Topic: Serial.print() Cutting Off Phrases (Read 1 time) previous topic - next topic
ZacharyBruno
Hello,
I'm using Serial.print() to debug my program (see where it runs and where it does not). Currently the program is supposed to print out the following:
"Starting...."
then
"IMU Started"
then
"MLB"
then
"Roll Loop Done"
However, in the Serial Consol, I'm getting these phrases cut off at random sections like this:
"Starting....IMU StartedMLBRollLo"
Why is this?
Thanks,
Zachary
It's not the while loop timer issue. I tried while(1) and it did the same thing. One thing to note is that "MLB" is always complete. I'll upload the files I'm working with. It isn't the complete package, so it won't compile, but it should be all that is necessary.
Code: [Select]
void Plane::Move(int roll, int pitch, int yaw, String velocity, int time) /// time in miliseconds
  desiredRoll = roll;
  desiredPitch = pitch;
  desiredYaw = yaw;
  desiredVelocity = velocity;
  unsigned long startTimer = micros();
  unsigned long endTimer   = micros();
  while ((endTimer - startTimer) < (time*1000)) {
    Serial.println("MLB");
    delay(15);
    rollPlane(roll);
    Serial.println("Roll Loop Done");
    delay(15);
    pitchPlane(pitch);
    Serial.println("Pitch Loop Done");
    yawPlane(yaw);
    Serial.println("Yaw Loop Done");
    velocityPlane(velocity);
    Serial.println("Velocity Loop Done");
    /// May need a function to check if there is a lost connection/regained conection to the IMU via Serial
RadarProject - Arduino Autopilot for RC http://radarproject.wordpress.com/
PeterH
You are printing stuff out in a loop that looks as if it would run very quickly - you are probably producing output faster than the serial port can transfer it. Is it really useful to print stuff out that frequently?
I only provide help via the forum - please do not contact me for private consultancy.
MarkT
Does the problem still show up if you reduce the baud rate from 115200 to 57600?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
