Topic: LM35D ¿Good? (Read 912 times) previous topic - next topic
Picon
http://www.ti.com/lit/ds/symlink/lm35.pdf
Page: 6 .Graphic: Minimum Supply Voltage vs. Temperature.
The graph shows the voltage discontinuities at certain temperatures. The slope increases with increasing current. Arduino generates a voltage of 5.01 V.
How I can I know that there are no discontinuities in voltage between +2 º, +100 º C?
I see in the graph where the discontinuities begin to 2 mA, but I do not see where the discontinuities with 40 mA.
dhenry
Typically done by reading the datasheet or experimenting with the chip.
Grumpy_Mike
No it doesn't.
The dotted line indicates that the chip is operating outside it's recommended parameters, not that there is a discontinuity in reading.
Nice useful post as normal from dhenery.
Picon
Can you tell me why there is a 5?
  samples = (5.0* analogRead(pin) * 100.0) / 1024.0;
for this device.
100ºC = 1024 points
Tª = (points * 100) / 1024
Why you should add 5?
Grumpy_Mike
You are not adding 5V you are multiplying by 5V.
An analogue reading returns a number from 0 to 1203, this corresponds to a voltage between 0 to 5V so this:-
Is converting the number you read into a voltage.
dhenry
Things like that utilize floating point math and floating point math is quite inefficient on an 8-bit mcu.
A simpler approach would be to use fixed point math.
Grumpy_Mike
No it is not a simpler approach it is an approach that runs faster.
We are dealing with a compiler here and simple projects. All those posts and you still haven't got the basic hang of this forum have you.
