Author Topic: 1 inch or smaller color display?  (Read 657 times)
Kentucky
Is there a color display that is 1 inch square or less?
« Last Edit: December 04, 2012, 08:49:33 pm by shaneshuford » Logged
SE USA
@ssh0le
yes
Boston area, metrowest
1.1" x 1.1" small enough?
http://www.nkcelectronics.com/rgb-lcd-65k-color-module-philips-pcf8833-comp658833.html
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
0.96" OLED display on a B.O.B... "http://adafruit.com/products/684". A little pricey compared to the larger displays (320 X 240, 3.2" 65K color from Amazon for $18.98 with sd card and a good sensitive touch screen too).
Bob
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Kentucky
on a better note.
whats the smallest projector you can get? something like this:
http://howsolve.blogspot.com/2010/07/3m-reveals-worlds-smallest-micro.html
i'm not that great with arduino library coding.
so it would be nice if it already had a library for it.
"Thursday, July 1, 2010" Nearly 2.5 years ago. Likely something even smaller is out by now smiley-wink
Anaheim CA.
In My wanderings and in all of my reading this is the first I knew of it. I can't imagine that it could exist in a cell phone due to power supply considerations for the source of illumination. I'd buy one in a heartbeat, were it available and inexpensive < $100.00.. The Ultimate GLCD...
Bob
France
And this one?
4D Systems µOLED-96-G2(SGC) with embedded graphic controller. Only three pins required, RX + TX + reset!
Main benefit is you can use the Serial_LCD Library Suite with high level commands.
Website: http://embeddedcomputing.weebly.com/serial-lcd.html
Download: http://embeddedcomputing.weebly.com/download.html
Forum: http://arduino.cc/forum/index.php/topic,60802.90.html
avenue33
