Topic: 12 LED Charlieplexed Snowfall with AtTiny85 (Read 29269 times) previous topic - next topic
strykeroz
If you want, I can dig up my version which (hopefully #) is correct.
# I have not yet made up boards since correcting the footprint.
That would be great - thanks.  And happy to be the lab rat for sure.
Cheers ! Geoff
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
Coding Badly
I have no idea how to extract the one part so I'm attaching the entire library.
PJ-102A is the part number.  It's the Eagle Package for this...
http://www.digikey.com/product-detail/en/PJ-102A/CP-102A-ND/275425
I believe it is the same or very similar to the one you are using.
daaf1984
Time flies....
I should have posted my version long time ago...
So I will do it right now ;)
Ik looks great Strykeroz! You did a great job.
Here are mine:
Measurements: 1x29 Cm
Used components:
• 1 ATTiny 45 @ 8Mhz (SMD SOIC)
• 1 100 nF capacitor (SMD 0805)
• 5 100 Ohm restistors (SMD 0805)
• 20 diffuse cold white LEDs 3mm
daaf1984
I'd just took one that wasn't cleaned up...
You can see the flux around the solder.. ;)
Here an other picture:
darrenmathews
I just read this entire thread. I'm impressed, you guys do awesome work.
How can I get the pcb files to have my own made?
strykeroz
Thanks for your interest.  I've not actually gone back to this project for several months - time flies - have a big box of LEDs sitting beside me here that needs to be assembled before December though  :)
I've just updated github with the EagleCAD schematic and board as well as a zip file that can be sent to Seeed Studios (that's where I had mine made) without any further work.  Note this is still with the bigger pad Adafruit 2.1mm component discussed above and produces a board in the sick-of-beige 50x31mm shape.
Not sure if Dave has published his somewhere as yet...
Cheers ! Geoff
daaf1984
Hi all,
Funny, here just the same, only finished 5 of them and still need something to weatherproof it. ;)
But I did posted my layout on the Fritzing site:
http://fritzing.org/projects/charlieplex-snowfallshooting-star-20-leds
Take a look at it and have fun with it!
Dave
strykeroz
...and still need something to weatherproof it. ;)
Hi Dave
I've had some success with some test circuits embedding them in casting resin (here's a link to the brand I bought but you're sure to have an equivalent local to you).  After several months the resin remains clear, and the circuit protected.  I can see some of the circuitry has changed colour due, I presume, to corrosion where I didn't get all the flux off.
Overall I think that's a method I'll continue to use for weatherproofing LED circuits, and my results can only improve.
Cheers ! Geoff
daaf1984
That's a good idea!! I have clear resin here, so I will do a test run. :D
Did you made a mold or brushed it over?
Dave
strykeroz
Hi Dave, for my tests I actually used small circuits which fit nicely into icecube trays...so I had a mold that did the job just great. Maybe you could form a mold out of Sugru or similar for yours?
Geoff
daaf1984
After some considerations, I decided to use clear tubing for weatherproofing.
Just seal the bottom and top with acrylic rod.
If something occurs, it's easier to re-solder, than using resin.
