Loading...
Pages: [1]   Go Down
Author Topic: SD writer code ultra light  (Read 1090 times)
Santiago
Offline Offline
Newbie
Hello Arduino World!
View Profile
Hello friends!
I need your help. I have 25,142 byte used (of 32,256 byte available) for my code.
So, I need to write on SD a datastream [name, time, value x8] in a .csv file, but just with 7 kb smiley-sad
there's someone can help with this?
Really really thanks for your help! smiley-grin i've tried all day and i cant do it (SD or SdFat)   smiley-cry
Logged
Me
\{end}
Santiago
Offline Offline
Newbie
View Profile
Two examples:
Code:
#include <SdFat.h>
SdFat sd;
SdFile myFile;
  if (!sd.begin(4, SPI_HALF_SPEED)) sd.initErrorHalt();
  if (!myFile.open("test.txt", O_RDWR | O_CREAT | O_AT_END)) {
    sd.errorHalt("opening test.txt for write failed");
  myFile.println("testing 1, 2, 3.");
  myFile.close();
10,842 bytes smiley-sad
Code:
#include <SD.h>
File myFile;
void setup(){
   pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    myFile.close();
void loop(){
12,856 bytes smiley-sad
Thxs y gracias again! smiley-grin
Logged
Me
\{end}
0
Offline Offline
Edison Member
Arduino rocks
View Profile
I wrote a small library for Standard SD cards, 2 GB or less, formatted FAT16. The library is here http://code.google.com/p/fat16lib/downloads/list.
The total size of this sketch is 7126 bytes on an Uno with Arduino 1.02.
Code:
#include <Fat16.h>
SdCard card;
Fat16 file;
  if (!card.init() ||
    !Fat16::init(&card) ||
    !file.open("MYFILE.TXT", O_APPEND | O_CREAT | O_WRITE)) {
    Serial.println("init failed");
    while(1);
  file.println("append 1, 2, 3");
  file.close();
  Serial.println("Done");
void loop() {}
It should add less than 7 KB to your sketch since the following sketch take 1928 bytes.
Code:
void loop() {}
Logged
0
Offline Offline
God Member
Get Bitlash: http://bitlash.net
View Profile
That is great.  I will try it with Bitlash and celebrate the extra free RAM.  Thank you.
Are there any differences in the API compared with its bigger cousin that one should be aware of?
Best,
-br
Logged
Santiago
Offline Offline
Newbie
View Profile
Mr fat16lib:
Check this! "Binary sketch size: 29,932 bytes (of a 32,256 byte maximum)"
Thank you so much!
Logged
Me
\{end}
Santiago
Offline Offline
Newbie
View Profile
Well well now i'm working with your code, but...
I'm using the LCD shield in this proyect, so the first code i used have this:
Code:
if (!SD.begin(4))
***pi 4 and 10 are no connected to LCD shield, and before use Fat16 my code was working smiley-sad ***
Do i need this part? because i read on SDCARD this must to be declared:
Code:
SdCard::init(uint8_t speed, uint8_t [b]chipSelectPin[/b])
Thanks for you help with this! smiley-grin
Logged
Me
\{end}
0
Offline Offline
Edison Member
Arduino rocks
View Profile
You need to change this line:
Code:
  if (!card.init() ||
to:
Code:
  if (!card.init(speed, chipSelectPin ) ||
Where
Quote
uint8_t SdCard::init    (    uint8_t     speed,
      uint8_t     chipSelectPin
Initialize a SD flash memory card.
Parameters:
    [in]   speed   Set SPI Frequency to F_CPU/2 if speed = 0 or F_CPU/4 if speed = 1.
    [in]   chipSelectPin   SD chip select pin number.
Returns:
    The value one, true, is returned for success and the value zero, false, is returned for failure.
In your case chipSelectPin is 4 and first try speed = 0.
You don't need this but it won't hurt:
Code:
Logged
Pages: [1]   Go Up
Print
Jump to:
