« on: December 04, 2012, 03:18:21 pm » |
I've made a function to write a line to the log; void wltl(String logmessage) { // write line to log if(DEBUG){ Serial.println(String(hour()) + ":" + String(minute()) + ":" + String(second()) + " " + logmessage); } }
But I get some strange results when I run this. I call it like this; wltl("SSID: " + String(WiFi.SSID()));
Thanks for your help guys...!
UK
What a host of balls she had seen: gaity, the brass buttons...
« Reply #1 on: December 04, 2012, 03:24:18 pm » |
Strings are evil. Don't use them.
Whenever possible, use character arrays (char *).
« Reply #2 on: December 04, 2012, 03:27:43 pm » |
Is that because they can't be of variable lenght?,
And with a char array, how exactly would you write the log routine?
Thanks!
UK
« Reply #3 on: December 04, 2012, 03:37:03 pm » |
They can be of variable length, but they stomp all over your memory. Not nice. For your function, I would do something like: void wltl(char *facility, char *logmessage) { // write line to log if (DEBUG) { Serial.print(hour()); Serial.print(":"); Serial.print(minute()); Serial.print(":"); Serial.print(second()); Serial.print(" "); Serial.print(facility); Serial.print(": "); Serial.println(logmessage); } }
wltl("SSID", WiFi.SSID());
« Last Edit: December 04, 2012, 03:48:03 pm by majenko »
« Reply #4 on: December 04, 2012, 04:03:39 pm » |
But this forces me to allways pass 2 arguments to the function, I sometimes just want to ' wltl("blaaat"); Without having to: wltl("blaaat" ,""); To make it all work. Is there not a way to combine the string before passing it to the function?
« Last Edit: December 04, 2012, 04:06:04 pm by Lectere »
« Reply #5 on: December 04, 2012, 04:04:18 pm » |
And why exactly are strings evil?
New Jersey
« Reply #6 on: December 04, 2012, 04:09:40 pm » |
They use C's memory allocation routines behind the scenes. There is a bug in the implementation of free, which will eventually use all your memory and crash. Even if the bug were fixed, there would still be a risk of problems caused by heap fragmentation. C arrays of char are a much better idea.
UK
« Reply #7 on: December 04, 2012, 04:22:08 pm » |
But this forces me to allways pass 2 arguments to the function, I sometimes just want to ' wltl("blaaat"); Without having to: wltl("blaaat" ,""); To make it all work. Is there not a way to combine the string before passing it to the function? There is, but it involves more memory, and is pretty pointless anyway. You could overload: void wltl(char *facility, char *logmessage) { // write line to log if (DEBUG) { Serial.print(hour()); Serial.print(":"); Serial.print(minute()); Serial.print(":"); Serial.print(second()); Serial.print(" "); if(facility) { Serial.print(facility); Serial.print(": "); } Serial.println(logmessage); } }
void wltl(char *logmessage) { wltl(NULL,logmessage); }
« Reply #8 on: December 04, 2012, 04:29:35 pm » |
Okey, But what if I want to pass 5 arguments; wltl("IP Address: " + String(ip[0]) + "." + String(ip[1]) + "." + String(ip[2]) + "." + String(ip[3])); wltl("Signal strenght (RSSI): " + String(WiFi.RSSI()) + "dBm");
Do I have to write 5 overload routines?
« Reply #9 on: December 04, 2012, 04:31:57 pm » |
It this all because you are passing a pointer to the string, and not the actual string?
UK
« Reply #10 on: December 04, 2012, 04:44:36 pm » |
Yep, you are passing the pointer. You can construct a string using sprintf: for example: char temp[100];
sprintf(temp,"%d:%d:%d %s: %s",hour(),minutes(),seconds(),facility,logmessage);
« Reply #11 on: December 04, 2012, 05:42:02 pm » |
You are not passing five arguments, you are passing one argument and using the overloaded + operator of the String class to construct that argument. Stop putting that operator in the argument, either construct your new string first, or pass multiple strings as multiple arguments.
« Reply #12 on: December 04, 2012, 05:50:14 pm » |
Majenko, Drone, thanks a lot!
« Reply #13 on: December 04, 2012, 06:03:29 pm » |
I get this error tho; error: cannot convert 'StringSumHelper' to 'char*' for argument '1' to 'void wltl(char*)' void wltl(char *logmessage) { // write line to log if(DEBUG){ Serial.print(hour()); Serial.print(":"); Serial.print(minute()); Serial.print(":"); Serial.print(second()); Serial.print(":"); Serial.println(logmessage); } } And I call it with this; wltl("IP Address: " + String(ip[0]) + "." + String(ip[1]) + "." + String(ip[2]) + "." + String(ip[3])); The WLTL routine is suppose to make live easier, to centrally controll weather or not to write log items to disc, or add time stamps. If I first have to construct a string, and then pass it, I might as well just plot it... I'm a VB guy, I don't understand all this fuzz.
« Last Edit: December 04, 2012, 06:06:10 pm by Lectere »
« Reply #14 on: December 04, 2012, 06:10:56 pm » |
I get this error tho; error: cannot convert 'StringSumHelper' to 'char*' for argument '1' to 'void wltl(char*)' void wltl(char *logmessage) { // write line to log if(DEBUG){ Serial.print(hour()); Serial.print(":"); Serial.print(minute()); Serial.print(":"); Serial.print(second()); Serial.print(":"); Serial.println(logmessage); } } And I call it with this; wltl("IP Address: " + String(ip[0]) + "." + String(ip[1]) + "." + String(ip[2]) + "." + String(ip[3])); The WLTL routine is suppose to make live easier, to centrally controll weather or not to write log items to disc, or add time stamps. How can you convert a complex object like String to a char pointer? You can't. "ABC" is a const char[3]. Get the plus operators out of your argument, as I said earlier. Consider the following, as has already been indicated to you by majenko (get rid of String): char logmsg[100]; sprintf(logmsg, "IP Address: %d.%d.%d.%d", ip[0], ip[1], ip[2], ip[3]);
wltl(logmsg);
Your life will be simpler, and your sketch will be smaller.
