Topic: Serial Read with Switch/Case problem (Read 3697 times) previous topic - next topic
flotilla
  I am using an UNO board with a Bluesmirf BT module connected to an android app.
I am trying to get the program to read the serial input from the app through the BlueSmirf
and run a different case depending on the input.
For some reason it does nothing when I press an input in the app and I can't work out why.
For a test I have an LED hooked up to pin 13.  I can get it to switch on and off using the app with
no problems with the first set of code.
however, I have tried to integrate that into the second set of code and I don't think I am doing it right
and possibly have the serial.read in the wrong place.
I figured if I can get case 4 (test LED)to work then I can get the rest of the code to work for my device.
can anyone see what I am doing wrong?
The android app says the following:
microController BT outputs standard 2 byte messages. The messages contain a key (0-255) and a value (0-255).
outgoing: (key, value)
(Working bit)
const int ledpin = 13;
  pinMode(ledpin, OUTPUT);  // pin 13 (TestLED)
  Serial.begin(115200);       // start serial communication at 115200bps
    if( Serial.available() >= 2)       // if data is available to read
    int key = Serial.read();
    int val = Serial.read();
    digitalWrite (key,val);
(Not Working Code)
const int ShakePin = 4;
const int FeedPin = 5;
const int StopPin = 6;
const int TestPin = 13;
byte mode;
  pinMode(ShakePin, OUTPUT);  //Shaker Relay Pin
  pinMode(ShakePin, LOW);  //
  pinMode(FeedPin, OUTPUT);  // Feeder Relay Pin
  pinMode(FeedPin, LOW);  //
  pinMode(StopPin, INPUT);  // Cutout Switch
  pinMode(StopPin, HIGH);  //
  pinMode(TestPin, OUTPUT);  // pin 12 shakermotor as OUTPUT
  pinMode(TestPin, LOW);  // pin 12 shakermotor as OUTPUT
  if( Serial.available() >= 2){
    if ( mode == 0 && key == 4){ mode = 1;}
    if ( mode == 0 && key == 5){ mode = 2;}
    if ( mode == 0 && key == 13){ mode = 4;}
    switch (mode){
case 0:  // do nothing and wait
   break;
case 1:  // Shake Relay
    digitalWrite (ShakePin, HIGH);
    delay (5000);
    digitalWrite (ShakePin, LOW);
    mode = 0;
   break;
case 2:  // Feed Relay
    delay (5000);
    digitalWrite (FeedPin, HIGH);
    delay (3000);
    if (digitalRead(StopPin) == LOW) mode = 3;
break;
case 3:  //Stop Feed Relay and GoTo mode 0
    digitalWrite (FeedPin, LOW);
    mode = 0;
break;
case 4:   //LED Test
     digitalWrite (TestPin,HIGH);
     delay (3000);
     digitalWrite (TestPin,LOW);
     mode = 0;
PaulS
What is sending the data? Is the data binary or ASCII? Your non-working code assumes binary, but that may not be the case.
Every case, even the last one, should have a break statement.
flotilla
#2
Dec 05, 2012, 09:40 pm Last Edit: Dec 05, 2012, 09:46 pm by flotilla Reason: 1
The android app sends the data over bluetooth to the serial port when you press a touchscreen button.
The app sends out two byte messages. I am trying to interpret the first byte (key) into different variables.
On the app you can set different buttons to output different key bytes. It also outputs a value for each key
as well in the second byte but I am not using that.
I added the break; to the last case but still no joy. How do I find out if the output is ASCII or binary? does the fact that
it works in the first set of code indicate anything?
PaulS
You need to help us understand what "it doesn't work" means. Do the wrong pins go HIGH/LOW?
Let's see. Is HIGH equal to INPUT or OUTPUT? I'm guessing that the second statement in each pair is supposed to be digitalWrite(), not pinMode().
flotilla
Ahh, I have been staring at this code for two hours and missed that every time. Damn it.
Changed the relevant lines to digitalWrite and it now works great.  Thanks again Paul! I
Can now get on with the mechanical side of things.
Thanks
