Topic: Christmas Lights Control System -Arduino Mega - 16 Channel Relay Board (Read 67568 times) previous topic - next topic
RodneyD
Hello zparticle
I saw your postings originally on you-tube and followed you to here. Awesome job and thanks to you I am inspired to do a set of my own this year.
Don't know if you have up graded to Vixen3, but I was not able to get your code to run correctly on Vixen3 until I changed the footer command to "END" instead of 'VIXEN_END" also so had to change the line for the 9 count buffer referring to footer.  Apparently the new Vixen doesn't support that many characters on the footer, I didn't have to change the header.
Once I did that it came to life.
Thanks again for your post and you should probably put some videos of the finished product here
Rodney
richer2003
Hello, I'm having a strange problem here. I have everything connected, the arduino communicates with the relay board. I know this because the self test works. When you connect power to the arduino, it cycles through all the relay switches, 1 - 16. It also does this when you press the reset button on the arduino.  But when i try running a sequence in vixen, nothing happens. I have the COM ports set up correctly, COM2, Baud 57600. I can't seem to figure out why its not communicating.
I've tried using both Vixen 2 and Vixen 3 and no luck. Any help would be awesome, thank you.
dduval1046
hi
same problem
com2 baud 57600
and nothing
test vixen 3
tx for help
uglost
Been beating my head against the wall for a couple of nights now with a very similar issue. When V 2 connects with my mega 2560 the lights (which are on) turn off until the sequence has run, then they come back on. Extremely frustrating. Did you find a resolution for your problem?
Razataz327
Hi all .. it is still summer but I am in full swing of my Christmas build.
I am going to be using led strings and rope light. No pixels this year. I am using arduino 2560 boards connected to many relay boards. Hooking up many arduinos 2560 in parallel to the pc via w5100 ethernet boards to a hub. Have been doing lots of reading the last 6months and this appears to be the easiest for what I am doing.. lights on and off only.
I have found the sketches for the arduino to vixen and relays. I am not having good luck finding information on setting up the w5100 to the pc and vixen. Any help, suggestions and guidance would be appreciated.
Thanks very much
Garnet
CrossRoads
I don't if this helps, but I have relay boards controlled by sending data to a shift register which then controls relay coils, couple form factors: Uno shield, Mega shield, and standalone designed for easy daisychaining.
http://www.crossroadsfencing.com/BobuinoRev17/
Here's a couple videos.
https://www.youtube.com/watch?v=ukRtgLK_b5c
https://www.youtube.com/watch?v=oHTRGXyd3xU
