Topic: Sensor Power Supply (Read 702 times) previous topic - next topic
Arduino4HS
I'm using some infrared sensors that use a LED and phototransistor, which both require a voltage to operate. I also have a 12v clip that is powering some motors through a driver chip. Is it safe to power these sensors (with the appropriate additional series resistance) from the motor supply? Will motor operation affect the sensors if the supply is used this way?
Grumpy_Mike
Quote
Yes but make sure the signal going into your arduino is no greater than 5V.
Quote
There is always that possibility because motors generate interference. Good supply decoupling is often very important.
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
