Topic: Reversed output on 74hc595 (Read 2871 times) previous topic - next topic
bgenc
I am a beginner at electronics. I was trying to light up 8 leds using a 74hc595. I did all the cabling and programming but faced a very unexpected result. When I upload a high bit to the register, it outputs a low bit, and vice versa. So when I want to light up all 8 leds, they all get dark. If I try to to get them all dark, then they altogether light up. Here is my code for lighting them up one by one (This actually makes them all dark one by one):
int pData = 2;
int pShift = 3;
int pLatch = 4;
  pinMode(pData, OUTPUT);
  pinMode(pShift, OUTPUT);
  pinMode(pLatch, OUTPUT);
  digitalWrite(pLatch, LOW);
  digitalWrite(pShift, LOW);
  digitalWrite(pData, HIGH);
  digitalWrite(pShift, HIGH);
  digitalWrite(pLatch, HIGH);
I can of course move on with this reverse logic, uploading high when I need low, etc, but seriously, what is going on here? Any guidance is appreciated.
dhenry
You have just loaded '1' into the shift register.
Papa G
Sounds like a wiring logic problem. Can you post your schematic?
bgenc
I don't have a schematic ready but I can show you some pictures:
bgenc
And that is supposed to light up the first led, right? In my case it does the opposite.
dhenry
Depending how the leds are wired, those pictures can be total correct.
If you don't want to reverse your data being sent, just reverse how the leds are wired: if they are wired to ground now; wire them to Vcc; if they are wired to Vcc, wire them to ground.
dhenry
Yes / no, depending on how your leds are wired.
bgenc
Damn, I totally see your point. thanks a million. I had to be much more careful.
Papa G
Okay, it appears you have your logic backwards. You have all your LED anodes wired to +V through a current limiting resistor. Then you are driving the individual cathodes from the output of your shift register. So, if you want to turn on an LED you must write a LOW into the shift register output so that current will flow from +V toward a low voltage(effectively ground). When you write a HIGH into the shift register output, you effectively have +V at both ends of your circuit, and no current flows. Does that make sense?
bgenc
It absolutely does. Thank you very much. Problem solved.
Papa G
You're welcome. :)
