Loading...
Pages: [1]   Go Down
Author Topic: driving 11v 7 segment led displays  (Read 654 times)
Offline Offline
Jr. Member
View Profile
I need to drive 6 - 3" 7 segment led displays.  Each segment has a forward voltage of 11v.  The approach I would take with a regular 7 segment would be to use a 7447 but since the voltage requirement is higher I am not sure what to do.  Should I use a 7447 to drive transistors that will drive the leds?  Any tips are appreciated!
Logged
Offline Offline
Edison Member
View Profile
Quote
Certainly one option: it keeps the code base small.
Logged
Offline Offline
Jr. Member
View Profile
Any recommendation on what transistor to use?
Logged
Offline Offline
Edison Member
View Profile
That's a function of the current needing to light up the leds.
Logged
Offline Offline
Jr. Member
View Profile
5-10mA
Logged
Offline Offline
Edison Member
View Profile
In that case, any of those small signal bjt / mosfet will work.
Logged
Offline Offline
Jr. Member
View Profile
Thanks dhenry...  As a novice, I appreciate your knowledge greatly.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Just use the SN7447 as normal, it will drive up to 30V - its an open-collector device so only sinks current (upto 40mA per segment).
Note the SN74LS47 has less voltage and current drive (15V, 24mA), but should still handle your displays.
Logged
Offline Offline
Jr. Member
View Profile
I was actually looking through the data sheet today and noticed that.  I didn't realize they went up to 30v.  Thanks!
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
The 7447 does not have any latching function. I'd go with 83 cent (avnet.com) TPIC6B595 shift register with high current/high voltage open drain output.
Daisy chain 6 of them, 6 SPI.transfer()s to update the display.
MOSFET outputs will run a lot cooler than 7447 as well.
Create an array with your font, pull that data & write it out.
Code:
// update display
digitalWrite(SS, LOW);
for (x=0; x<6; x=x+1){
SPI.transfer(fontArray[x]);  // fontArray[] = {B00111111, B00000110, }; etc with 1 = segment on
digitalWrite(SS, HIGH);
[code]
[/code]
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
I think the OP is talking about a muliplexing the displays so only one 7447 is needed (but 6 high-side switches needed to do the digits?).
Given the high-side isn't 5V then the digit switching would be a bit tricky.  Using one chip per digit might make sense (although a lot more
complex wiring-wise compared to a multiplexed set up).  If so then constant-current low-side drivers would be more useful than the TPIC6B595
to avoid 42 resistors that would be needed.  One 16-output constant current driver per two digits would mean only 3 chips and 3 pins to drive
everything (but the bcd to 7-segment conversion would need to be in software).  I think a 12V supply might just be enough overhead?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
"(although a lot more complex wiring-wise compared to a multiplexed set up). "
Really. I would have considered that less complex. Wire up the TCIPs with SCK, SS, in parallel, daisy chain the data line.
Use  for_next loop to 6 SPI.transfers to send the data out.
This board here will do most of the job for you. Just add the digits and current limit resistors.
Logged
Pages: [1]   Go Up
Print
Jump to:
