Topic: noob question how to vertical scrolling display (Read 828 times) previous topic - next topic
nittrick
Jan 06, 2013, 12:34 am Last Edit: Jan 06, 2013, 02:34 pm by nittrick Reason: 1
hi
i got a 16x2 display
(http://dx.com/p/lcd-keypad-shield-for-arduino-duemilanove-lcd-1602-118059)
i want it to do like this.
     _____________                                          _____________                              _____________
   I  message1       I        when pressed down -->  I message2    I   and down agien  I message 3     I  when pressed ones more back
   I  message2       I                                         I message3      I                            I message 1     I  to picture one.
   ______________                                           _____________                             _____________
i want do be able to do this the reverse way whit up too.
i have made a fast sketch i know the syntax is all messed up but i think u understand, see it as a mind map
Quote
int x=0
if down button pressed
   if x>4
      set x+1
      print z
else if up button pressed
   if x>-2
   set x-1
print z
print z
then my ide of z is that depending on the what x is it going to put different text in z. like
Quote
if x= 1
z=message 1
else if x=2
z=message 2.
its the last part with z i cant solve.
is this possible or how do a solve the problem?  i have tried to google it but i dont know what to search for.
floresta
Quote
You are talking about vertical scrolling.
What is called 'scrolling' in Arduinoeese is called shifting in LCDspeak.
Now, to fix up your original post...
If you highlight the stuff below "i want it to do like this." and use the Teletype button (it looks like a typewriter) it will be easier to format.
The stuff you have put into a 'quote' block should have been put in a 'code' block using the button that looks like a '#' symbol.
Don
nittrick
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
