Topic: Servo Motor Control (Read 952 times) previous topic - next topic
tjdichoso
Hello Friends,
I have a project where I have some externally powered servos. The arduino is powered separately and I am using it to control the position of the motors, which I already understand to do. I'm trying to make a wired controller connected to the arduino so that when a click button is  pressed, it would execute lines of code to control the servos. I'm not sure what I'm looking for code-wise or how the click button should be wired to the arduino.
Any suggestions?
I also, want to eventually make the controller wireless. Maybe just over RF or bluetooth. Any suggestions?
Thanks!
HazardsMind
Start with the basic servo examples, knob and sweep, and maybe the button examples and go from there.
If you get stuck, come back and we'll help you.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
zoomkat
Test code for two buttons controling a servo.
//zoomkat servo button test 12-29-2011
#include <Servo.h>
int button1 = 4; //button pin, connect to ground to move servo
int press1 = 0;
int button2 = 5; //button pin, connect to ground to move servo
int press2 = 0;
Servo servo1;
  pinMode(button1, INPUT);
  pinMode(button2, INPUT);
  servo1.attach(7);
  digitalWrite(4, HIGH); //enable pullups to make pin high
  digitalWrite(5, HIGH); //enable pullups to make pin high
  press1 = digitalRead(button1);
  if (press1 == LOW)
    servo1.write(170);
  press2 = digitalRead(button2);
  if (press2 == LOW)
    servo1.write(10);
tjdichoso
Thanks!
In this programming scheme, do I need to to run the power through the button?
zoomkat
Thanks! In this programming scheme, do I need to to run the power through the button?
No, power is supplied to the buttons from the pins by making the pins high.
tjdichoso
I'm having trouble getting this to work still..
Here is my wiring setup:
Pin 7 to servo motor, motor powered separately
pin 5 to push button (https://www.sparkfun.com/products/9190) to ground
Pin 4 to push button to ground
Is the problem the type of button I'm trying to use?
tjdichoso
Ok, when I hold the button wired to pin 4, the motor rapidly wiggles back and forth. When I press and hold the other button, nothing happens at all.. I'm trying to get it so that once, say button four is triggered, I can use the sweep function to have the servo move to various positions without having to hold the button down.
PeterH
What code are you running? Have you got Serial.print statements in place so that you can confirm your button presses are being detected correctly?
I only provide help via the forum - please do not contact me for private consultancy.
