Loading...
Pages: [1]   Go Down
Author Topic: Arduino/Adafruit Micro Upload problem  (Read 374 times)
Offline Offline
Newbie
View Profile
Hi
Im having trouble uploading blink and any other sketch to my new Arduino/Adafruit board Micro
I'm Using:
Arduino IDE 1.0.2
Windows XP Pro
Windows driver for Micro "usbser.sys"
When i click upload the RX flashes once and then bootloader starts after the board resets,
in the meantime IDE finishes upload but the Micro is still running bootloader
RX on the board then flashes twice and nothing happens, the sketch doesn't load.
I've found what i think is the problem, the port is currently connected to USB port 14 but the
recconnection to port 14 fails after the Micro resets.
here is an excerpt from the upload screen
Code:
Binary sketch size: 4,816 bytes (of a 28,672 byte maximum)
Forcing reset using 1200bps open/close on port COM14
PORTS {COM1, COM14, } / {COM1, COM14, } => {}
PORTS {COM1, COM14, } / {COM1, } => {}
PORTS {COM1, } / {COM1, } => {}
PORTS {COM1, } / {COM1, COM13, } => {COM13, }
Found Leonardo upload port: COM13
E:\Apps\Arduino\arduino-1.0.2\hardware/tools/avr/bin/avrdude -CE:\Apps\Arduino\arduino-1.0.2\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P\\.\COM13 -b57600 -D -Uflash:w:C:\DOCUME~1\RENIER~1\LOCALS~1\Temp\build348112787411548573.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "E:\Apps\Arduino\arduino-1.0.2\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM13
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       1024    8      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: ser_send(): write error: sorry no info avail
so i tried different USB ports and the same thing happened plugged the Micro into port 10
then I get a phantom Leonardo board pop up on port 9 and so on...
So I've updated the windows USB drivers, and I've tried the board on all the USB ports with no luck
Any advice or tricks on how to upload to the Arduino Micro?
Thanx!
Logged
Pages: [1]   Go Up
Print
Jump to:
