Topic: Making Robot Beep When Object Detected? (Read 2393 times) previous topic - next topic
cherryguy
So, I have a working autonomous robot that works with a ping))) sensor and a rear motor and a directional forward motor. I have a piezo speaker laying around, not many specs on it but it works with the example sketch called 'toneMelody'. I'm not much of a code guy but ANY help is appreciated. I have an IF function and I should be able to just add something to it but im not sure what method/function to add. Heres my code.
Code: [Select]
RC Car to Robot Conversion
by Nathan Brown
Used to convert an RC car into a robot that uses a PING sensor to avoid obstacles,
and an Arduino motor shield for motor control.
For more information see:
http://www.instructables.com/id/RC-Car-to-Robot/
Built atop sketch by Randy Sarafan which was
Built atop Ping example code by Tom Igoe
// this constant won't change.  It's the pin number
// of the sensor's output:
const int pingPin = 7;
  //establish motor direction toggle pins
  pinMode(12, OUTPUT); //drive motor -- HIGH = forwards and LOW = backwards
  pinMode(13, OUTPUT); //turn motor -- HIGH = left and LOW = right
  //establish motor brake pins
  pinMode(9, OUTPUT); //brake (disable) the drive motor
  pinMode(8, OUTPUT); //brake (disable) the turn motor
  //Turns brake off for drive motor
  digitalWrite(9, LOW);
  //Turns brake on for turn motor
  digitalWrite(8, HIGH);
  //Sets initial speed of drive motor
  analogWrite(3, 200);
  //Sets initial direction of drive motor
  digitalWrite(12, HIGH);
  // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, inches, cm;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  inches = microsecondsToInches(duration);
  //if objects are less than 12 inches away
  //the robot reverses and turns to the right
  //for 2 seconds
  if (inches < 24){
    //brake drive motor and pause 1/10 second
    digitalWrite(9, HIGH);
    delay(100);
    //setting turn motor
    //turn off brake for turn motor
    digitalWrite(8, LOW);
    //set turn motor direction
    digitalWrite(13, HIGH);
    //activate turn motor
    analogWrite(11, 255);
    //setting drive motor
    //turn off brake of drive motor
    //set drive motor backwards direction
    digitalWrite(12, LOW);
    //activate the drive motor
    //backup for 2 seconds
    delay(2000);
    //stopping
    //brake both motors
  //when nothing is within 12"
  //the robot simply drives forwards
  else{
    //Setting drive motor
    //set drive motor forward direction
    //activate drive motor
  delay(100);
long microsecondsToInches(long microseconds)
  // According to Parallax's datasheet for the PING))), there are
  // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
  // second).  This gives the distance travelled by the ping, outbound
  // and return, so we divide by 2 to get the distance of the obstacle.
  // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
  return microseconds / 74 / 2;
cherryguy
warunasanjaya11
#2
Jul 25, 2012, 12:23 am Last Edit: Oct 19, 2012, 07:19 am by warunasanjaya11 Reason: 1
There are two things I do not understand. The ping))) sensor assesses space using sonar. Not for detecting objects. How do you modify that kind of device for your robot? Also Piezoelectric speakers are often used as beepers in watches and other electronic gadgets. For what purpose are you going to use that kind of device?
I am sorry that I could not help with your code.
Dashquid
fatlossprofessional.co.uk
fatlossprofessional
mobilehelper
securetrip
whichpetcover
google
abc
facebook
craigslist
arduinoPi
#3
Jul 25, 2012, 03:17 am Last Edit: Jul 25, 2012, 03:34 am by arduinopi Reason: 1
if the piezo speaker uses less than 30 mA (almost all do unless it's extremely large) then you can attach the red wire to a arduino pin and the black to ground. to code it you would make the pin a output as usual. to play noise through it you would put this for example.
 tone(piezoPin,2000,500);
this would play a 2000 hertz square wave on the  piezo pin for 500 milliseconds
All of my projects --> http://www.frankmagazu.com/
cherryguy
Thank you so much. I used this code and it worked perfectly, it plays a bit of a two tone beep when it realizes hey, theres 'something' 2 feet ahead of me, let me put my breaks on, play this for 200 milliseconds, wait 300 milliseconds, and play this tone for 300 milliseconds. :) I'm showing it off at work tomorrow :D
chrisandcarleen
I am using your code also with some modifications for 2 drive wheels and a ping)) with a piezo buzzer on detection. usina a uno r3 thruhole a r3 motorshield, an a magician chassis from sparkfun. Here is the modded code. please help me toggle a led on when the piezo sounds.
Code: [Select]
const int pingPin = 6;
const int piezoPin = 5;
  pinMode(12, OUTPUT); //drive motor A -- HIGH = forwards and LOW = backwards
  pinMode(13, OUTPUT); //drive motor B -- HIGH = forwards and LOW = backwards
  pinMode(9, OUTPUT); //brake (disable) the drive A motor
  pinMode(8, OUTPUT); //brake (disable) the drive B motor
  //Turns brake off for drive A motor
  //Turns brake off for drive B motor
  //Sets initial speed of drive 1 motor
  analogWrite(3, 255);
  //Sets initial speed of drive 2 motor
  //Sets initial direction of drive motor 1
  //Sets initial direction of drive motor 2
  digitalWrite(13, LOW);
  //for 2 seconds
  if (inches < 12){
    //make a beep for indication of wall
    //brake drive motors 1 and 2 and pause 1/10 second
    delay(100);
    //setting turn routine
    //turn off brake for drive 1 and 2 motor
    //set drive 1 and 2 motor direction
    //activate drive 1 and 2 motor
    analogWrite(11, 200);
    delay(800);
    //stopping
    //brake both motors
  else{
    //set drive motor 1 forward direction
    //set drive motor 2 forward direction
    //turn off brake of drive motor1
    //turn off brake to drive motor 2
    //activate drive motor 1
    //activate drive motor 2
  delay(100);
the mismatched pwm settins are there to make it drive straight forward.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
