Topic: connect pic with arduino (Read 720 times) previous topic - next topic
marios_
Dec 05, 2012, 01:23 pm Last Edit: Dec 05, 2012, 01:47 pm by marios_ Reason: 1
Hello guys
I want to connect my pic18f with arduino mega. when i sent HIGH from the pic i want arduino to read it and and execute a command. Can you help me with the code please.
I tried this code but without result.
int inPin = 22;   // choose the input pin
int val = 0;     // variable for reading the pin status
pinMode(inPin, INPUT);
val = digitalRead(inPin);  // read input value
if (val == HIGH) {
// execution of this command
Thank you
Groove
What's the problem?
Have you connected the grounds together?
Per Arduino ad Astra
wildbill
What were you expecting?
PaulS
That code does something. You expect it to do something. What either of those somethings is is a mystery, though. Ball's back in your court.
You did connect the grounds, right?
Graynomad
You aren't executing any code when you detect the high input
if (val == HIGH) {
What did you expect to see from a comment?
______
Rob
