Topic: how to control a camera with video n Image mode both.help me about it completly (Read 2064 times) previous topic - next topic
engr_m_ahmed
i have a project of arduino to interface with PC n sensors.
actually its a security survelliance project.
An IR sensor and Metal Sensor is mounted on a Walk Through gate.
If any human enters through the gate the IR sensor will activate and send a signal to Arduino. now arduino will send a signal to PC to switch ON camera then capture a picture.
If the man possess any gun, then IR and metal detector both will send signal to arduino
now arduino will send signal to PC so that the camera will start recording a video of that person
Image processing will also be used in this project to scan that person and rotate the camera according the movement of that person.
plzzzz you all are requested to help me in this project,
i want to know the code of Arduino, as well as complete method that how to complete this project.
furthermore, tell me the software of computer to use and which camera should i use to work on this project.
i have already made an IR sensor and im designing metal detector. i have only 3 weeks left so plzzz help me as soon as possible so that i may complete this project with in time.
AWOL
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
engr_m_ahmed
its a group project. but all my group partners are totally nil
so i have to do it alone
dxw00d
AWOL meant that this should probably have been posted in the Gigs and Collaborations forum.
http://arduino.cc/forum/index.php/board,26.0.html
zoomkat
Quote
its a group project. but all my group partners are totally nil so i have to do it alone
You should talk to whoever assigned you the project and explain the lack of help from your partners.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
PaulS
Quote
What do you need help with? Reading the IR sensor? That's trivial. Reading the metal sensor? What is a metal sensor? If it is a switch that indicates whether the gate is opened or closed, reading it is trivial.
Quote
No, it won't. The Arduino will send some data to the PC, via the serial port. Doing that is trivial.
Some application needs to be monitoring the serial port. That application will have some expectations about the data that tells it to start or stop doing something. Determining what those expectations are may be as easy as RTFM or it may involve reading the source code. Or, it may not be possible to determine.
But, since we don't know what that application is, we can't help you.
Quote
The image processing will not be done on the Arduino. The pan, tilt, and zoom are not likely to be done by the PC. The PC will need to send data to the Arduino. The Arduino will need to parse that data and move the servos.
Since you haven't mentioned what servos you have, how they are used to move the camera, or what application is sending what data that needs to be parsed, you're pretty much on your own here.
Quote
You have not provided near enough detail yet. Lots of people here will be willing to help, if you stop blaming others for your problems and answer the questions that you are asked. And, if you show a little effort.
