Topic: Teensy 3.0: 48/96 MHz, Arduino Due: 84 MHz, ARM cellphones: 1-1.5Ghz. Why? (Read 8141 times) previous topic - next topic
GoForSmoke
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
JoeN
Run fast enough and what do all those jumper wires do?
I wouldn't think the external bus would run anywhere near the speed of the processor at the higher speeds.  For example, it seems you can only get 22Mhz out of the Raspberry Pi despite the relatively high (non-overclocked) clock speed of 700Mhz.  I would expect the 1-1.5Ghz processors I was talking about would have bus speeds around that too.  Instead, I am mostly interested in having such processors available for their relatively better computing power.
http://codeandlife.com/2012/07/03/benchmarking-raspberry-pi-gpio-speed/
I will never ask you to do anything that I wouldn't do myself.
GoForSmoke
Back in the 80's I was shown a circuit that ran over 100 Mz where if one short wire between two contacts was bent to one side the circuit worked but if it was bent the other way it didn't and if a shorter piece that went direct was used the circuit didn't work either. The EE who showed me that just shrugged and shook his head, it wasn't his circuit.
I'm sure there's many circuits I might build that won't take anywhere near that speed without showing some kind of problem.
