Author Topic: String numeric output with V-USB HID  (Read 1703 times)
Atlanta, USA
AKA: Ray Burne
This discussion centers on code by:
http://www.obdev.at/products/vusb/license.html
http://code.rancidbacon.com/ProjectLogArduinoUSB
www.avdweb.nl/arduino/hardware-interfacing/temperature-measurement.html
et al.
ARDUINO 1.0.1
I have built many V-USB toys using the ATtiny85.  They all work, they are all fun projects, but they do require that you drop down to C code and use the command line to compile, link, and flash the '85.  Rancid Bacon's V-USB library for Arduino http://code.google.com/p/vusb-for-arduino/ provides a great enhancement and is easy to utilize, especially the samples he provides.
However, as a HID keyboard emulator, it is awkward to send data to the PC on a keystroke by keystroke method.  As an example of this difficulty, I took on the task of reading the internal temperature of the ATmega328P-PU on the UNO from the code library by Albert van Dalen (AvdWeb link above.)  I pondered the issues for a while and considered two generalized methods; character array or Strings.
The code below needs to be polished, but works.  The hardware required is minimal, two zener diodes, and three resistors.  Please see refer to Rancid Bacon's site for the hardware build.  I built mine on a UNO prototype shield from Adafruit.  The nice thing about this is that you can run both the Arduino GUI and the USB HID port simultaneously.  (Just do not connect +5 on the port being used for HID... ground, D+ and D- are all that is needed and reference the +5 back to the UNO main board.)
PLEASE NOTE that my ChipTemp.h file is local for quick changes, not in my user library.
I used a pushbutton on pin 10 so that the program would not start spooling characters across HID after I programmed the UNO and before I could change focus to Notepad with my mouse!  Program the UNO, open Notepad and/or click in Notepad to set focus, then press the button on pin 10 to start the program.  I cannot attest to the accuracy of the temperature, but I did one test where the UNO was off for an hour and then powered on.  The UNO started with a reading near room temperature and the indication was that the temperature climbed higher, 6F degrees total, over a period of about 5 minutes.  This leads me to believe that the temperature diode is monitoring the internal temperature.
I had to "mess around" with the ChipTemp.h file and change the calibration values before I could get a decent room temperature.  Using a different 'known good' 386P chip on a breadboard resulted in a large change in the calibration value.  Your results may vary.
Obviously you can use any temperature sensor and simply change the assignment in the line
sOut.concat(String(chipTemp.fahrenheit()));
The String object is very versatile in Arduino, so have a look at the Reference page
http://arduino.cc/en/Reference/StringObject  Have a look at the UsbKeyboard.h file for all of the defined key combinations... this will allow you to build alphanumeric strings for output.
Have fun.
Update:
Here is the same with alphanumeric output:
// MRB 20121201 Tested using String Object
// UNO Profile: Binary sketch size: 7,694 bytes (of a 32,256 byte maximum)
#include "UsbKeyboard.h"
#include <avr/pgmspace.h>
#include "./ChipTemp.h"
#define BUTTON_PIN 10
ChipTemp chipTemp;
String sOut;
void delayMs(unsigned int ms) {    // Safe delay
  for (int i = 0; i < ms; i++) {
    delayMicroseconds(1000);
  pinMode(BUTTON_PIN, INPUT);
  digitalWrite(BUTTON_PIN, HIGH);
  TIMSK0&=!(1<<TOIE0);            // disable timer 0 overflow interrupt (used for millis)
  while (digitalRead(BUTTON_PIN) != 0){
      UsbKeyboard.update();
      delayMs(20);
    digitalWrite(13, !digitalRead(13));    // flash LED
    sOut = "INTERNAL CHIP TEMP = ";
    sOut.concat(String(chipTemp.fahrenheit()));  // chipTemp.celsius() | chipTemp.deciCelsius()  | chipTemp.fahrenheit() | chipTemp.deciFahrenheit()
    KeyStrokeAlpNum(sOut);
    delayMs(20);    // Interrupt safe since V-USB utilizes interrupt
void KeyStrokeAlpNum(String Sc){
    int sPoint = Sc.length();          // Pointer to end-of-String (inc. null)
    for (int x = 0; x < sPoint; x++){
      int y = x + 1;
      if (Sc.substring(x, y) == "A"){  // substring single character: y = x+1
          UsbKeyboard.sendKeyStroke(KEY_A, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "B"){
          UsbKeyboard.sendKeyStroke(KEY_B, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "C"){
          UsbKeyboard.sendKeyStroke(KEY_C, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "D"){
          UsbKeyboard.sendKeyStroke(KEY_D, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "E"){
          UsbKeyboard.sendKeyStroke(KEY_E, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "F"){
          UsbKeyboard.sendKeyStroke(KEY_F, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "G"){
          UsbKeyboard.sendKeyStroke(KEY_G, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "H"){
          UsbKeyboard.sendKeyStroke(KEY_H, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "I"){
          UsbKeyboard.sendKeyStroke(KEY_I, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "J"){
          UsbKeyboard.sendKeyStroke(KEY_J, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "K"){
          UsbKeyboard.sendKeyStroke(KEY_K, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "L"){
          UsbKeyboard.sendKeyStroke(KEY_L, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "M"){
          UsbKeyboard.sendKeyStroke(KEY_M, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "N"){
          UsbKeyboard.sendKeyStroke(KEY_N, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "O"){
          UsbKeyboard.sendKeyStroke(KEY_O, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "P"){
          UsbKeyboard.sendKeyStroke(KEY_P, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "Q"){
          UsbKeyboard.sendKeyStroke(KEY_Q, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "R"){
          UsbKeyboard.sendKeyStroke(KEY_R, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "S"){
          UsbKeyboard.sendKeyStroke(KEY_S, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "T"){
          UsbKeyboard.sendKeyStroke(KEY_T, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "U"){
          UsbKeyboard.sendKeyStroke(KEY_U, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "V"){
          UsbKeyboard.sendKeyStroke(KEY_V, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "W"){
          UsbKeyboard.sendKeyStroke(KEY_W, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "X"){
          UsbKeyboard.sendKeyStroke(KEY_X, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "Y"){
          UsbKeyboard.sendKeyStroke(KEY_Y, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == "Z"){
          UsbKeyboard.sendKeyStroke(KEY_Z, MOD_SHIFT_LEFT);
       else if (Sc.substring(x, y) == " "){
          UsbKeyboard.sendKeyStroke(KEY_SPACE);
       else if (Sc.substring(x, y) == "1"){
          UsbKeyboard.sendKeyStroke(KEY_1);
       else if (Sc.substring(x, y) == "2"){
          UsbKeyboard.sendKeyStroke(KEY_2);
       else if (Sc.substring(x, y) == "3"){
          UsbKeyboard.sendKeyStroke(KEY_3);
       else if (Sc.substring(x, y) == "4"){
          UsbKeyboard.sendKeyStroke(KEY_4);
       else if (Sc.substring(x, y) == "5"){
          UsbKeyboard.sendKeyStroke(KEY_5);
       else if (Sc.substring(x, y) == "6"){
          UsbKeyboard.sendKeyStroke(KEY_6);
       else if (Sc.substring(x, y) == "7"){
          UsbKeyboard.sendKeyStroke(KEY_7);
       else if (Sc.substring(x, y) == "8"){
          UsbKeyboard.sendKeyStroke(KEY_8);
       else if (Sc.substring(x, y) == "9"){
          UsbKeyboard.sendKeyStroke(KEY_9);
       else if (Sc.substring(x, y) == "0"){
          UsbKeyboard.sendKeyStroke(KEY_0);
      UsbKeyboard.sendKeyStroke(KEY_ENTER);
      // Return
Notepad display:
INTERNAL CHIP TEMP  78
Note: The "=" does not display because I have not mapped this keystroke!  The pix shows the simplicity of the USB interface... I have both USB ports active during development (but only 1 active +5V source.)
« Last Edit: December 08, 2012, 11:29:18 am by mrburnette » Logged
Atlanta, USA
AKA: Ray Burne
More pixs
A UNO stick made with the rancidbacon reference circuit.  The USB-Serial converter is fitted to the board for programming via the Arduino GUI and then removed.  Alternately, the uC could be removed and flashed with any ISP burner (generally overwrites bootloader, however.)
The strip of protoboard was from Radio Shack... old stock: 910-3804 DIP-Small
The USB-serial adapter is from eBay.  I have cut the 3.3V line and the Reset line (not an Arduino reset.) One adapter can be used with many sticks... no reason to throw $2.20 U.S. to the wind to dedicate a serial-USB since the HID connector will provide for serial output.  Yes, you could run both USB ports simultaneously (but only use HID +5 and do not connect the CP21xx +5... only Ground reference, Tx, and Rx.  Such a configuration could be used to use the Com-USB port for eeprom configuration, customization menu, sensor offsets, one-time keyboard input, etc. and all the pertinent user output could come over HID.  Or, the Com serial could be used for diagnostics, etc.
The key takeaway is that USB-Com requires an INF and driver for Windows but HID keyboard is accepted without user driver installation... the OS will load native drivers automatically under Windows, Linux, iOS... even some tablets with USB support.
I did cover the bottom of the hand-soldering of parts with HFT quick setting epoxy to allow the stick to be handled without fear of being overly gentle.
- Ray
« Last Edit: December 07, 2012, 10:59:17 am by mrburnette » Logged
Atlanta, USA
AKA: Ray Burne
HID keyboard appears just as any USB keyboard, so therefore it can be copied to a text file in a command window!  This is pretty cool, since the command:  COPY CON filename.txt <ENTER> will start the process.  You must terminate the file recording with a Ctrl Z... either from the HID keyboard or the primary keyboard.
Such may be desirable when the accepting program has limitations on the input data, either size or timeouts.  The data can be written to a file, a utility used to break the file into manageable pieces, etc.  Also, this technique would be appropriate for re-purposing an OLD PC with low RAM capabilities (WinXP with no other applications running) ... since the file size is roughly the character size of input, the buffering could go on for a very long time if backup power was provided.
I have not tried it, but I understand that there are DOS drivers for USB-HID available... so perhaps even Windows would not be required.  Also, some newer BIOS will process BOOT HID, but I have not tried this either.  I do not even know if I have a copy of DOS to try... maybe an old Windows 98SE?  Test for future.
- Ray
« Last Edit: December 07, 2012, 07:54:37 pm by mrburnette » Logged
Atlanta, USA
AKA: Ray Burne
Example of reading all 6 of the default analog (port C0 - C5) values:
(Still uses pushbutton on PIN 10 to start the process to give me time to setup the notepad focus in Windows)
Updated to show use of for() loop construct:
// 20121208 Runs on UNO-clone strip board
// UNO Profile: Binary sketch size: 7,486 bytes (of a 32,256 byte maximum)
//const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
int sensorValue = 0;        // value read from the pot
int outputValue = 0;        // value output to the PWM (analog out)
String sOut;
void delayMs(unsigned int ms) {    // Safe delay helper function
  // Disable timer0 since it can mess with the USB timing. Note that
  // this means some functions such as delay() will no longer work.
  // Clear interrupts while performing time-critical operations
  cli();
  // Force re-enumeration so the host will detect us
  usbDeviceDisconnect();
  delayMs(250);
  usbDeviceConnect();
  // Set interrupts again
  sei();
      delayMs(20);
    for (int i = 0; i < 6; i++){
      // read the analog in value:
      sensorValue = analogRead( i );
      // Label the value
      sOut = "ANALOG";
      // String the characters together
      sOut.concat(String(i));
      sOut.concat(" ");
      sOut.concat(String(sensorValue));
      // spool the combined strings
    delayMs(5000);    // Interrupt safe since V-USB utilizes interrupt
      int y = x + 1;
      // Return
Example of the resulting output in notepad:
(I walked each analog pin with a 10K resistor to ground... other pins were floating.)
ANALOG0  0
ANALOG1  120
ANALOG2  220
ANALOG3  265
ANALOG4  294
ANALOG5  294
ANALOG0  296
ANALOG1  0
ANALOG2  109
ANALOG3  213
ANALOG4  268
ANALOG5  282
ANALOG0  313
ANALOG1  315
ANALOG2  0
ANALOG3  120
ANALOG4  217
ANALOG5  261
ANALOG0  312
ANALOG1  332
ANALOG2  313
ANALOG3  0
ANALOG4  128
ANALOG5  216
ANALOG0  290
ANALOG1  322
ANALOG2  320
ANALOG3  312
ANALOG4  0
ANALOG5  120
ANALOG0  120
ANALOG1  234
ANALOG2  272
ANALOG3  297
ANALOG4  282
ANALOG5  0
« Last Edit: December 08, 2012, 01:04:52 pm by mrburnette » Logged
Atlanta, USA
AKA: Ray Burne
Now on Instructables:
http://www.instructables.com/id/Arduino-Digital-and-Analog-logging-using-V-USB/?ALLSTEPS
The push button on pin 10 has been removed and the code edited to wait 10 seconds after the HID device is recognized before sending characters.
ANALOG0 426
ANALOG1 401
ANALOG2 378
ANALOG3 373
ANALOG4 362
ANALOG5 445
DIGITAL 3L 6L 7L 8H 9H 10H 11H 12H
// 20121210 Runs on UNO-clone strip board using 328P-PU
// UNO Profile: Binary sketch size: 8,260 bytes (of a 32,256 byte maximum)
// When freeram function is uncommented: FREE RAM 1506
// #define BUTTON_PIN 10
String sOut;
int freeRam () {
  extern int __heap_start, *__brkval;
  int v;
  return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
  // pinMode(BUTTON_PIN, INPUT);
  // digitalWrite(BUTTON_PIN, HIGH);
  cli();
  delayMs(250);
  usbDeviceConnect();
  sei();
  pinMode(3, INPUT);      //  sets the digital pin 3 as input
  pinMode(6, INPUT);      //  sets the digital pin 6 as input
  pinMode(7, INPUT);      //  sets the digital pin 7 as input
  pinMode(8, INPUT);      //  sets the digital pin 8 as input
  pinMode(9, INPUT);      //  sets the digital pin 9 as input
  pinMode(10, INPUT);      // sets the digital pin 10 as input
  pinMode(11, INPUT);      // sets the digital pin 11 as input
  pinMode(12, INPUT);      // sets the digital pin 12 as input
  for (int i = 0; i < 500; i++){            // 10 second delay in lieu of using Button press on pin 10
    // while (digitalRead(BUTTON_PIN) != 0)
     delayMs(20);
  // Tell them who we are...
  sOut = "SIMPLE HID DATA LOGGER USING VUSB WWW.OBDEV.AT";
  sOut = "ARDUINO PORT BY RANCIDBACON.COM";
  sOut = "UNO 328P EXAMPLE - RAY BURNETTE C20121210";
      // Label the value
      sOut = "ANALOG";
      sOut.concat(" ");
    sOut = "DIGITAL ";
    if (digitalRead(3) == HIGH){
      sOut.concat("3H ");
        sOut.concat("3L ");
    if (digitalRead(6) == HIGH){
      sOut.concat("6H ");
        sOut.concat("6L ");
    if (digitalRead(7) == HIGH){
      sOut.concat("7H ");
        sOut.concat("7L ");
    if (digitalRead(8) == HIGH){
      sOut.concat("8H ");
        sOut.concat("8L ");
    if (digitalRead(9) == HIGH){
      sOut.concat("9H ");
        sOut.concat("9L ");
    if (digitalRead(10) == HIGH){
      sOut.concat("10H ");
        sOut.concat("10L ");
    if (digitalRead(11) == HIGH){
      sOut.concat("11H ");
        sOut.concat("11L ");
    if (digitalRead(12) == HIGH){
      sOut.concat("12H");
        sOut.concat("12L");
    // sOut = "FREE RAM ";              // Uncomment next 4 lines to check for memory leaks
    // sOut.concat(String(freeRam()));
    // KeyStrokeAlpNum(sOut);
    // UsbKeyboard.sendKeyStroke(KEY_ENTER);
      int y = x + 1;
      if (Sc.substring(x, y) == "H"){  // substring single character: y = x+1
       else if (Sc.substring(x, y) == "."){
          UsbKeyboard.sendKeyStroke(55);
       else if (Sc.substring(x, y) == "-"){
          UsbKeyboard.sendKeyStroke(45);
       else if (Sc.substring(x, y) == "A"){
      // Return
- Have fun, Ray
« Last Edit: December 11, 2012, 10:54:09 am by mrburnette » Logged
Atlanta, USA
AKA: Ray Burne
Note:
Only a subset of keyboard codes were defined by Rancidbacon in his .H file.
If you need to add a value not in the include file list, please refer to:
http://www.usb.org/developers/devclass_docs/Hut1_11.pdf
Section 10, Table 12 : Keyboard/Keypad Page
