 9;
int fPin = 8;
int gPin = 7;
  Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
  pinMode(aPin, OUTPUT);        // sets the digital pin as output
  pinMode(bPin, OUTPUT);
  pinMode(cPin, OUTPUT);
  pinMode(dPin, OUTPUT);
  pinMode(ePin, OUTPUT);
  pinMode(fPin, OUTPUT);
  pinMode(gPin, OUTPUT);
  delay(200);                      // Wait 200ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
  Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance in cm and print result (0 = outside set distance range)
  int val = (uS);  //us inserted instd of val 12/4/12
  if(val >= 1 && val <= 100) // else if was inserted in sketch
  digitalWrite(aPin, LOW);
  digitalWrite(bPin, LOW);
  digitalWrite(cPin, LOW);
  digitalWrite(dPin, LOW);
  digitalWrite(ePin, LOW);
  digitalWrite(fPin, LOW);
  digitalWrite(gPin, HIGH);
  else if (val >= 101 && val <= 200)
  digitalWrite(aPin, HIGH);
  digitalWrite(dPin, HIGH);
  digitalWrite(ePin, HIGH);
  digitalWrite(fPin, HIGH);
  else if (val >= 201 && val <= 300)
  digitalWrite(cPin, HIGH);
  digitalWrite(gPin, LOW);
  else if (val >= 301 && val <= 400)
  else if (val >= 401 && val <= 500)
  else if (val >= 501 && val <= 600)
  digitalWrite(bPin, HIGH);
  else if (val >= 601 && val <= 700)
  else if (val >= 701 && val <= 800)
  else if (val >= 801 && val <= 900)
  else if (val >= 901 && val <= 1023)
SAButter
I can kinda get it to work if I change the section below but I don't understand why?
  int val = (uS);
                   to
  int val = 8*uS / US_ROUNDTRIP_CM;
AWOL
Quote
...but you're not going to tell us what it is telling you or how what you're seeing differs from what you expect to see.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
