Loading...
Pages: [1]   Go Down
Author Topic: Serial Port will not go into command mode after entering $$$  (Read 462 times)
Offline Offline
Newbie
View Profile
I am trying to use my serial port in the Arduino IDE to set the IP protocol on my Arduino Wifly shield.  When I go to enter "$$$" to place the serial port into command mode, nothing happens.  Any thoughts?
Logged
Netherlands
Online Online
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
post your code ?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
Code:
#include "WiFly.h"
char passphrase[] = "268435459115635028";
char ssid[] = "Verizon AC30 E753";
  WiFly.begin();
  if (!WiFly.join("ssid", "passphrase"))
     // Handle the failure
  // Rejoice in your connection
  Serial.print("IP: ");
  Serial.println(WiFly.ip());
Logged
Offline Offline
Newbie
View Profile
Would I need to connect the two pins RX and TX?
Logged
Offline Offline
Newbie
View Profile
I also tried typing in $$$ into Teraterm and no success.
Logged
Netherlands
Online Online
Tesla Member
View Profile
should
not be
if (!WiFly.join(ssid, passphrase))
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
Yes, I changed that now but it still does not allow it to connect.  I'm pretty sure I need to change the ip protocol on the wifly shield so that it can connect to the 3G hotspot card but when I enter $$$ into the serial monitor and press enter, nothing happens.
Logged
Netherlands
Online Online
Tesla Member
View Profile
Your code nowhere reads anything from Serial so how should it react?
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
I guess I'm just confused as to what I would do with the data (to put it into command mode) once I have read the serial data.
Logged
Netherlands
Online Online
Tesla Member
View Profile
Quote
How should we know? it is your application smiley-wink
what is the goal of your project?
what are your requirements?
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
Currently, I just want to be able to connect my arduino wifly shield to my 3G Wifi Mobile Card.  From the research I have done, it looks like you just have to type "$$$" into the serial monitor and press enter to send it into command mode.  Nothing is mentioned about having code to read from the serial port.
Logged
Offline Offline
Newbie
View Profile
Also, I'm using IDE 0022.  Not sure if that helps at all.
Logged
Pages: [1]   Go Up
Print
Jump to:
