Topic: Gamepad connected to computer controls servos connected to Arduino board? (Read 8565 times) previous topic - next topic
jeffmorris
Is it possible to have a gamepad connected to computer control servos connected to Arduino board?
gamepad > computer > Arduino board > servos
gamepad > computer > Xbee > Xbee > Arduino board > servos
HazardsMind
If it is a PS2 gamepad then you can just connect it directly to the arduino. I've done this before and it worked perfectly.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
jeffmorris
HazardsMind
Ok, there is a library that allows you to use a Xbox controller with an arduino, check this out.
www.youtube.com/watch?v=_EgXrcxZPnE
and maybe this.
http://forums.makezine.com/comments.php?DiscussionID=7799
My GitHub:
jeffmorris
I am hearing-impaired and the video doesn't have captioning.
zoomkat
Quote
There are links below the video when the below is viewed at the youtube site. click the youtube icon on the bottom right of the video frame.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
jeffmorris
I tried the links below the video but the person who created the video made his own motor controller. I don't know if he uses XBee modems or not.
HazardsMind
That xbox controller is either USB or Bluetooth, so you will need either a BT module or USB module, to communicate between it and the arduino.
My GitHub:
jeffmorris
There are wired and wireless XBOX 360 gamepads. The person in the video was using a wired XBOX 360 gamepad. Do I need an USB Host Shield like this: https://www.sparkfun.com/products/9947 ?
HazardsMind
My GitHub:
jeffmorris
Am I supposed to run the Gamepad Processing code on my computer and the Motor Arduino code on the Arduino board? Running the Gamepad Processing code opens the Gamepad window where I see the sliders move when I move the thumbsticks on the gamepad. After uploading the Motor code to the Arduino, I open the Serial Monitor and the X-CTU window but nothing is happening on either terminal window. The person in the video uses motors controlled by H-Bridge circuit. My robot uses continuous servos. Any suggestions?
HazardsMind
My GitHub:
jeffmorris
http://www.mediafire.com/?s8xawz38e3sy0t1#!
I didn't write the code. Someone else wrote the code. Gamepad V2.0 seems to work but Motor V2.0 doesn't work because he uses motors connected to H-Bridge circuit and I have servos. He made his own H-Bridge circuit. I have Pololu Simple Motor Controller, Sparkfun Serial Controlled Dual Motor Driver, Seeed Studio Motor Shield, and Tamiya Twin Motor Gearbox. I'm not sure which motor controller work.
HazardsMind
Ok, are you using the servo library to control your servos? His code will obviously need to be altered to work with your servos.
My GitHub:
jeffmorris
I tried to modify the code to control two DC motors connected to Seeed Studio Motor Shield. 0 to 127 runs the motor forward. 0 to -127 runs the motor backward.
Link to Seeed Studio Motor Shield Wiki: http://www.seeedstudio.com/wiki/Motor_Shield
Code: [Select]
int pinI1=8;//define I1 interface
int pinI2=11;//define I2 interface
int speedpinA=9;//enable motor A
int pinI3=12;//define I3 interface
int pinI4=13;//define I4 interface
int speedpinB=10;//enable motor B
int spead =127;//define the spead of motor
byte checkByte = 0;         // incoming serial byte
byte lMotorSpeed = 0;
byte rMotorSpeed = 0;
byte lMotorDir = 0;
byte rMotorDir = 0;
int ledPin = 4;
int counter = 0;
int timeout = 15; // about half a second
int second = 0;
  pinMode(pinI1,OUTPUT);
  pinMode(pinI2,OUTPUT);
  pinMode(speedpinA,OUTPUT);
  pinMode(pinI3,OUTPUT);
  pinMode(pinI4,OUTPUT);
  pinMode(speedpinB,OUTPUT);
  if(Serial.available())
    if (Serial.available() > 2)
      checkByte = Serial.read();
      if(checkByte == '#')
        counter = 0;
        digitalWrite(ledPin, HIGH);
        lMotorSpeed = Serial.read();
        rMotorSpeed = Serial.read();
        //Serial.println("checkByte OK!");
        lMotorSpeed = (Serial.read()-'0')*100;
        lMotorSpeed += (Serial.read()-'0')*10;
        lMotorSpeed += (Serial.read()-'0');
        //Serial.print("L Value Read: ");
        //Serial.println(lMotorSpeed, BIN);
        rMotorSpeed = (Serial.read()-'0')*100;
        rMotorSpeed += (Serial.read()-'0')*10;
        rMotorSpeed += (Serial.read()-'0');
        //Serial.print("R Value Read: ");
        //Serial.println(rMotorSpeed, BIN);
        lMotorDir = bitRead(lMotorSpeed, 7);
        rMotorDir = bitRead(rMotorSpeed, 7);
        //Serial.print("L Motor Dir: ");
        //Serial.println(lMotorDir, BIN);
        //Serial.print("R Motor Dir: ");
        //Serial.println(rMotorDir, BIN);
        if(lMotorDir)
          //Serial.println("L Motor Dir: Backwards");
          digitalWrite(pinI4,LOW);//turn DC Motor B move anticlockwise
          digitalWrite(pinI3,HIGH);
          //Serial.println("L Motor Dir: Forwards");
          digitalWrite(pinI4,HIGH);//turn DC Motor B move clockwise
          digitalWrite(pinI3,LOW);
        if(rMotorDir)
          //Serial.println("R Motor Dir: Backwards");
          digitalWrite(pinI2,HIGH);//turn DC Motor A move clockwise
          digitalWrite(pinI1,LOW);
          //Serial.println("R Motor Dir: Forwards");
          digitalWrite(pinI2,LOW);//turn DC Motor A move anticlockwise
          digitalWrite(pinI1,HIGH);
        lMotorSpeed = map(lMotorSpeed, 0, 127, 0, 127);
        rMotorSpeed = map(rMotorSpeed, 0, 127, 0, 127);
        analogWrite(speedpinA,lMotorSpeed);//input a simulation value to set the speed
        analogWrite(speedpinB,rMotorSpeed);
