Offline
Newbie
« on: December 04, 2012, 11:53:04 am » |
Hello, i'm new in the community, i search information about creating a kind of network with more arduino. I use "arduino Mega2560" for the master (or the server?) and arduino uno for the slaves. I think about ethernet, with ethernet shield, but it's expensive because i have to use one shield for each arduino and a ethernet switch I need a full duplex connection, for send information from the master to the slaves and receive status and other information. The rs495 is good, but isn't full duplex.
Excuse for my english if there are some errors, but i'm italian.
Bye, Marco
Logged
California
Offline
Edison Member
« Reply #2 on: December 04, 2012, 07:22:45 pm » |
Bye, Marco
The million dollar question is how far apart are the devices?
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #3 on: December 04, 2012, 07:34:22 pm » |
Excuse for my english if there are some errors, but i'm italian. So is one of my Arduino boards, but it's not nearly as polite and understandable as you are.  Lefty
Logged
nr Bundaberg, Australia
Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
« Reply #4 on: December 04, 2012, 10:45:04 pm » |
The rs495 is good, but isn't full duplex. It can be full- or half-duplex, it's just a matter of how you do it. How many slaves? How far apart? ______ Rob
Logged
Offline
Newbie
« Reply #5 on: December 05, 2012, 02:56:26 pm » |
Hello. I answer at all yours questions:
The max distance between the boards is 5 meters, but it have to work at longer distance, like 10 / 20 m Number of boards is not up to 10.
I can't use I2C because the cables are near motors (for the noise (electrical noise)).
Can i use ethernet connection for more arduino, without any PC?
Thanks, Marco
Logged
Offline
Tesla Member
« Reply #6 on: December 05, 2012, 06:36:04 pm » |
Can i use ethernet connection for more arduino, without any PC? I think so, but I thought you wanted full-duplex. RS-485 will do full- or half-duplex and cost a lot less. ______ Rob
Logged
Offline
Newbie
« Reply #7 on: December 07, 2012, 01:03:26 pm » |
maybe i use rs485... connecting the control pin of the MAX485 to an output of arduino, i can control the direction of messages (TX or RX).. Is it right? Maybe is the better choice... Thanks, Marco Ps: now i do some experiments...
Logged
UK
Offline
Sr. Member
« Reply #8 on: December 18, 2012, 08:16:56 pm » |
NRF24L01+ 2.4GHz 2Mbs modules can be bought in a low power version from China for around £1.30 each. The high power versions, with external antenna, cost about £7.50 each.
Used with the NRF24 and NRF24 Network libraries from maniacbug they may be suitable for your requirements.
The low power ones are certainly cheap enough to buy a few to try out.
Logged
Offline
Brattain Member
« Reply #9 on: December 18, 2012, 11:06:41 pm » |
maybe i use rs485... connecting the control pin of the MAX485 to an output of arduino, i can control the direction of messages (TX or RX).. Is it right? Maybe is the better choice... Thanks, Marco Ps: now i do some experiments...  If you use but one twisted pair then only half-duplex is possible and a need to switch converter chips from send to receive mode is required in your software. However if you run two twisted pairs then true full-duplex is possible and the converter chips are 'hardwired' to send and receive modes. Lefty
Logged
