Topic: Looping 15 times (Read 1 time) previous topic - next topic
htetmyetaung1993
Hi everybody,
        Newbie here. How can I make to do something when the program loops 15 times.My program is I am calculating the data, when the data is 15 times runned, i want to reset to 0.
Cybernetician
i++;
if(15==i)
    i=0;
Osgeld
#2
Dec 04, 2012, 04:36 am Last Edit: Dec 04, 2012, 04:38 am by Osgeld Reason: 1
or
   i = 0
   while(i < 15)
       stuff();
        ++i;
or
   for(byte i = 0; i < 15; ++i)
        stuff();
htetmyetaung1993
#3
Dec 04, 2012, 04:37 am Last Edit: Dec 04, 2012, 04:39 am by Jaay Reason: 1
ah....sry brother...I cannot understand...let's say if this is my program...How can i Stop at 15th loop(making datastore 0)?I mean I want to continue the loop but I want to reset the datastore to 0.
float KWH;
     KWH=(float) pow/1000/60;
     Serial.print("Total energy usage for 1 min=");
     Serial.println(KWH,2);
     datastore= datastore + KWH;
     //float finaldata=datastore+KWH;
     Serial.print("DATA=");
     Serial.println(datastore,2);
Cybernetician
i = 0
   while(i < 15)
       stuff();
       i++;
Osgeld
heres your problem, its going to loop 15 times in a matter of milliseconds, if not microseconds... more info is needed
htetmyetaung1993
It's going to loop in a microseconds and it will continue looping..but every 15 times, the data is reset to 0
Osgeld
#7
Dec 04, 2012, 04:41 am Last Edit: Dec 04, 2012, 04:45 am by Osgeld Reason: 1
       float KWH;
    datastore = 0;
its a loop in a loop, above using a for loop (which is what I would do) will go from 0-14 (15 times) exit and start the main loop over again, which starts the for loop again going from 0-14
Cybernetician
float KWH;
     if(15==i)
      datastore=0;
      i=0;
     i++;
declare i global
htetmyetaung1993
thank you brothers....It works
